Posts: 12080 from 2003/5/22
> I see the Genesi use the A8 at 800mhz is that kind of the same thing?
The Cortex-A8 is, as you might have guessed, the predecessor to the Cortex-A9:
http://en.wikipedia.org/wiki/ARM_Cortex-A8
http://www.arm.com/products/processors/cortex-a/cortex-a8.php
The Cortex-A8 based chip that is used by Genesi is Freescale's
i.MX515 and they're about to switch to the
i.MX535 which is still Cortex-A8. As for Cortex-A9 they made statements pointing to the
i.MX6 for future Genesi products:
http://www.powerdeveloper.org/forums/viewtopic.php?p=14714#14714
http://www.powerdeveloper.org/forums/viewtopic.php?p=14812#14812
http://www.powerdeveloper.org/forums/viewtopic.php?p=14826#14826
> Are there any other kind of SoC based CPU's that could be used?
Used for what exactly?
> What happened to that Mobile GT?
You seem to like MobileGT
very much ;-) Well, just have a look at Freescale's product page for MobileGT:
http://www.freescale.com/mobilegt
You'll find that the latest addition to this chip family was the MPC5125 in April 2010. There're some threads here on MZ where this chip has been discussed:
https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7014&forum=11
https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7713&forum=3
The Web has some mention of an "
MPC5130 : Dual PowerPC core based SOC" but I don't know if that's still to come or cancelled by now:
https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6428&forum=3&start=12
> I'm Sure there are many cheap and nasty ARM based netbooks and tablets to use?
> [...] These Android tablets are only like £50 to £180 whatever on ebay!
Yes, there are. However, they're usually not Cortex-A9 yet but Cortex-A8 at best, most often just
ARM11 and sometimes even only
ARM9.
> we need a mini PPC board for <£225
There are:
http://www.google.com/search?q=twr-mpc5121
http://www.google.com/search?q=twr-mpc5125
...and even complete mini machines:
https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=7675&start=80
