openvpn development
    bash64
    Posts: 974 from 2010/10/28
    Started with the latest sdk.
    configure barfs at no support for ipv6.
    I am guessing there is a switch to tell it to ignore ipv6.
    Looking for it....
  • »08.05.13 - 14:42
    bash64
    Joined their forum and posted the issue.
  • »08.05.13 - 15:04
    Posts: 3300 from 2003/3/5
    Well... I would probably start by disabling that check in configure and then carefully check for the places in which it is used. From a brief look, it's mostly used for case AF_INET6 only, which you can easily #ifndef __MORPHOS__ out, it's just a handful of places in the source code.
  • »09.05.13 - 05:21
    bash64
    thanks.
    this is on hold as I think bochs holds more promise.
  • »09.05.13 - 23:39
