Xbox 360 controller driver testers wanted
    _DaNi_
    Posts: 154 from 2010/5/4
    IĀ grab a snapshot, i think the class not work on poseidon, here the picture:
    http://www.subirimagenes.com/otros-grab-7875896.html
  • »27.07.12 - 18:19
    Posts: 3249 from 2003/3/5
    Please doubleclick on that device and give me the Product ID field value. What device did you connect exactly? That's not a 360 Wireless adapter for sure.
  • »27.07.12 - 18:32
    _DaNi_
    i uploaded a grab with the device information, the wireless is the xbox 360 wireless official from microsoft!
    http://www.subirimagenes.com/otros-grab-7876021.html
  • »27.07.12 - 18:46
    Looks like there are two revisions of the device floating around. Please redownload the driver (same url), install it and reboot to make sure it was flushed. It will hopefully work now.
  • »27.07.12 - 19:39
    _DaNi_
    now works, poseidon is running now the xbox 360 wireless and syncronize with the xbox 360 joypad without problems :)
  • »27.07.12 - 21:23
    vulture
    Posts: 195 from 2008/2/4
    @jacadcaps
    the new driver works for me too as it has the same pid as Dani's. Only peculiar thing, a few seconds after the gamepad led is stabilized at position 1, it starts blinking again. But it still gives the same indications under logtool, so it seems to be working ok.
    [ Edited by vulture 28.07.2012 - 09:14 ]
  • »28.07.12 - 05:12
    XDelusion
    Posts: 602 from 2010/10/27
    I tried this last night with my USB Mad Catz XBOX 360 Controller clone, but to no avail. I could not get the class to bind.
    I see that there is an updated download and more technical info on the page today so I'll go home and have another shot tonight.
  • »28.07.12 - 15:27
    If it does not bind with the most recent version of the driver, please let me know the vendor and product ids of the device.
  • »28.07.12 - 16:37
    XDelusion
    Sure thing!
  • »28.07.12 - 16:51
    XDelusion
    I forgot to download LogTool last time, but in the mean time I was still unable to force bind with your latest upload.
    here's a screen shot:
    http://www.mediafire.com/view/?9kusma2tyycvnyq#
  • »29.07.12 - 21:42
    Redownload and try again. Hard to say whether it's going to work or not though - it seems quite different from the others.
  • »29.07.12 - 22:34
    Simon
    Posts: 809 from 2008/7/6
    I wonder, will it be possible to use all buttons ? I know I still have problems assigning all buttons on a PS1 controller ? Or is it just me who can't properly set up Poseidon ? And if so, what is the difference with this driver if all buttons are assigned or are there lesser buttons on an XBOX360 pad ?
  • »30.07.12 - 04:15
    Yes, it will eventually be possible to use all buttons, but only in games that'll be updated to use the new API. lowlevel.library can't have as many inputs as these pads have.
  • »30.07.12 - 09:34
    _DaNi_
    i am updating with stefkos the OpenBOR is possible add the API for support the wireless controler with OpenBOR? Give me info about this
    Thanks
  • »30.07.12 - 17:12
    Definitely, the only problem is that the API is still in the works. But since stefkos has access to current MorphOS betas, I'm pretty sure he'll be able to add the support for this as soon as the API & driver are mature enough.
  • »30.07.12 - 17:48
    _DaNi_
    aja, good news i wait :)
  • »30.07.12 - 18:02
    Jupp3
    Posts: 1193 from 2003/2/24
    _DaNi_,
    I assume that will be "a generic API for all joysticks (and joystick-like) devices", rather than "Only for Xbox360 controllers", as that wouldn't really make much sense :-)
  • »30.07.12 - 18:22
    Updated http://dreamolers.binaryriot.org/priv/xbox.lha again. The only change is that the led 1 on the wired usb controller should be lit now. Please let me know if this works if you've got one.
  • »13.08.12 - 20:49
    vulture
    Doesn't work with my controller, all leds are just blinking. Here's the info from poseidon:
    Product Name: Joytech 360 pad
    Product ID: 48879 (0xBEEF)
    Manufacturer: Joytech T2
    Vendor: 5678 (=0x162E)
    unknown
    Serial #: A568741
    No response at logtool, tried to force the binding as well, but still no response.
  • »15.08.12 - 12:56
    @vulture
    Redownload and try again :)
  • »16.08.12 - 00:13
    vulture
    Downloaded the new class, still the same result.
  • »16.08.12 - 00:26
    Sure you rebooted/flushed the old class from mem? It should at least bind to the device now.
  • »16.08.12 - 11:06
    vulture
    I rebooted the system, of course. I really get no bind. Would you like me to make a snapshot? Maybe there's something going on that I don't describe correctly.
  • »16.08.12 - 14:52
    A screenshot of the information window that appears when you doubleclick the pad in the Devices view in USB prefs would be handy indeed.
  • »17.08.12 - 10:02
    vulture
    Here:  :-)
    http://postimage.org/image/4klo8hnwr/
    http://postimage.org/image/4aifo15kt/
    [ Edited by vulture 17.08.2012 - 17:44 ]
  • »17.08.12 - 13:42
