goa / w3d on radeon cards
    waldiamiga
    Posts: 91 from 2007/7/25
    thellier wrote:
    Hello & Happy New Year 2014
    Wazp3D for Morphos is NOW on Aminet
    Yeahh, great. Happy New Year thellier.
    MorphOS.pl
    Core i7 Notebook|WinUAE 3.x/AmigaOS4.1x & Icaros Desktop 2.x & QEmu 6.x.x
  • »02.01.14 - 17:46
    Jambalah
    Posts: 820 from 2008/3/30
    Hi Thellier and thanks for your work!
    A question: I run the Wazp3D config program, doing some settngs and close the window. Nothing is saved in Envarc and nothing could be loaded from there. So when I try WipeOut, for example, a window appears with a "Loading Wazp3D.cfg" message but nothing more happens. Is it a normal beta behaviour? Thanks!
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »03.01.14 - 18:18
    Intuition
    Posts: 1110 from 2013/5/24
    Thanks Alain!
  • »03.01.14 - 19:01
    Posts: 33 from 2013/6/20
    @Intuition
    wipeout dont works = i dont know why as it works with wazp3d/os4
    wazp3d-prefs change the parameters INSIDE the wazp3d library
    then when the prog end (ie w3d_destroycontext) then a wazp3d.cfg file is saved
    that will be used next run
    this way of working ensure to never save a crashing config
    Alain
  • »04.01.14 - 07:30
    Jambalah
    Thanks for answer Alain!
    The real problem is not WipeOut is that Wazp3d.prefs doesn't save any configuration file and so it won't load anything at start. And so will do the library. The only way I managed to save a config file was to launch prefs, run the cow demo and when I stopped demo it saves a configuration file (!!) which I put in Envarc:
    Pegasos II 1 ghz
  • »04.01.14 - 10:10
    Henes
    Posts: 507 from 2003/6/14
    thellier,
    As I told you on meta-morphos forum, warpup libs are no usual libs. You can not simply rename an amigaos/morphos lib to make a warpup one... The whole ABI is different, amongst other things. I guess all this must be explained somewhere in the old warpup docs from the 90'... The poweropen and systemv ABIs were even documented in the old morphos sdk for more than 10 years (and google knows about them anyway, as they are not some amiga creation)...
    As to why it works on hyperos... I imagine you also didn't write a proper warpup lib there... so I expect its powerpc.library has some kind of hardcoded warp3dppc.llibrary -> warp3d.library wrapper doing all the hard work for you. You tell me :)
    [ Edited by Henes 05.01.2014 - 00:37 ]
  • »05.01.14 - 00:35
    BSzili
    Posts: 559 from 2012/6/8
    So warpup programs can't use ABox API MorphOS libraries? Is the stock warp3dppc.library a warpup binary? I'm not having a go, but I couldn't tell, because the official libraries are encrypted.
  • »05.01.14 - 13:19
    zukow
    Posts: 642 from 2005/2/9
    @BSzili
    Morphos 1.4.5 binaries aren't encrypted.
  • »05.01.14 - 13:35
    Henes
    They can and they all (directly or indirectly) do.
    It is a morphos native binary... respecting warpup abi and api.
    Same for powerpc.library and itix's rtgmaster.library (and I just noticed this one is opensource so it could really help wazp3d if alain can't search/read/understand warpup docs himself).
  • »05.01.14 - 13:50
    BSzili
    @zukow
    Thanks for the tip. I grabbed the 1.4.5 ISO, and the warp3dppc.library is a "normal" MorphOS library there. I must have misunderstood something.
    @Henes
    I get it now, I'll dig into wup.c/wup.h.
    http://aminet.net/package/driver/video/rtgmaster_mos
    [ Edited by BSzili 05.01.2014 - 14:10 ]
  • »05.01.14 - 13:50
    Posts: 1516 from 2003/2/24
    WarpUp libraries are built like any native MorphOS library but must use function prologue and epilogue to switch r2 and ctr in PPC calls.
  • »05.01.14 - 14:12
    BSzili
    @itix
    I created the glue functions using your macros:
    #define	RC_START(x)	ULONG ctrstore; struct EmulHandle *old_r2 = MyEmulHandle; x rc; asm ( "mfctr %0" : "=r" (ctrstore)); MyEmulHandle = SysBase->ThisTask->tc_ETask->EmulHandle; SysBase->ThisTask->tc_ETask->EmulHandle = NULL; {
    #define RC_END } asm ("mtctr %0" : : "r" (ctrstore)); SysBase->ThisTask->tc_ETask->EmulHandle = MyEmulHandle; MyEmulHandle = old_r2; return rc;
    #define NR_START ULONG ctrstore; struct EmulHandle *old_r2 = MyEmulHandle; asm ( "mfctr %0" : "=r" (ctrstore)); MyEmulHandle = SysBase->ThisTask->tc_ETask->EmulHandle; SysBase->ThisTask->tc_ETask->EmulHandle = NULL; {
    #define NR_END } asm ("mtctr %0" : : "r" (ctrstore)); SysBase->ThisTask->tc_ETask->EmulHandle = MyEmulHandle; MyEmulHandle = old_r2;
    The problem is that struct ETask no longer seem to have an EmulHandle field, so this doesn't compile with the latest SDK. Has the EmulHandle field in ETask became private?
  • »09.01.14 - 10:36
    Piru
    Posts: 576 from 2003/2/24
    BSzili wrote:
    @itix
    It indeed is private. I think new code was supposed to use NewGetTaskAttrs() and NewSetTaskAttrs() with TASKINFOTYPE_EMULHANDLE. However after some checking it seems that NewGetTaskAttrs TASKINFOTYPE_EMULHANDLE doesn't always return the raw tc_ETask->EmulHandle value and thus it likely cannot be used as a direct replacement here.
    Anyway, this somewhat hackish solution should work:
    #pragma pack(2)
    struct HackETask
    UBYTE stuffbefore[130];
    struct EmulHandle *EmulHandle;
    #pragma pack()
    #define TASKEMULHANDLE ((struct HackETask *)SysBase->ThisTask->tc_ETask)->EmulHandle
    Then use TASKEMULHANDLE instead of SysBase->ThisTask->tc_ETask->EmulHandle.
    [ Edited by Piru 09.01.2014 - 15:36 ]
  • »09.01.14 - 13:11
    BSzili
    Thanks, for the time being I'll probably go with your workaround. Doing 3 New*TaskAttr() calls per function might add too much overhead. Then again, maybe it doesn't make much difference, we'll see when Wipeout 2097 is up and running with Wazp3D.
  • »09.01.14 - 14:02
    @BSzili
    Just compiled your latest change : Wazp3D still not workking with Wipeout and others....
    Alain Thellier
  • »09.01.14 - 18:30
  • vox
    vox
    Posts: 524 from 2003/11/25
    thellier wrote:
    @BSzili
    Alain Thellier
    I ve heard MOS 4.6 will have SAM460ex support AND Radeon4000HD driver.
    Nice and I am really waiting just for it :-)
    Should I be AmigaOS happy with 2D driver or MorphOS happy with GOA, REGGAE and yes W3D ... :-)
    Lame PC with AmiKit XE
  • »15.01.14 - 20:02
    Posts: 12079 from 2003/5/22
    I hope this will already come with 3.6 ;-)
    > MorphOS [...] with GOA
    Goa3D doesn't and won't work on Radeon R300 and beyond.
  • »15.01.14 - 21:26
  • vox
    vox
    Ah, nice whowoff I am ex-AmigaOS user :-) Well, it will not come with AOS 4.1.6
    either, so yes, all bets on MorphOS 3.6
    But looking forward to experience MOS 4.6 as well.
    P.S. Will it mean just 4000/4200HD model, or some wider varity based
    on same chips?
    Doesn`t is enough, please no won`t work ... is there some serious
    reasons since chips should be kind of backward compatibile?
    [ Edited by vox 16.01.2014 - 11:35 ]
  • »16.01.14 - 11:35
    > it will not come with AOS 4.1.6 either
    AmigaOS 4.1.6 has been released more than a year ago. And OS4 has Sam460ex support and a 2D driver for Radeon R700 for 3 years.
    Has there anything in particular been announced for this?
    > Will it mean just 4000/4200HD model, or some wider varity based on same chips?
    As you know, "R700 support" was the statement that was reportedly given on the Pianeta Amiga show last year. AFAIK, there is no HD4000 model, and HD42x0 models are R600-based. So I guess it should be HD43x0 models and above, but I have no inside knowledge whatsoever, only what has been stated in public for everybody to read upon.
    The MorphOS Team made it pretty clear that there will be no Rave3D for R300 and up, so no Goa3D (which relies on Rave3D) either. But as soon as Wazp3D will run hardware-accelerated via TinyGL, you won't need Goa3D anyway.
    > is there some serious reasons since chips should be kind of backward compatibile?
    It's been explained there by a MorphOS Team member:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=9256&forum=49&start=4
  • »16.01.14 - 13:53
    No one can say when the SAM460 port will be ready, and an HD4XXX driver has not been mentioned.
    It is not impossible, but the original work centered around the use of an X1300 video card.
    If things remain evolutionary, we should see an R400 driver (for support of the X800XT video card in G5 Power macs), and eventually an R500 driver (for X1300 video cards in the SAM460 and for later support of the X1900GT).
    Who is to say what 3.6 will include?
    Until its released, unless its mentioned prior to that release, its all speculation.
  • »16.01.14 - 16:51
    Henes
    At every new generation, Radeon chips are not "backward compatible" with their ancestors.
  • »16.01.14 - 19:03
    There're estimates by the developers at least:
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=11&topic_id=8931&start=106
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=38&topic_id=9764&start=30
  • »16.01.14 - 19:29
  • vox
    vox
    Software based rendering is NOT a solution.
    Every new generation of Radeons is NOT backward compatibile? Phew, AMD doesn`t know how to do the job.
    Please let me know when things go official about this project NAOMO and things speed up. I am really waiting just for it.
    I can buy X1550 LP card if really necessary.
  • »16.01.14 - 20:05
    BSzili
    If you are referring to Wazp3D, it has an OpenGL backend too.
  • »16.01.14 - 20:09
    Where did I say anything about software rendering in what you quoted from me?
  • »16.01.14 - 20:20
