gccselect problems
    Intuition
    Posts: 1113 from 2013/5/24
    What is the correct command to change the default compiler to gcc4?
    If I run 'sdk:gccselect4 4.4.5' or 'sdk:gccselect 4.4.5' they both fail with a 'wrong number of arguments' message.
    I've looked at the contents of both scripts and they only seem to require the one argument. :-?
    I have the SDK installed to Work:Development on a PFS3 formatted partition rather than SYS:Development if that makes any difference?
  • »30.05.13 - 19:09
    Intuition
    Hmm, it seems I had errors on my PFS3 partition.
    Once I fixed them and rebooted gccselect worked as expected. :)
  • »30.05.13 - 19:56
    Posts: 3268 from 2003/3/5
    The only FS that gave me no problems when *preparing* the SDK, was SFS. Neither IceFS nor PFS3 are able to build a working SDK.
  • »03.06.13 - 05:53
    Leif
    Posts: 111 from 2006/5/31
    Just want to clearify that installing SDK and using SDK works with IceFS.
    I do remember there was some weird issue with the preparing of SDK..
    It was some time ago though..
    I should also add that there is an issue using SDK with IceFS
    if SDK is on a partition larger than 500GB. This due to some ixemul
    code somewhere peeks the FileLock for fl_DiskKey instead of using SameLock(). This breaks at 500GB for IceFS (due to 32bit fl_DiskKey).
    [ Edited by Leif 03.06.2013 - 13:28 ]
  • »03.06.13 - 09:19
    Intuition
    That's interesting to hear.
    I think I'll give IceFS a try as I've been experiencing some weird issues that only started happening since I started using PFS. If they still persist I'll go back to SFS.
  • »03.06.13 - 10:50
    Posts: 645 from 2004/4/15
    I Am using Ice Fs since it was released.
    It's stable and dast.
    Give it a try.
  • »03.06.13 - 17:17
    Intuition
    Give it a try.
    I'll back up my data and reformat with IceFS tonight and report back with how I get on.
    Is it OK to use it for SYS: too?
  • »03.06.13 - 19:12
    Leif
    If you are on Mac then no, else yes if you have separate boot
    partition.
  • »03.06.13 - 19:22
    Intuition
    I'm on a Mac with HFS Boot/DH0, PFS SYS/DH1 and PFS Work/DH2 currently, so I should only format DH2 with IceFS?
  • »03.06.13 - 19:46
    yes
  • »04.06.13 - 02:57
    Intuition
    eliot wrote:
    yes
    I've been running IceFS on my data partition for a few hours now and it seems OK so far. Not blindingly fast or anything but not slow either.
  • »04.06.13 - 03:34
