Atheros 5k MorphOS wifi support
    None of this bothers me on a desktop because I'm not adverse to running cat5 cables to each computer desk.
    But with laptops its really asnnoying. And the iBooks wifi is never likely to be supported.
    We really could use a good USB solution.
  • »20.06.13 - 00:23
    Posts: 2027 from 2003/2/24
    Andreas_Wolf,
    > So am I right in assuming that when my G5 arrives I will only be able to
    > use ethernet because USB wifi adapters are currently unsupported?
    Yes, you are. You could still use a WLAN Ethernet bridge though. That's what I do with my Mac mini G4.
    Atheros 5000 based PCI cards won't work on G5 machines? Don't they have compatible PCI bus or why?
  • »20.06.13 - 06:16
    Intuition
    Posts: 1110 from 2013/5/24
    Thanks, that's what I'll do as running cable from my office to downstairs where my router sits will be a pain.
  • »20.06.13 - 10:59
    Posts: 12080 from 2003/5/22
    Not with MorphOS 3.2 apparently:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=9234&forum=3&start=16
    I don't know what the reason for reported non-support of PCI slots in PowerMac G5 is.
  • »20.06.13 - 12:22
  • rNx
    rNx
    Posts: 35 from 2010/10/26
    Web Caster FT-STC-Na/g works, but only with static IP.
  • »28.06.13 - 16:40
    Intuition
    I'm using an Ethernet to WiFi bridge on my G5.
    It cost about £10 on eBay from China.
    The weird thing is that it's very fast on MorphOS but on osx it is very slow.
  • »28.06.13 - 17:36
    imax
    Posts: 41 from 2004/9/20
    Hi All !
    I bay this :
    http://www.aliexpress.com/item/Chinapost-VAP11G-RJ45-Mini-WIFI-Bridge-Wireless-Bridge-For-Dreambox-Openbox-Xbox-PS3-PC-Camera-TV/521120958.html
    Wintel required for initialization.
    Macmini work without problems.
    MacBook requires some tricks.
  • »20.07.13 - 06:19
    amiga4001
    Posts: 444 from 2006/11/16
    I am having an issue with the wireless settings.
    If I have a connection and do a shutdown/poweroff , connection is no longer possible.
    Only way to get it back online is choose another network save reboot and choose my own network again reenter the wpa2 key ,then it's back online.
    Anybody else experiencing this kind off behaviour?
  • »20.07.13 - 06:33
    Posts: 2794 from 2006/3/21
    I am the CommVEx show in Las Vegas, displaying MorphOS3.2 on my 17" G4 PowerBook, and AmigaOS4.1.6 on my X1000. I can get my Netgear WG511T wireless NIC to connect to the hotel WLAN, but for some strange reason, it only wants to work for a few minutes, then loses it's wireless connection until I reboot.
    I would like to demonstrate a truly wirelessly connected Amiga-Like laptop to everyone here, but have no idea what the problem might be.
    Any ideas why it is dropping it's wireless connection to the hotel's WLAN?
    Edit: Can only get connected to the hotel's WLAN using DHCP. One of the other users here might be able to set up his equipment to broadcast a different WLAN that I might be able to use a static IP address to connect to, but that has not been accomplished yet. Is DHCP working for my Netgear card while running MorphOS3.2?
    [ Edited by amigadave 26.07.2013 - 21:07 ]
  • »27.07.13 - 05:03
    Intuition
    I had this problem when my router was set to any channel above 11.
    When I set it to use channel 3 (None of my neighbours seemed to be using this channel) the problem went away.
    Hope this helps.
  • »27.07.13 - 05:26
    Unfortunately, I can't change the channel of the hotel's router, so will have to suffer with how it is partially working now, or depend on Tim to set up a secondary WLAN that I can connect to.
  • »27.07.13 - 17:42
    Intuition
    Perhaps you could teher your mobileephone to your Powerbook and use it's internet connection?
  • »27.07.13 - 18:02
    Actually, it seems to be working faster now, so maybe the hotel WLAN is performing better today.
    Are there any other threads here or on other forum sites that suggest any settings I can change to improve wireless performance? It is acceptable now, so I am not worried about changing it too much.
  • »28.07.13 - 03:16
  • ASiegel
    Posts: 1370 from 2003/2/15
    Hope this helps.
    As AmigaDave is in the United States, channels above 11 are generally not being used anywhere as operation of channel 12 and 13 are only allowed in low power modes which dramatically reduce the network range. (The situation is similar in Canada.)
  • »28.07.13 - 09:14
    Having a completely portable MorphOS3.2 is really great! Too bad I only brought one of my two PowerBook batteries with me, and it is the weaker of the two at that, so my battery life is limited to less than an hour.
    My 15" G4 PowerBook just recently one of it's cooling fans fail, and I have not yet completed the replacement of both fans and the heat sink, so this 17" G4 PowerBook is my only working laptop computer at the moment. I noticed that the thermal paste on that model was way too much and I doubt it was cooling well the last few months, which probably contributed to the failure of the fan, as it was probably running more often than it should have been. It would probably be a good idea for any G4 PowerBook owner to disassemble and re-apply the thermal paste on the heat sinks, or Graphics and CPU chips, to lengthen the life of their G4 PowerBook.
  • »28.07.13 - 20:44
    Do any of you know if MorphOS3.2 allows Internet Sharing, like MacOSX does?
    Can I connect any Ethernet cable and serve my wireless Internet to another computer, like I can while running MacOSX?
    Probably would not do it too often, but it might come in handy once in a while.
  • »29.07.13 - 06:47
    Posts: 2985 from 2003/3/5
    Nope. You'd have to install MiamiDX ;)
  • »29.07.13 - 09:37
    So, and I'm sure this has been covered, but if the TL WN550G Atheros based PCI card works under AROS it can be assumed to work under MorphOS?
  • »15.09.13 - 03:25
    Yes.
  • »15.09.13 - 09:54
    Thanks Andreas.
    I decide to move one PowerMac to a location that would be difficult to run Cat5 wiring to.
    So the wireless card become necessary.
    And the adapter I have for my iBook is prohibitively expensive.
  • »15.09.13 - 19:53
    bennymee
    Posts: 132 from 2004/4/14
    Krashan,
    My Cisco Aironet card has just arrived. I've plugged it in, booted the PowerBook, entered network prefs. "wl0" interface has been created automatically. Then I clicked the checkmark to enable it. It loaded list of networks, my one was at the top (probably sorted by signal strength). I selected it, set static IP (I have no DHCP on my LAN), then has been asked for the WPA passphrase. Entered it and voila: wirelessly online in less than a minute
    I just bought a Netgear WG511 v2 and plugged it in in my Powerbook 5.9 with MOS 3.4.
    But nothing happens, no new device, and no lights on the card.
    >As the card does not physically fit my Dell M4300 of Amiga 1200 is it possible to test this >Netgear card for 100% working ?
    Update: the card does work in my Dell M4300 laptop.
    [ Edited by bennymee 21.12.2013 - 20:46 ]
  • »21.12.13 - 20:16
    Quick googling tells that WG511 v2 has either Marvell or Prism chipset, so it's not going to work. Only Atheros chipset based cards are supported.
  • »21.12.13 - 20:58
    bennymee
    jPV,
    OK thanks, I asummed al 511WG xxx had the right chipset.
    I'll search for a new one somewhere....
    [ Edited by bennymee 21.12.2013 - 21:29 ]
  • »21.12.13 - 21:27
  • DH1
    DH1
    Posts: 18 from 2013/12/16
    Pegasos 2 B1
    MorphOS 3.4
    Netgear WG311T wifi card
    Working!
  • »22.12.13 - 00:08
