UADE2 chronicles
    BSzili
    Posts: 570 from 2012/6/8
    I'm not dead yet, it's just that the uade2 ANR player eats up all the free time I can dedicate to MorphOS. After some false starts I finally have a clear idea on how to get things together, but I have some questions.
    Are there any good info on making shared libraries out there? Can I compile them with GCC4? Do I have to use some specific compiler/linker flags? I tried looking some makefiles, but they are all over the place. Also are there any restriction on using LibNIX functions?
    The other thing is AHI double buffering. I made an AHI backend for uade123, and it sometimes hangs at the beginning of the playback. This is how the source looks like:
    #include <stdlib.h>
    #include <devices/ahi.h>
    #include <proto/exec.h>
    #ifndef __MORPHOS__
    #define AllocTaskPooled(size) AllocMem(size, MEMF_ANY)
    #define FreeTaskPooled(mem, size) FreeMem(mem, size)
    #endif
    #include "uadeconstants.h"
    #include "audio.h"
    #include "uade123.h"
    /* this is hardcoded baby! */
    #if (UADE_BYTES_PER_SAMPLE == 1)
    #if (UADE_CHANNELS == 1)
    #define type AHIST_M8S
    #elif (UADE_CHANNELS == 2)
    #define type AHIST_S8S
    #else
    #error Invalid channel number.
    #endif
    #elif (UADE_BYTES_PER_SAMPLE == 2)
    #define type AHIST_M16S
    #define type AHIST_S16S
    #else
    #endif
    #else
    #error Invalid bytes per sample value.
    #endif
    #define BUFSIZE (8192 * UADE_BYTES_PER_SAMPLE * UADE_CHANNELS)
    static char AHIBuf[2][BUFSIZE];
    static ULONG rate;
    static struct MsgPort *AHIPort = NULL;
    static struct AHIRequest *AHIReq[2] = { NULL, NULL };
    static int active = 0;
    static int slots = 2;
    void audio_close (void)
    if (AHIReq[1])
    if (!CheckIO((struct IORequest *) AHIReq[1]))
    AbortIO((struct IORequest *) AHIReq[1]);
    WaitIO((struct IORequest *) AHIReq[1]);
    FreeTaskPooled(AHIReq[1], sizeof(struct AHIRequest));
    AHIReq[1] = NULL;
    if (AHIReq[0])
    if (!CheckIO((struct IORequest *) AHIReq[0]))
    AbortIO((struct IORequest *) AHIReq[0]);
    WaitIO((struct IORequest *) AHIReq[0]);
    if (AHIReq[0]->ahir_Std.io_Device)
    CloseDevice((struct IORequest *) AHIReq[0]);
    AHIReq[0]->ahir_Std.io_Device = NULL;
    DeleteIORequest((struct IORequest *) AHIReq[0]);
    AHIReq[0] = NULL;
    if (AHIPort)
    DeleteMsgPort(AHIPort);
    AHIPort = NULL;
    int audio_init(const struct uade_config *uc)
    if (uade_no_audio_output)
    return 1;
    rate = uc->frequency;
    if ((AHIPort = CreateMsgPort()))
    if ((AHIReq[0] = (struct AHIRequest *) CreateIORequest(AHIPort, sizeof(struct AHIRequest))))
    AHIReq[0]->ahir_Version = 4;
    if ((AHIReq[1] = (struct AHIRequest *) AllocTaskPooled(sizeof(struct AHIRequest))))
    if (!OpenDevice("ahi.device", AHI_DEFAULT_UNIT, (struct IORequest *)AHIReq[0], 0))
    AHIReq[0]->ahir_Std.io_Command = CMD_WRITE;
    AHIReq[0]->ahir_Std.io_Offset = 0;
    AHIReq[0]->ahir_Type = type;
    AHIReq[0]->ahir_Frequency = rate;
    AHIReq[0]->ahir_Volume = 0x10000;
    AHIReq[0]->ahir_Position = 0x8000;
    CopyMemQuick(AHIReq[0], AHIReq[1], sizeof(struct AHIRequest));
    return 1;
    return 0;
    int audio_play(unsigned char* output_samples, int num_bytes)
    int size;
    return 1;
    while (num_bytes)
    WaitIO((struct IORequest *) AHIReq[active]);
    size = (BUFSIZE > num_bytes) ? num_bytes : BUFSIZE;
    CopyMem(output_samples, AHIBuf[active], num_bytes);
    num_bytes -= size;
    AHIReq[active]->ahir_Std.io_Data = AHIBuf[active];
    AHIReq[active]->ahir_Std.io_Length = size;
    AHIReq[active]->ahir_Link = AHIReq[active ^ 1];
    SendIO((struct IORequest *) AHIReq[active]);
    // swap buffers
    active ^= 1;
    return 1;
    are there any obvious problems there?
  • »05.01.13 - 15:06
    BSzili
    This is not about the ANR plugin yet, which is in development hell currently. I have some idea how it all should work together (library, playloop task, uadecore), but I have no time and energy to finish it for the time being. ANR also locks up my system at exit, so even if I resumed the work on the plugin, I wouldn't be able to test it.
    However I fixed some nasty bugs in the uade123 command line player, including the problems (hits, crashes) with the code above. You also won't need an UADE: assign anymore, just make sure uade123 and uadecore are in the same drawer.
  • »24.07.13 - 17:51
    pampers
    Posts: 1073 from 2009/2/26
    How about integrating it somehow with Jukebox - possible? Or even better - UADE reggae decoder :)
    [ Edited by pampers 24.07.2013 - 21:38 ]
    MorphOS 3.x
  • »24.07.13 - 18:37
    Intuition
    Posts: 1116 from 2013/5/24
    Is Piru's source no help from the port he made years ago?
  • »24.07.13 - 19:14
    Posts: 12571 from 2003/5/22
    In think he already looked at that:
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=32&topic_id=6961&start=45
  • »24.07.13 - 20:03
    Intuition
    Perhaps he should write to the FSF asking if an ANR plugin would indeed violate the GPL?
  • »24.07.13 - 22:26
    BSzili
    @Intuition:
    It's not a concern ATM, because the ANR plugin is shelved, as I wrote in my last post.
    @pampers:
    AFAIK Jukebox uses reggae classes, so the first would imply the latter. I don't think it would be much easier than the ANR plugin. Is there any documentation out there on writing reggae classes?
  • »25.07.13 - 06:08
