XBox 360 Controller
  • JJ
    JJ
    Posts: 147 from 2010/7/7
    Thats why I got the xbox batteryacks that you can charge while your playing :)
    We don't stop playing because we grow old; we grow old because we stop playing. - George Bernard Shaw
    Xbox Live: S0ulA55a551n2
  • »14.01.11 - 16:22
    Posts: 423 from 2005/4/9
    and how would that be different to a wired one then?:D
    (assuming you charge it with an usb cable connected.)
    zx.spectrum@3.5
  • »14.01.11 - 16:27
  • JJ
    JJ
    Sorry should have quoted that was in reply to wirelss controllers eating through batts and running out half way through a game.
    Charge and play solves all those problems :)
  • »14.01.11 - 16:31
    yeah got that. i just told that wireless charging with usb while playing = wired controller, so no pro for wireless only cons:) means only using wired controller solves all problems:)
    zx.spectrum@3.5
  • »14.01.11 - 17:20
  • JJ
    JJ
    Sorry for the thread resurrection been away from this site and morphoos for quite some time . Was there ever any progress on this
  • »04.09.14 - 21:05
    Posts: 12074 from 2003/5/22
    "Classes/USB/Xbox360 [NEW]
    Supports Xbox 360 wired and wireless pads (using a PC USB adapter) using the new sensors.library based input API. Handles all buttons, LEDs, battery and the rumble motors.
    http://www.morphos-team.net/releasenotes/3.2
    More threads on the topic:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=10096&forum=11&start=4
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=10058&forum=10
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=9951&forum=10&start=6
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=9854&forum=11
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=9781&forum=11&start=5
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=9727&forum=12
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=8639&forum=11&start=58
  • »04.09.14 - 21:17
  • JJ
    JJ
    Thought I remembered something. Thanks
  • »04.09.14 - 21:51
    Yasu
    Posts: 1724 from 2012/3/22
    Can someone recommend a game which use this controller?
    My MorphOS blog
  • »01.01.15 - 23:56
    Cego
    Posts: 712 from 2006/5/28
    Speeddreams and Torcs afaik
  • »02.01.15 - 01:23
    Posts: 2971 from 2003/3/5
    Actually, all games will now work with the xbox controller - due to the lowlevel.library emulation that was added in MorphOS 3.6.
  • »02.01.15 - 08:31
    Yasu
    @Cego
    Thanks!
    @jacadcaps
    Hmm, I only tried Battle Squadron and while I can use the controller in the menu it doesn't work at all in the game. Maybe it's the game though. I will try it with Speed Dreams.
    My MorphOS blog
  • »02.01.15 - 12:47
    Cego
    Just tried to plug in my XBOX 360 wired controller, but Trident will just give a "?" in "Devices".
    Seems that not all 360 controllers are supported...
  • »03.06.20 - 17:37
    Is the xbox360.class loaded? What's the PID/VID of the device?
  • »03.06.20 - 17:41
    Cego
    Theres no class loaded, just "None".
    Product ID: 654 (=0x028E)
    Vendor: 1118 (=0x045E) Microsoft Corp.
    When I open up "Information", it'll show up four Interfaces:
    0/0 Vendor Interface (0)
    1/0 Vendor Interace (1)
    2/0 Vendor Interface (2)
    3/0 Xbox Security Method 3, Version 1.00, © 2005 Microsoft...
  • »03.06.20 - 17:48
    Well, you need to Dir Scan in USB/Classes then. The pad is supported.
  • »03.06.20 - 17:58
    Cego
    thanks! that fixed the problem. But how could this be in the first place? This is a fresh install
  • »03.06.20 - 18:01
    Which is exactly why it didn't work. The class isn't enabled in the default configuration.
  • »03.06.20 - 18:05
    beworld
    Posts: 590 from 2010/2/10
    hi,
    i bought a beautifull "Gamepad For Xbox 360 Joystick Wireless Bluetooth"
    here : https://www.aliexpress.com/item/4000910822157.html
    Ok it's a beautifull but a crap made china ;-)
    So MoprhOS see it :
    ProductID 0x028E, Vendor 0x045E, Product Version 0114 Manufacturer Holtek
    I see xbox360.class in Trident no problem.
    Sensors see all sensors !! but nothing work :-) no event, no button etc
    (Jacadcaps, i test also with gamepadlib, i see aonly all sensors but no event.)
    Any little ideas ? or I throw this thing directly in the trash?
    Thanks
    IMac G5 2.1,PowerBook G4 1.5,MacMini 1.5, PowerMac G5 2.7 died !!!
    My MOS ports
  • »11.07.20 - 14:54
    Hard to say why it doesn't work. Did you connect it via a USB cable?
    I can prepare a debug version of the xbox360 class and we can try to debug this...
  • »11.07.20 - 19:03
    beworld
    Not possible to connect via USB....
    if you wan and have little time, i can test with debug version of xbox360.
    I test it on Windows = ok
    My MOS ports
  • »11.07.20 - 19:15
    You can use something like https://www.aliexpress.com/item/32995704386.html to connect it via USB... That's why I wanted to make sure.
  • »11.07.20 - 19:34
    Zetec-s
    Posts: 192 from 2008/7/10
    I have been given one of the below for Christmas and however hard I try I cannot get it to work under MorphOS.
    https://www.amazon.co.uk/Etpark-Controller-Joystick-Improved-Ergonomic-black/dp/B07Q4SD1NB/ref=sr_1_10?dchild=1&keywords=xbox+360+controller&qid=1608931870&sr=8-10
    Product version: 0110
    Vendor: 1118 (=0x04SE)
    Manufacturer: Microsoft
    Once I do a DirScan the controller stops flashing and appears to settle down but I cannot get it to register any movement in any game I try.
    Do I need to go for an Official Microsoft or am I missing something?
    Any help much appreciated.
  • »25.12.20 - 21:41
    Try https://tunkki.dk/~jaca/waitandhid to confirm whether it's working or not. It could be that it needs some additional setup step which the MorphOS driver does not perform.
  • »26.12.20 - 00:01
    lordcoxis
    Posts: 19 from 2018/10/14
    I am using an "Xbox Controller + Cable for Windows":
    Product ID: 746 (=0x02EA)
    Product version: 0301
    This is a cheap-ish controller and is connected directly using the provided USB cable. It is detected as "Controller" in Trident (using xbox360.class), but pressing "Settings" does nothing. I also can't seem to get it to work with anything (although I'm 99% sure it did work in a previous MorphOS version - using 3.14 now), but "waitandhid" does detect it properly (all buttons work, etc). So, my questions are:
    1. Should pressing "Settings" on the device open up the settings page?
    2. Should lowlevel.library software work with this driver?
    Thanks in advance.
  • »26.12.20 - 09:52
    Zetec-s
    Thanks jacadcaps, that little app was really useful.
    All the entries appear to register fine, apart from the right shoulder button that shows permanently as active (i.e. registers as 1).
    I subsequently tried the controller under Windows and WinUAE (its the only games I have on my Windows laptop) and the right shoulder button isn't registering under WinUAE either and definitely wasn't working in Gloom or WormsDC.
    Would this potentially be the reason why it is not working at all under MorphOS? Obviously it doesn't work correctly, but not sure if to order another or try something completely different.
  • »26.12.20 - 11:28
