Powermac supported devices
    Simon
    Posts: 809 from 2008/7/6
    What kind of G4 is used in the G4 1.4 minimac ?
  • »03.10.10 - 18:31
    Divinity
    Posts: 498 from 2009/9/8
    @Oepabakkes
    7447a
  • »03.10.10 - 18:59
    Posts: 12086 from 2003/5/22
    > 7447a
    It's rather the (inofficial) 7447B, which is often imprecisely subsumed as 7447A. See:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6560&forum=11&start=7
  • »03.10.10 - 21:05
    > I've modified it.
    Thanks.
    > there seems to be no hard and fast information (at least none referenced)
    > wrt which models have 7410/7450 processors
    It's in a posting of mine which you already replied to:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7332&forum=11&post_id=76248#76248
    You just have to ignore the "(not) supported" classification as it is based on false information previously provided by pega-1. The assignment of exact G4 type(s) to specific PowerMac G4 models is genuine though. My source for this has been:
    http://www.everymac.com/systems/apple/powermac_g4/index-powermac-g4.html
    > I doubt that anyone will take it as gospel.
    I hope that after the recent modification it's safe to take it as that ;-)
  • »03.10.10 - 21:22
    Everblue
    Posts: 167 from 2004/1/6
    Any news on PowerMac support dates? I have been waiting for this one since January :P
  • »05.10.10 - 06:51
    stephen_robinson
    Posts: 746 from 2007/4/22
    I notice a lot of Powerbooks in that last PowerDev meeting, will this be part of the 2.6 release?
  • »05.10.10 - 07:10
    analogkid
    Posts: 661 from 2004/11/3
    @stephen_robinson
    You mean PowerDev at Geit? It were two Powerbooks, IIRC.
    And no, PB support won't be part of MorphOS 2.6 ...
  • »05.10.10 - 08:11
    Simon
    So if a Sonnet 1.4Ghz upgrade uses the 7447a or b it's safe to assume it will work with MorphOS ?
  • »05.10.10 - 08:54
    Bifford
    Posts: 275 from 2003/2/24
    Do you folks have any idea if and when the GeForce 4MX will be supported? This is what my MDD PowerMac G4 has inside it.
    Sam / Bifford
    Bifford the Youngest
  • »14.10.10 - 22:04
    Posts: 423 from 2005/4/9
    probably and most likely never. (maybe it happens if nvidia decides to release the source/documentation for their drivers/cards, but then it still wont be 100%:)
    so you better get a supported card for your mac (r7500-9250, or r9500-9800 with no 3d support) or flash a card for the pc with mac bios (cheaper but more difficult indeed:)
    [ Edited by sadddam on 2010/10/15 0:40 ]
    zx.spectrum@3.5
  • »14.10.10 - 22:39
    boot_wb
    Posts: 874 from 2007/4/9
    As there are a few inconsistencies between the expected (pre-release) hardware support information and actual (release) hardware support information, I recommend visiting the MorphOS-team website for correct information.
    This thread served its purpose - it was intended to get information together prior to release: to allow potential users to make informed choices based on information available at the time, and to take the pressure off developers being asked for the same information ad nauseum.
    Now that MorphOS 2,6 has been released, the proper place to find such information is MorphOS-Team website.
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »16.10.10 - 11:24
