Problem with WorkbenchControl
    zzd10h
    Posts: 20 from 2012/1/10
    Bonjour,
    I'm trying to port, for fun, one of my little programs from OS4 to MOS (on a PowerBook under MOS3.2). The goal of this program is to detect selected files in Workbench and to pass them to YAM or SimpleMail as attachment.
    But I have problem with WorkbenchControl function.
    The following code works under AOS4 but I can't find why it fails under MOS.
    The call to WorkbenchControl always return FALSE (therefore "Error" in my sample)
    Certainly that I miss a little thing...
    I compile the following code with
    gcc AttachMail.c -o AttachMail -noixemul
    When I start it (even with files selected in Ambient) I obtain "Error"
    Thank for your help
    #include <stdio.h>
    #include <proto/exec.h>
    #include <proto/wb.h>
    #include <workbench/workbench.h>
    #include <string.h>
    int main(int argc,char **argv)
    struct List * selectIcons;
    if (WorkbenchControl(NULL,WBCTRLA_GetSelectedIconList,&selectIcons,TAG_DONE))
    printf("OK n");
    WorkbenchControl(NULL,WBCTRLA_FreeSelectedIconList,selectIcons,TAG_DONE);
    else
    printf("Error n") ;
    return 0;
    [ Edité par zzd10h 10.07.2013 - 21:54 ]
  • »10.07.13 - 17:53
    Piru
    Posts: 610 from 2003/2/24
    WBCTRLA_GetSelectedIconList and WBCTRLA_FreeSelectedIconList return an error because they are not implemented.
    You can see the implemented tags here:
    http://morphosambient.cvs.sourceforge.net/viewvc/morphosambient/ambient/wblib/control.c?view=markup
    [ Edited by Piru 10.07.2013 - 23:06 ]
  • »10.07.13 - 18:05
    zzd10h
    Thank you Piru,
    I thought that it was implemented because it is in GG/os-include/workbench/workbench.h
    But I don't need to search more ;)
    Is a similar function on Ambient to retrieve selected files ?
    [ Edité par zzd10h 10.07.2013 - 22:17 ]
  • »10.07.13 - 18:12
    Posts: 1520 from 2003/2/24
    zzd10h wrote:
    Thank you Piru,
    I dont see how this could be implemented in Ambient. In Ambient you can have icons selected in multiple windows (drawers). In Workbench you have only one global lasso that selects only icons which are visible (i.e. not underneath other window or otherwise hidden) or select icons only in one window.
    I dont know if this could be implemened using mime types or some arexx script. Unable to check here.
  • »10.07.13 - 20:41
    Posts: 2206 from 2003/2/24
    I think using separate program for this on Ambient is overkill. I'd do this just with Ambient's mime types. Select files you want to send and have a hotkey or context menu action to send them to a little arexx script (or maybe here could be separate program too) which adds them to SimpleMail or YAM. ARexx script could detect if either of them is running, and if not, start one of them before adding files.
    [ Edited by jPV 11.07.2013 - 08:56 ]
  • »11.07.13 - 03:55
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    I implemented the necessary internal functions to retrieve selected files in a given lister (and list all views as well). So it is actually possible to do that using a REXX script.
    For instance, create some selected.rexx file with the following contents:
    address AMBIENT
    ViewList views
    /* say 'number of views ' views.count */
    do i = 0 to views.count - 1
    viewpath = substr(views.i, pos(':', views.i)+1)
    viewid = substr(views.i, 1, pos(':', views.i)-1)
    say 'viewpath ' viewpath
    say 'viewid ' viewid
    GetSelectedNames selectedfiles viewid
    do j = 0 to selectedfiles.count - 1
    say selectedfiles.j
    end
    end
    This example will list all selected files in all opened views. In your case, you might want to get only files of the active view, so you'd need to check against active window title, i suppose.
    That said, doing that with mimetypes as jPV explained would be even better.
    [ Edited by Fab 11.07.2013 - 11:32 ]
  • »11.07.13 - 07:15
    zzd10h
    Thanks you guys for your suggestions,
    and merci Fab for your sample.
  • »11.07.13 - 07:48
