Raspberry Pi
    Posts: 2726 from 2003/2/24
    @Miky060
    If you're going ARM with MorphOS, why not aim for the Efika MX instead? (Edit 3: Then you would also get access to the Netbook practically for free (it's virtually the same HW), Efika SmartBook going *MorphBook*! :-P ;-)) Or focusing on the upcoming Efika based on i.MX6 (it's not like a port would happen overnight anyway)?
    A little comparison (any claims about the Raspberry PI, in numbers or words, is a cut/paste from the wikipedia page and other online sources):
    Memory:
    OK, much memory is pleasant to have, but in these kinds of applications it's a trade-off with cost, and 512MB memory actually gets you quite far in most cases where this HW will be used (often more than enough, especially in a MorphOS context).
    And the Raspberry has *half* of this (and half of this is reserved for the GPU), so you are down to Efika 5200 levels, meaning special version of Odyssey, etc to handle this limitations...
    Processor:
    The Raspberry's BCM2835:
    - is ARM11, in other words ARMv6, which due to its age is no longer supported by several popular Linux distros, including Ubuntu.
    - Level 2 Cache is 128 KB, used primarily by the GPU, not the CPU
    - It's only 1.25 DMIPS/MHz
    - It's only clocked at 700MHz.
    The i.MX51 in the Efika MX:
    - is ARMv7, IMHO MorphOS would be better off with this ISA instead, since all Cortex-A8, A9 and A15 uses this ISA, and future 64-bit ARMv8 CPU's will be backwards (ARMv7) compatible.
    - Has 256KB L2 cache
    - Has NEON SIMD (think Altivec, but not quite as powerful)
    - 2.0 DMIPS/MHz
    - is clocked at 800MHz.
    General differencies:
    The Efika MX:
    - Has WiFI (and also Ethernet of course)
    - Has a 8GB Internal SSD, with a pretty decent performance actually
    - Audio jacks for headset (yes, including audio *IN*)
    - Has a built-in speaker
    - Comes in a real case
    - Comes with power supply and cables (contents of the package)
    The Raspberry:
    - Nope!
    What would a realistic assumption be about the differences in the overall desktop use performance, between the Raspberry and the Efika, adding together the combined effect of the lower clock frequency, the much lower DMIPS/MHz, the lower RAM, the lower L2 cache and no NEON? The Raspberry having half of Efikas performance? You tell me...
    (EDIT: 1.25 * 700 = 875 DMIPS, vs. 2 * 800 = 1600 DMIPS, about half there already, before even adding the impact of any of the other variables)
    While I actually understands that a price tag at a quarter of the Efika MX would seem cool at a first glance, it's also worth noting that the Raspberry falls very short of the Efika's level of performance, specification, functionality and usability. In fact, I think this could be too limited to actually be useful for real. It's more of a toy. The final version of this could possibly be sold as a naked PCB at a similar price, or at least not very far off, and it would offer a lot more than the Raspberry. But the question is - Why?
    I mean, if you add the very *basics* to the Raspberry PI in order to get it up and running, like...
    Case: ~$15 to $45
    8 GB storage: ~$20
    Power cables and transformer: ~$20 (I don't know what they charged, but these kind of things usually costs about this, or a bit more)
    ...and you aren't at $35 anymore, but have been crawling quite far up in Efika MX price range (almost all the way, but not in performance, features and usability). There are hidden costs! Many a little makes a mickle. And the Efika MX is still *very low cost*, not particularly expensive at all! :-)
    (EDIT 2: The Raspberry Pi has a lot of focus though, a lot of attention, which could mean something to an OS who's main strengths are low footprint and resource efficiency, but if "$35" is the key reason to your Raspberry purchase, chances are that €111 won't be that appealing)
    [ Edited by takemehomegrandma 17.03.2012 - 09:17 ]
  • »17.03.12 - 07:16
    Posts: 12408 from 2003/5/22
    > If I have understood the specifications of the Raspberry Pi correctly,
    > it could be as fast, or faster than the Efika 5200b
    True. If the Dhrystone benchmark is anything to go by, the Raspberry Pi's 700 MHz ARM1176 core is 15% faster than the Efika 5200B's 400 MHz e300c0 core.
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=7675&start=104
    > it comes with only 256mb of RAM (and possibly only 128mb or RAM in
    > some circumsances) and that this small amount of RAM is shared
    > between the CPU and GPU.
    AFAIK, all Raspberry Pi models come with 256 MiB of shared RAM, of which the user can dedicate either 32, 64 or 128 MiB to the GPU. That leaves either 224, 192 or 128 MiB as the main RAM.
    > When running 1080p video playback, I would imagine that the GPU
    > might take a large chunk of this shared memory
    According to http://en.wikipedia.org/wiki/Raspberry_Pi#Specifications ("Note 2"), 1080p video playback should be possible with 64 MiB dedicated to the GPU, leaving 192 MiB as the main RAM.
  • »17.03.12 - 07:54
    scrAb_
    Posts: 62 from 2010/7/23
    @TMHG
    > If you're going ARM, why not aim for the Efika MX instead? Or focusing on the upcoming Efika based on i.MX6 (it's not like a port would happen overnight anyway)?
    I'm with you on this.
    I'm just looking at Sabre Lite Dev Board specs...
    MacMini@1.5Ghz 1GB/DualBoot Morphos3.1/DebianPPC - Efika MX sb
    PowerBook 5,9
  • »17.03.12 - 08:12
    > will be used [...]. And the Raspberry has *half* of this (and half of
    Actually, the English Wikipedia page says that the VRAM can be set to half, quarter or eighth of the shared RAM.
  • »17.03.12 - 09:12
    Yeah, my post here was largely a cut/paste from a post I did in a thread at amiga.org the 3rd of March, and the wiki-page has been updated since then, sorry. Still too little RAM though... ;-)
  • »17.03.12 - 10:36
    From your link:
    "The minimum amount of memory that can be allocated to the GPU is 32 MB"
    "The available memory, 128–224 MiB, after subtracting 32–128 MiB for graphics memory"
    "The 128–224 MiB of available memory"
  • »17.03.12 - 11:11
    OK, maybe I didn't read it carefully enough ;-) (or there were other changes as well or I linked wrong, or whatever, can't be bothered to check)... My point remains though, 256MB is too little RAM, and while an Efika MX systems does cost a little bit more, it offers much, much more, not only in RAM, but also in Features and Performance, and it also comes as a Netbook! :-)
  • »17.03.12 - 11:51
    Yes, that's it I guess.
    > or I linked wrong
    No, you correctly linked to the version that was the current one when you made your posting on amiga.org.
  • »17.03.12 - 12:17
    Don't get me wrong,
    I find the device interesting as a Linux platform.
    I just don't see that it would bring much to our OS.
  • »17.03.12 - 15:34
    minator
    Posts: 371 from 2003/3/28
    Jim,
    How about thousands of people who like trying things like small boards or ...alternative operating systems?
  • »17.03.12 - 16:43
    minator,
    If these little ARM based Linux doohickeys get any small I'm going to need magnification to find them.
  • »17.03.12 - 16:54
    minator,
    Yes, if hundreds of thousands of people are going to buy one of these things and then find that they don't like the only operating system currently ported to it, they might be very interested in looking at MorphOS, which could bring us more MorphOS users and developers.
    I don't know if the potential prospect of gaining a few new MorphOS users and possibly 3 to 10 new MorphOS developers by doing a port of MorphOS to the Raspberry Pi is worth the effort it would take to complete the port, unless the MorphOS Dev. Team has already decided that they want to port to the ARM architecture regardless of the Raspberry Pi port or not. I don't know how long such a port would take, because timing of getting MorphOS released on the Raspberry Pi would be a key factor to the success of getting many owners to try MorphOS. If the port of MorphOS could not be completed quick enough, the initial "Buzz" around the Raspberry Pi could die down by then and it would be much harder to get enough Raspberry Pi owners to notice and want to try MorphOS on their new "Toy".
    Personally, I don't think the "Buzz" around the Raspberry Pi will be as strong as it is today, a year from now, or two years from now.
  • »17.03.12 - 17:14
    kamelito
    Posts: 103 from 2011/9/21
    The Raspberry PI will evolve and is tight to education in the UK, it might become the new BBC micro.
    More than 200 000 registered to the RS site to have one and it's not yet the education market which will be for September. I'll buy one the Aros guys are already targeting it.
    Kamel
  • »18.03.12 - 06:54
    Miky060
    Posts: 694 from 2003/2/24
    @takemehomegrandma
    Yes, you're right, the Efika MX seems more interesting, but all this is just to speak and discuss, no concrete hopes in my post. MOS Team is too little and with real job/life for every member and every porting would take too much time (taken from other more important goals..) to make a port possible. Moreover the eventual port would come out as something already old when finished.
    If I can just dreaam I would see MOS ported to one of these little all-in-one computers and run much smoother than any linux distro. The MOS licence for that kind of hardware should cost much less than the actual price for desktops/NoteBooks. Still better if some Society (maybe Genesi) would pay the team to port MOS on the new hardware. Obviously in this dream MorphOS should bring to that hardware something more (not just speed) that a Linux distro can already do. In this dream all this would bring some more money to morphos developers and more visibility and popularity to our OS that in my opinion has big potential in mobile devices.
    But, hey, this is just a dream, reality is another one.
  • »18.03.12 - 10:40
    @ Miky060
    You are right in that the Raspberry Pi has a huge spotlight shining on them right now, they have had media coverage, and everyone is looking. Can result in a considerable momentum. If MorphOS would strip away all Amiga Legacy stuff (the 68k emulator/JIT-emulator, all the Amiga Legacy stuff, and any "glue code" in the system that may be there to helps certain individual legacy 68k programs to run better. When the need for Amiga backwards compatibility is gone, a recompile of the OS could possibly be done quite fast. Compile the code to ARM, make drivers, support the HW. Would be a very limited verion of MorphOS, something reminding more of AROS, but more usable. Call it MorphOS Light, and sell it to the Raspberry Pi community for $35, bundled with pre-installed set of software that will make it fun and usefull, and showing off what MorphOS is about. A Cheap way to "spread the word", build a trade mark and some brand recognition for future endeavors on other platforms.
  • »18.03.12 - 22:38
    Crumb
    Posts: 736 from 2003/2/24
    Raspeberry Pi only has 256MB. That's not enough for intensive OWB use IMHO. EfikaMX has 512MB and could be more useful.
  • »20.03.12 - 12:31
    MarK
    Posts: 641 from 2004/1/25
    it's a reason to reduce memory requirements of OWB... :)
    bye, MarK.
  • »23.03.12 - 06:31
    ausPPC
    Posts: 543 from 2007/8/6
    Is there an AROS for ARM devices that isn't Linux hosted?
  • »19.08.12 - 20:42
    No.
    http://en.wikibooks.org/wiki/Aros/Platforms/ARM_support
  • »20.08.12 - 05:59
    Does this news:
    http://www.raspberrypi.org/archives/2221
    plus the news that the Raspberry Pi can now be software over-clocked to 800MHz to 1GHz make the Raspberry Pi any more attractive as a possible low end, low power, extremely low price, target for MorphOS4.x, IF/WHEN MorphOS ever gets ported to the ARM architecture?
    I would not want the Raspberry Pi to be the only ARM hardware that is supported, because there are many more ARM boards that have more power & speed, and if the MorphOS Dev. Team is going to go with a port to the ARM architecture, I am sure many/most users who are interested in the ARM port will want to see MorphOS4.x running on the most powerful ARM hardware that is available, and not the weak Raspberry Pi.
    What I wonder though, is how the performance of the Raspberry Pi compares to the Efika 5200b, and if the Open Source driver for the GPU on the Raspberry Pi will make running MorphOS4.x a good experience? Probably too early for anyone to tell, but an interesting question, and the only reason right now that I would be interested in a port of MorphOS to the ARM architecture.
  • »21.11.12 - 01:34
    Krashan
    Posts: 1107 from 2003/6/11
    The question is why Raspberry Pi people don't just make detailed technical documentation available? In my opinion they do not care about any other system than Linux. It is possible that market of really free (in the sense of freedom of information) ARM hardware will grow, but we need a few years more.
  • »21.11.12 - 05:28
    Henes
    Posts: 507 from 2003/6/14
    @amigadave
    This is sadly a totally bullshit announcement. If you read the source code for this pseudo open-source driver, you can see it's just a wrapper for a closed-source binary blob where the real driver code is.
    And there is no documentation anyway.
    So, nothing changed and whoever is responsible for this should be ashamed for life.
  • »21.11.12 - 08:02
    My guess is that this is a restriction imposed by Broadcom.
  • »21.11.12 - 09:41
    Henes wrote:,
    @amigadave
    That is really disappointing! The person responsible for the announcement should be publicly flogged for posting misinformation like this and getting the hopes on non-technical people like me up in the air.
  • »21.11.12 - 19:20
