CPU temperature
    Jambalah
    Posts: 820 from 2008/3/30
    Well, I dismounted the cpu unit and replaced cpu 1 (the one below assuming G5 stands vertically) since ASD diagnostic showed an error checking AD 7417 AD1 sensor. Assembled cpu unit, reseated and power on. After the chimes sound G5 booted MorphOS and I immediately noticed the difference: low temperature (started from 66 C degrees to 82) and quiet fans. I booted the ASD cd and checked for thermal calibration wich reporting an error message explaining that wrong values were found and reccomending to perform calibration. Did it and both cpu passed. Reboot and MorphOS runs ok with temperature between 80.9 and 81.1 and fans really quiet. I'm really satisfied! Let's check how it will go next days.
    @Intuition:
    Sorry to read your post only now but if you should encounter any problem downloading 2.5.8 let me know if I coul help in any way.
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »26.08.13 - 19:09
    Intuition
    Posts: 1110 from 2013/5/24
    @Intuition:
    Thanks, the torrent is coming down steadily so i'll just have to be patient. :)
    I haven't got the money to register MorphOS for my G5 at the moment after spending a lot of money upgrading and registering my PowerBook so the 30 minute time out pisses me of and causes me to not bother using it at the moment.
    Once I've registered it will be anothe story as I'll use it as my main development machine as the PB feels a tad slow when compiling C as I've got used to lighning fast Intel hardware over the years.
  • »26.08.13 - 19:41
    Lord76
    Posts: 64 from 2014/8/31
    Hello i have now a Power Mac with 2.7 ghz, he run at 82-86 Celsius on Morphos and 50-84 C on MAC OSX.
    Who can i download this Service CD ASD 2.5.8?
    greetings
    Powerbook G4 A1138
    Vampire V4 Standalone
    Amiga1200 with V1200
    A2000 with with V500+
  • »08.03.15 - 22:44
    BSzili
    Posts: 559 from 2012/6/8
    The ASD won't help you, MorphOS doesn't support power saving on G5s.
  • »09.03.15 - 10:02
    Lord76
    ah okay thank you, but my Temperatures are to high or not? I mean 86C is to much or not?
    greetings
    Powerbook G4 A1138
  • »09.03.15 - 14:41
    BSzili
    It is certainly high, but it's still within the limits.
  • »09.03.15 - 15:07
    wrong thread, sorry
    [ Edited by Jim 09.04.2017 - 07:37 ]
  • »09.04.17 - 12:33
