MorphOS on Apple G4 Cube?
    CountRaven
    Posts: 566 from 2007/12/11
    Hello all,
    Any news about the port of morphos 3 ?
    Any chance to have sound supported for the cube ? autherwise i probably sell it.
    Thanks for answer.
    Regards.
    Is it sound support the only problem? Cause I think MorphOS does not even run in Cube. Or have I missed something?
  • »10.02.12 - 04:19
    robinson
    Posts: 5 from 2011/9/4
    Morphos runs on the cube even networking and watching youtube video are possible only sound is missing.
    unfortunately sound will never works, i asked frank Mariak and he answered me : " Cube (and it's USB audio) won't get official support with 3.0,
    unfortunately. First of all, I don't have one and on a second thought, the
    USB driver doesn't support the special transfer mode that is required for
    USB audio.
    Maybe at some later point but definitely not around the corner ...."
    Regards.
  • »10.02.12 - 06:43
    Posts: 12078 from 2003/5/22
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=11&topic_id=6835&start=21
  • »10.02.12 - 06:54
    Posts: 537 from 2003/4/11
    CountRaven schrieb:
    Hello all,
    Thanks for answer.
    Regards.
    Just to revive some old thread in context of the recent MorphOS3.4 update, PowerMac 5,1 Cube is supported even though it is not officially mentioned anywhere and there was even some fix in the latest update related to some networking setup issue. With MorphOS 3.4, it should basically work OOTB.
    There is indeed the remaining issue of missing usb audio support, though.
  • »25.12.13 - 06:40
    stephen_robinson
    Posts: 746 from 2007/4/22
    Well it was mentioned in the changelog, does that mean it's officially supported now?
    Devs/Networks/SunGEM
    Autonegotiation fixes
    Fixed to update link speeds when manually configured
    Fixed network setup on PowerMac5,1 (Cube)
  • »25.12.13 - 08:03
    Yes, it is officially supported now, we still need to update the website info accordingly, though.
    EDIT: The website info is updated now ....
    [ Editiert durch pega-1 25.12.2013 - 14:29 ]
  • »25.12.13 - 10:30
    ausPPC
    Posts: 543 from 2007/8/6
    Hmm... ;)
    https://en.wikipedia.org/wiki/Power_Mac_G4_Cube#Modifications_and_upgrades
    http://www.everymac.com/systems/apple/powermac_g4/faq_cube/
    http://www.everymac.com/systems/apple/powermac_g4/faq_cube/power-mac-g4-cube-video-card-hacks-geforce-3-5500-6200-radeon-9000.html
    Some people put 9800s in their Cubes?
    [ Edited by ausPPC 30.12.2013 - 11:35 ]
  • »27.12.13 - 22:43
    ausPPC
    Ridiculous price & wrong gfx card but somehow still kinda cool...
    http://www.ebay.com/itm/Apple-Mac-G4-Cube-with-Upgraded-1-8-GHz-CPU-Processor-and-Upgraded-SuperDrive-/370878457062?pt=Apple_Desktops&hash=item565a1424e6
  • »30.12.13 - 07:15
    WeiXing3D
    Posts: 327 from 2012/6/13
    To summarize, what is the best hardware configuration in a PowerMac 5,1 Cube to run and use MorphOS?
  • »31.12.13 - 17:30
    ausPPC
    @WeiXing3D IMO that would depend on how flexible MorphOS is. Does it expect a stock standard Cube or will the additional hardware options be automatically recognised? Does anyone have access to an upgraded Cube to play with?
  • »31.12.13 - 19:45
    Posts: 2239 from 2003/2/24
    Sonnet did make upgardes up to 1.8GHz for the Cube, no reason why that shouldn't work (pretty much the same as the CPU-cards they offer for PMacs and they work too.
    Depending on the actual space in the Cube you might also be able to up the GFX to a Radeon 9xxx.
  • »31.12.13 - 20:07
    pampers
    Posts: 1061 from 2009/2/26
    Insane, good luck to a seller :)
    MorphOS 3.x
  • »01.01.14 - 11:07
    Yes, the third link in posting #52 leads to a page saying that the Cube can take Radeons 9000, 9200 and 9800 Pro.
  • »01.01.14 - 22:57
    stephen_robinson
    I sold my G4 Cube, so I've not been able to test amy of the more recent update of MorphOS on it.
    it looks nice, but the macmini is a much more practical machine for MorphOS. If you can call what we're doing here as practical.
  • »15.05.15 - 22:34
    Posts: 18 from 2021/1/31
    I'll give 3.4 a try on my g4-cube then ;)
  • »31.01.21 - 17:00
    Why ancient v3.4 and not the most recent release (or anything between in case of regressions)?
  • »31.01.21 - 18:07
    Good question, did newer releases do anything good for support of the g4-cube-hardware 450/R128pro/original ADC-Monitr?
    I am a retro-gamer, so main target of the cube is gaming and watching demos. Getting connected to my NAS would be fine, but is not a must have. Browsing the web is not needed. I do need an alternative Solution for the audio because the appe-pro-speakers do not work.
    First test:
    1. Regardless what version I use, the Monitor stays black and the LED blinks (unsupported mode)
    2. Shift/F1/LMB does not work on Macs, because left Mouse-Button ejects the CD...so no boot menu at all.
    3. After pressing "c" and then holding "ctrl" does work but I have to hold a longer time due boot up, otherwise the monitor goes black again and blinks.
    4. If I do hold "ctrl" I see the desktop (Ambient-Screen)
    5. Installing does not work because OS9-Harddisk-Driver and the installed OS9.0.4 makes the iWizzard go crazy.
    5a. Does Morphos boot from external storage like FireWire-Harddisk?
    5b. Is there an other way of staying with OS9 and installing Morphos too?
    6. Getting to the Monitor-Sektion and choosing nothing leads directly to a black screen and a blinking LED on the Monitor
    6a. 16Bit Colordepth and 640x480 seems to be OK
    6b. 24Bit ColorDepth and 640x480 does lead to a black Screen and blinking LED again.
    There is only 640x480 Resolutions visible in the menu.
    Greetings
    Doc
    [ Edited by drzeissler 31.01.2021 - 17:46 ]
  • »31.01.21 - 18:37
    I did test MorphOS on different hardware like my g4-mini and mostly I do only install the Demopack and watch demos. Therefore the first supported Morphos Version does the job. Later versions do support older apple keyboards, so changing the audio-volume is handy.
    Greetings
    Doc
    http://amiga.bbs.fi/demopack_morphos/
  • »31.01.21 - 18:42
    Getting the old versions:
    http://www.morphos-team.net/morphos-3.9.iso
    http://www.morphos-team.net/morphos-3.8.iso
    http://www.morphos-team.net/morphos-3.7.iso
    http://www.morphos-team.net/morphos-3.6.iso
    http://www.morphos-team.net/morphos-3.5.iso
    http://www.morphos-team.net/morphos-3.4.iso
    http://www.morphos-team.net/morphos-3.3.iso
    http://www.morphos-team.net/morphos-3.2.iso
    http://www.morphos-team.net/morphos-3.1.iso
    http://www.morphos-team.net/morphos-3.0.iso
    http://www.morphos-team.net/morphos-2.7.iso
    http://www.morphos-team.net/morphos-2.6.iso
    http://www.morphos-team.net/morphos-2.5.iso
    http://www.morphos-team.net/morphos-2.4.iso
    http://www.morphos-team.net/morphos-2.3.iso
    http://www.morphos-team.net/morphos-2.2.iso
    http://www.morphos-team.net/morphos-2.1.iso
    http://www.morphos-team.net/morphos-2.0.iso
  • »31.01.21 - 18:43
    > did newer releases do anything good for support of the g4-cube-hardware [...]?
    Searching the MorphOS release notes for 'cube' reveals this:
    "Classes/Usb/USBAudio
    Made it possible to enable a specific amplifier plugin and customised equaliser parameters for PMac Cube speakers
    https://www.morphos-team.net/releasenotes/3.12
    It's F1 *or* LMB (don't know about Shift).
    "Helios FireWire/IEEE1394 Stack
    Integrated Helios FireWire support for mac_ppc32/mac_ppc64 architectures
    [ Edited by Andreas_Wolf 31.01.2021 - 23:55 ]
  • »31.01.21 - 19:03
    Posts: 358 from 2019/5/9
    It can be pretty challenging to install Radeon 9800PRO into cube.
    Not only physical modification of card pins, but you need to solve cooling, and finally length of 9800PRO is 190mm and cube outer size is 7.7" incl case = 195.6 mm !! Not much space for installation.
    Anyway, the Cube is very nice machine!
    AmigaOS4: Micro A1-C, AmigaOne XE, Pegasos II, Sam440ep, Sam440ep-flex, AmigaOneX1000
    MorphOS: Efika 5200b, Pegasos I, Pegasos II, Powerbook G4, Mac Mini, iMac G5, Powermac G5 Quad
  • »01.02.21 - 08:55
    Thx again, testing this week. Forget about upgrading from Rage128pro to a "better" card. If you will risk killing your cube then go for it. Perhaps adding a fan can help, but the nice thing about the cube is, that it has no fan.
    [ Edited by drzeissler 01.02.2021 - 19:39 ]
  • »01.02.21 - 19:18
    I got MorphOS 3.13 booting after several attemps on the cube. I can hear some sound. It does not sound very clear, but the sound seems to work. Great!
    I started on the partition-map but I had to stop there.
    -24GB OS9
    -24GB OSX
    -24GB
    I have to read the basic partition-map required for morphOS because I will not delete OS9 and OSX from the machine.
    [ Edited by drzeissler 01.02.2021 - 19:53 ]
  • »01.02.21 - 20:43
    I killed my OS9 boot while using iWizard. OSX is still booting on the local HDD of the cube.
    I installed MorphOS on an external Firewire 160GB LaCie HDD (automatic partition).
    I cannot boot that external Morphos Installation.
    Perhaps I am checking an USB-Stick installation if firewire fails.
    Any tips for external firewire installation?
    Thx :)
  • »03.02.21 - 13:07
