Atheros 5k MorphOS wifi support
    Krashan
    Posts: 1107 from 2003/6/11
    @rms
    Hi, I wonder why didn't you get one of them:
    http://www.amazon.com/electronics/dp/B0007OWNC2
    which costs 1/4 of the price of the Cisco Aironet Card? (at least price here in Switzerland)
    Seems you have some insane prices in Switzerland. I bought Cisco Aironet in Poland for 10 EUR, postage included. TP-Link TL-WN310 costs roughly the same, as well as 12 EUR is the price of PCI based TL-WN350.
  • »10.06.13 - 04:24
    Ingo
    Posts: 103 from 2004/3/19
    Krashan wrote:
    @rms
    Indeed. i bought the Netgear card for 9,- EUR incl shipping from some onlinestore.
  • »10.06.13 - 07:19
    TrevorDick
    Posts: 130 from 2005/10/12
    [quote]Krashan wrote:
    @rms
    They (and most Amazon sellers, but not all) don't ship to NZ. :-(
    TrevorD
  • »10.06.13 - 19:16
  • rms
    rms
    Posts: 606 from 2004/11/27
    Krashan wrote:
    @rms
    Hi all, sorry explained it wrong! What I wanted to say is that the Cisco Aironet cost here in Switzerland CHF 151.00
    http://shop.rotronic.ch/de/cisco-aironet-802-11a-b-g-wireless-cardbus-adapter-netzwerkadapter/51936097.html?t_Action=SearchSchnell&t_SearchValue=Cisco%20Aironet%20card&t_Sort=&manufacturer=&device=&t_Hier=&t_SubHier=&t_lager=
    and I bought the Netgear card, which I have in use now, for about Euros 20.00
    So I wonder why the Cisco card is so expensive, is the price due because it's faster, better support, etc.
    Regards
    Christoph
  • »11.06.13 - 02:44
    amiga4001
    Posts: 454 from 2006/11/16
    I have lot's off trouble to get online with the new wlan driver..
    I have to do mutliple resets and get into the setup screen to get it online(green light).
    It sometimes even ask for the wma key again after muliple resets.
    If that happens I reenter the key and it's online in a few seconds..strange
    I tried a smc and a netgear 511T both same behaviour.
    If the connection is there it's rocksolid.
  • »11.06.13 - 18:35
    Tony
    Posts: 10 from 2013/6/6
    my network card seems to work.
    where is the configuration for WEP/WPA authentification and passwords ?
  • »12.06.13 - 13:39
    TrevorD
    If you ever need help ordering anything from a re-seller who will not ship to NZ, let me know and I will be glad to order it for you and then ship it to NZ after it arrives at my location here in California.
  • »12.06.13 - 17:25
    TrevorDick
    @amigadave
    Many thanks for the offer. You do know you are in danger of opening Pandora's Box? ;-)
    TrevorD
  • »13.06.13 - 02:45
    Posts: 3287 from 2003/3/5
    Tony wrote:
    In the Network system settings.
  • »13.06.13 - 06:09
    Tony
    Thanks, apparently it doesn't want to connect to WAP (no window appears) whereas it's ok for WPA. Unfortunately i have to connect to WAP.
  • »13.06.13 - 12:58
    ncafferkey
    Posts: 38 from 2006/1/6
    What's WAP?
  • »13.06.13 - 23:49
    If you mean WEP, I haven't had the time to actually test any wlans using it yet, so it may indeed be unsupported.
  • »14.06.13 - 04:08
    Ruud
    Posts: 335 from 2009/2/2
    My old "router" was using WEP which didn't work with MorphOS so I changed it to WPA which of course works fine. Maybe manually editing the config file to include the password might work for WEP?
  • »14.06.13 - 06:13
    ncafferkey
    As a possible work-around to use WEP, here's a sample WEP config that could be added to the wireless prefs file:
    network={
    ssid="mynet2"
    key_mgmt=NONE
    wep_key0=123456789abcdef123456789ab
    wep_tx_keyidx=0
    BTW, why doesn't the code tag preserve indentation here?
  • »14.06.13 - 23:45
    SteveE617
    Posts: 80 from 2013/1/26
    Has anyone tried the USB wireless solutions:
    Belkin F6D3050
    D-Link DWL-G132
    Netgear WG111T/WG111U
    Steve E, BSOE, MIS
    PowerMac G5 | Dual 2.0 Ghz | 2 GB | 32GB CF | 9800XT
    AmigaOne x5000 | 8 GB | 1TB | Radeon 7770HD
  • »19.06.13 - 16:58
    Posts: 1087 from 2004/9/23
    Belkin F6D3050
    D-Link DWL-G132
    Why? It is not mentioned on the hardware support page, so it will not work.
    Geit
  • »19.06.13 - 17:03
    SteveE617
    Totally missed that when I read it....
    Steve E, BSOE, MIS
  • »19.06.13 - 17:35
    Simon
    Posts: 809 from 2008/7/6
    Would be nice tough, a driver that works with poseidon
  • »19.06.13 - 18:54
    Intuition
    Posts: 1116 from 2013/5/24
    So am I right in assuming that when my G5 arrives I will only be able to use ethernet because USB wifi adapters are currently unsupported?
    I'm not complaining, I just want to clarify the status of wifi support on G5 machines.
  • »19.06.13 - 20:45
    Posts: 12528 from 2003/5/22
    Yes, you are. You could still use a WLAN Ethernet bridge though. That's what I do with my Mac mini G4.
  • »19.06.13 - 20:58
    None of this bothers me on a desktop because I'm not adverse to running cat5 cables to each computer desk.
    But with laptops its really asnnoying. And the iBooks wifi is never likely to be supported.
    We really could use a good USB solution.
  • »19.06.13 - 21:23
    Posts: 2212 from 2003/2/24
    Andreas_Wolf,
    Atheros 5000 based PCI cards won't work on G5 machines? Don't they have compatible PCI bus or why?
  • »20.06.13 - 03:16
    Intuition
    Thanks, that's what I'll do as running cable from my office to downstairs where my router sits will be a pain.
  • »20.06.13 - 07:59
    Not with MorphOS 3.2 apparently:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=9234&forum=3&start=16
    I don't know what the reason for reported non-support of PCI slots in PowerMac G5 is.
  • »20.06.13 - 09:22
  • rNx
    rNx
    Posts: 35 from 2010/10/26
    Web Caster FT-STC-Na/g works, but only with static IP.
  • »28.06.13 - 13:40
