Raspberry Pi
    outlawal2
    Posts: 87 from 2009/5/6
    And as I have stated before... As soon as MorphOS becomes Linux or a Linux derivative I walk away from it completely.
    No, just no.
    "Pride is a poor substitute for intelligence." Quote from Rambo...
  • »06.11.19 - 17:56
    Posts: 12079 from 2003/5/22
    Then you might be pleased to hear that MorphOS (or AROS for that matter) wouldn't magically turn into Linux or a Linux derivative just by being ported to the Raspberry Pi ;-)
  • »06.11.19 - 20:14
    outlawal2
    I understand that, but if you read what AmigaDave said then you will understand why I said that.
    @Amigadave
    "And since they have already stated that they will most likely loose backward compatibility with Amiga 68k software during that change, why not make a complete jump with a new kernel that will also allow for the use of many existing drivers, by using an existing Linux kernel and building a new MorphOS on top of it.
    Then we could use the existing Linux based UAE for backward compatibility with Amiga programs. I think this is the only feasible way forward that would allow greater flexibility, and possibly the MorphOS Dev. Team could even make it so we could run any Linux program with little or even zero changes, or recompiling, from this new version of MorphOS for ARM."
  • »06.11.19 - 21:22
    Sorry, it wasn't obvious that your comment #99 was an answer to 6-year old comment #86.
  • »06.11.19 - 23:01
    Posts: 5 from 2022/1/11
    If this is not future for Amiga and MorphOS operating sytem, I do not know what it is.
    https://www.raspberrypi.com/products/raspberry-pi-400/
    Cheap affordable hardware, ARM based, single platform to develop drivers for. Enough power for low footprint OS.
    Power will grow as times goes by. large user base.
    All in all, I think that is the way to go.
    [ Edited by Lokz 13.01.2022 - 14:12 ]
  • »13.01.22 - 14:11
