Re: 73 available systems for MorphOS 3.2
    TomKeric
    Posts: 146 from 2013/2/18
    I have a success report :)
    Inspite, I am sure I loaded from CD, I tried tge alternative model provided by Geit to hold the ALT key, and then select the CD symbol (appearing next to OSX HDD and MOS HDD)
    For some reason this appeared to work better, I got the Update option showing on the installation overlay window
    Thanks everyone, hope this will be helping others in my situation too
    BR/Tomas
    -If you've never failed, you've never tried -
  • »10.06.13 - 07:31
    Intuition
    Posts: 1113 from 2013/5/24
    Congratulations! :)
    I hope you enjoy MOS 3.2 as much as I have so far.
  • »10.06.13 - 17:58
    WeiXing3D
    Posts: 327 from 2012/6/13
    So folks would this model and configuration work with MOS 3.2?
    Product Information
    This Apple iBook G4 laptop (July,2005) has been customized. Without any modifications the Apple iBook G4 laptop (July,2005) features 1.33 GHz PowerPC G4 processor that is responsible for its fast performance. You can save all your data on this customized laptop, which boasts a hard drive capacity of s40 GB, 60 GB, 80 GB or 100 GB. With a resolution of 1024x768 pixels, this iBook gives you a high-quality visual output. Featuring built-in Ethernet and Wi-Fi capability, this 12.1-inch customized laptop offers the communications efficiency that makes staying in touch quick and easy. An ATI Mobility Radeon 9550 graphics processor in this iBook guarantees a thrilling gaming experience. WhatÂ’s more, thanks to its 512 MB RAM, the Apple iBook G4 laptop (July, 2005) comes handy while multitasking and storing data.
    Product Identifiers
    Manufacturer Apple
    Product Family iBook
    Model ID PowerBook6,7
    Model Number A1133
    MPN AppleiBook G412.1July2005
    Display
    Display Size 12.1"
    Miscellaneous
    Release Date July, 2005
    Please let me know and I'll snatch it from a local friend. Thanks.
    [ Edited by WeiXing3D 11.06.2013 - 22:38 ]
  • »12.06.13 - 01:21
    Posts: 12511 from 2003/5/22
    > Model Number A1133
    Simply compare with the list there:
    http://www.morphos-team.net/releasenotes/3.2
  • »12.06.13 - 06:46
