Atheros 5k MorphOS wifi support
    Posts: 537 from 2003/4/11
    stephen_robinson schrieb:
    Is that Airport and/or Airport Extreme?
    Not the original Airport cards which don't use Broadcom chips at all definitely, so either "AirPort Extreme" or "AirForce One 54g"
    You can use showconfig for example to check if a supported Broadcom card shows up in the boards section, it should be one of Vendor $14E4, either Device $4320 or Device $4318.
  • »19.04.14 - 21:19
    stephen_robinson
    Posts: 746 from 2007/4/22
    Hmm, a quick check on everymac.com show that the final ibooks use airport extreme, as did the 1.5 mac mini, and indeed the 1.42Mhz G4 and as far as I can tell all the G5s...
    So, looking good on that point then!
    (I'll have a check to see what my various Macs say re: Vender ID tomorrow, when I'm less dr*nk)
    [ Edited by stephen_robinson 19.04.2014 - 21:42 ]
  • »19.04.14 - 21:40
    Posts: 12080 from 2003/5/22
    Yes, the internal WiFi, if installed, is of the AirPort Extreme kind in the following MorphOS-supported PPC Macs:
    - eMac: all
    - iBook G4: all
    - PowerBook G4 Aluminum: all
    - Mac mini G4: all
    - PowerMac G4: FW800
    - PowerMac G5: all
  • »20.04.14 - 00:05
    stephen_robinson
    Right, on my 15" Powerbook 1.67:-
    Vendor $14E4 Device $4318 Broadcom Corporation, BCM4318 [AirForce One 54g] 802.11g Wireless LAN Controller
    :irritating dancing banana:
  • »20.04.14 - 07:38
    clr666
    Posts: 85 from 2008/7/8
    MorphOS 3.6 will be released in this year?
    P.S. My Mini & PB so much happy :D
    [ Edited by clr666 20.04.2014 - 14:19 ]
    _______________
    wintel free
  • »20.04.14 - 09:18
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=11&topic_id=8931&start=106
  • »20.04.14 - 14:05
    stephen_robinson
    Still haven't sobered up enough to check the others, but my Unsupported Quad G5 2.5's apple own wireless network card is:
    Wireless Card Type: AirPort Extreme (0x14E4, 0x4318)
    Wireless Card Locale: Unknown
    Wireless Card Firmware Version: Broadcom BCM43xx 1.0 (4.170.25.8)
    So another good reason to support them...
    Just sayin'
  • »21.04.14 - 18:03
    diezi7
    Posts: 167 from 2005/7/26
    Hi guys,
    I'm willing to know about wifi cards cause my PowerMac
    does not accept one Airport Extreme card I've got here lying
    around (MDD FW400).
    Do any of the mentioned cards work over the
    PCMCIA slot on PowerMac G4.
    Are Airport cards supported? (not extreme)
    Would a PCI Wifi card Airport compatible be recognized and work?
    And too, if there's some concrete model of PCI Wifi card working fine.
    Thx
    Pegasos II G4 (not working)
    Powerbook G4 1.0 15"
  • »01.10.14 - 11:03
    > Do any of the mentioned cards work over the PCMCIA slot on PowerMac G4.
    See comment #23 in this thread.
    No.
    See that thread:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6042&forum=11
    This thread has several examples.
  • »01.10.14 - 13:57
    diezi7
    Thanks for the help.
  • »01.10.14 - 22:12
