Posts: 12085 from 2003/5/22
> This would still require the development team to work on additional
> chipsets/hardware that I doubt they'd want to be troubled with.
Again, as you seem to have missed my last answer to you: PowerMac3,1 to PowerMac3,3 *do have* MPC7400. And as MorphOS is announced for these machines we can safely assume that the MorphOS Team does want to be troubled with their hardware.
> Some of the machines that use this Processor even appear to have AGP slots
Yes, that's the whole point of it in terms of MorphOS. All PowerMac G4 generations with AGP are supposed to be supported (but probably not every model of each generation, see
there). I cannot believe that you've forgotten that:
https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6684&forum=11&post_id=75390#75390
> although I did check what type yet
We (as in you and me) discussed that at lengths already:
https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7261&forum=11&post_id=75095#75095
> The PCI slot equipped 7400s could still be useful with a supported PCI graphics card.
According to the MorphOS Team the PCI based PowerMac G4 generation (
PowerMac1,2, "Yikes") will not be supported.
> I've never considered looking back at the older hardware.
I think you did, but forgot, which is frightening ;-)
> There's a lot of systems that could be supported if the developers had the
> time for them all.
All PowerMac G4 generations except the very first one are AGP based.
