Buttons on an image Background
    rebraist
    Posts: 96 from 2011/4/6
    Hi! Is there a way i can create a mui window, draw a picture on its background and then put some button objects on the picture?
    I was thinking i could override om_draw for an area object, and this wouldn't allow me to attach some buttons on the area, but can i do the same for a window object (in this way i could even attach buttons on it)?
    Thk you!
    Sam440 Os4.1.6
    Aros-Aros-Aros.
  • »04.06.13 - 20:02
    Posts: 2564 from 2003/2/24
    You could try defining that picture the window's (default) background.
  • »04.06.13 - 20:04
    Posts: 1090 from 2004/9/23
    Yeah, MUIA_Background is the way to go, but only if you have a good reason, as you limit the users configuration possibilities
    Geit
  • »04.06.13 - 20:09
    rebraist
    thx!!! i'll try it!!
    [ Edited by rebraist 05.06.2013 - 14:10 ]
    Sam440 Os4.1.6
    Aros-Aros-Aros.
  • »05.06.13 - 10:06
    rebraist
    Yeah MUIA_Background, placed in a Vgroup, works! But how can i view all of my picture?
    When i use my jpg (but with png is the same thing), my window is sized just as the buttons placed in it.
    Thk u!!
    Sam440 Os4.1.6
    Aros-Aros-Aros.
  • »07.06.13 - 18:45
    rebraist
    i've solved putting two vspace, but isn't a way mui displays the Whole picture?
    Sam440 Os4.1.6
    Aros-Aros-Aros.
  • »08.06.13 - 17:51
