Posts: 1226 from 2010/1/6
Quote:ncafferkey schrieb:
As a possible work-around to use WEP, here's a sample WEP config that could be added to the wireless prefs file:
network={
ssid="mynet2"
key_mgmt=NONE
wep_key0=123456789abcdef123456789ab
wep_tx_keyidx=0
There is a small mistake if you use a text-key: you will need quotion marks for the key!
eg:
wep_key0="125689blablabla6565"............
I don't know why, but my Netgear W511T needs as first line in wireless.prefs following line:
update_config=1
network={
ssid="mynet2"
key_mgmt=NONE
wep_key0="blablabla123"
wep_tx_keyidx=0
}Without that line, Atheros-Chip won't go online........
[ Editiert durch Amigaharry2 05.01.2014 - 16:43 ]Peg2, 3xPowerMac G5, 2xPowerbookG4, 2x MacMiniG4, Efika (again), A3000T and life is never boring.....
