Moderator
Posts: 461 from 2003/7/22
Quote:Divinity wrote:
@amigadave
no, There is NO important differences between 8500, 9000, 9200 and 9250, while there is BIG difference with newer 9600, 9700, 9800
All my tests are here
http://amiga.ikirsector.it/forum/viewtopic.php?f=40&t=13185
http://amiga.ikirsector.it/forum/viewtopic.php?f=40&t=14377
Yes, but you never tested the 8500 128MB 128bit (a "mythical" beast), that is the fastest card currently supported in MorphOS, nor the 8500LE/9100 (different names, same board) which is the second one. If you look at the performances on paper there is some difference, and there was in MorphOS as well up to the relase 1.4.5. With 2.0 the drivers for the 92x0 gained more in performance than the 8500, so the gap was almost closed. But still, if the 8500 was exploited in MorphOS as much as the 9250 is, you would see some difference...
Kind regards,
Andrea
