OPEN FIRMWARE REVISIONS
    Posts: 278 from 2003/3/4
    So far we have:
    Pegasos I/G3 "PRE-APRIL", Board: 1A (0.1b73), CPU: 750 CX 1.0, SF: 1.1 (20020814)
    Pegasos I/G3, Board: 1A1 (0.1b112), CPU: 750 CX 1.0, SF:1.1 (20021203121657)
    Pegasos I/G3, Board: 1A1 (0.1b114), CPU: 750 CX 1.0, SF: 1.1 (20030317114750)
    Pegasos II/G4, Board: 1.1, CPU: 744X 1.1, SF: 1.2 (20040224)
    Pegasos II/G3, Board: 1.1 (0.2b1), CPU: 750 CX 1.0, SF: 1.2 (20040402193939)
    Pegasos II/G4, Board: 1.1, CPU: 744X 1.1, SF: 1.1 (20040405)
    Pegasos II/G4, Board: 1.1, CPU: 744X 1.1, SF: 1.2 (20040405)
    Pegasos II/G4, Board: 1.2, CPU: 744X 1.2, SF: 1.1 (20040505)
    Pegasos II/G4, Board: 1.0, CPU: 744X 1.0, SF: 1.2 (20040810112413)
    Pegasos II/G4, Board: 1.2, CPU: 744X 1.1, SF: 1.2 (20040810112413)
    Pegasos II/G3, Board: 1.2, CPU: 750 CX 1.0, SF: 1.2 (20040810112413)
    Pegasos II/G4, Board: 1.2, CPU: 744X 1.2, SF: 1.2 (20040810112413)
    Pegasos II/G4, Board: 1.2, CPU: 744X 1.2, SF: 1.2 (20050602111451)
    Pegasos II/G4, Board: 1.2 ,CPU: 744X 1.2, SF: 1.2 (20050808153840)
    Pegasos II/G4, Board: 1.2 ,CPU: 744X 1.2, SF: 1.2 (20051216161829)
    [ Edited by cdfr on 2006/4/4 7:26 ]
    [ Edited by cdfr on 2006/4/10 14:43 ]
  • »02.04.06 - 09:30
    SoundSquare
    Posts: 1213 from 2004/12/1
    Pegasos II/G4, Board: 1.2, CPU board: 1.2, SF: 1.2 (20050602)
  • »02.04.06 - 13:02
    Neko
    Posts: 301 from 2003/2/24
    What's the point of listing these?
    Matt Sealey, Genesi USA, Inc.
    Developer Relations
    Product Development Analyst
  • »02.04.06 - 13:30
    cecilia
    Posts: 459 from 2003/8/30
    I've got a peg one
    where do i type those commands?
    typing them in a shell gets a no device found kind of repsonse.
  • »02.04.06 - 14:35
    The point is to list all the OF versions, all the board revisions and ask gently Bplan what changed between them.
    We may also learn that certain OF versions are matched with certain Hardware rev and know if depending on what OF version we have if an OF update to a newer version would make sense or not.
    If all this information is publically documented somewhere please advise.
    The commands are not to type in a DOS shell but at the Open Firmware prompt. If your Peg is set to autoboot you can press ESC when booting to reach the OF prompt.
    It looks that on (some ?) Peg1 the OF commands listed by Senex does not work. Peg1 owners please try to read the OF version if displayed at boot time (it may depends as some gfx card may not display it) and report the version here. For mainboard and CPU board rev you can always check it on the boards.
    [ Edited by cdfr on 2006/4/2 8:55 ]
  • »02.04.06 - 14:52
    SoundSquare
    Peg1 owners need to add a " / " :
    cd /openprom
  • »02.04.06 - 15:32
    cecilia
    hey, thanks guys! I'm writing down everything it says because I really don't know what it all means :lol:
    I'll leave it to you to understand....
    built-in 0x1317E4E (20020814)
    Relative-addressing model "Pegasos, 0.1b73"
    SmartFirmware-version "1.1"
  • »02.04.06 - 15:42
    Thanks for the tip soundsquare
  • »02.04.06 - 15:52
    Toto
    Posts: 268 from 2003/4/20
    Pegasos II G4
    Board 1.2
    CPU board 1.1
    SF 1.2 (20040810)
  • »02.04.06 - 21:26
    Here goes the first 1.1 CPU module !
    Could you please post a picture of it ?
  • »02.04.06 - 21:53
    Toto
    I'll post some pictures tomorrow, front and back.
  • »02.04.06 - 22:27
  • rms
    rms
    Posts: 599 from 2004/11/27
    I have the following 6 Pegasos's (they are all the same):
    Pegasos 2, 1.2
    realtive-addressing: 0x131CC6A (20040810)
    upgraded
    Regards
    Christoph
  • »03.04.06 - 09:31
    C64Days
    Posts: 103 from 2006/2/27
    Sometimes the OF revision release number and date is
    overwritten at OF prompt page by the OEM-Banner set by
    the reseller, to disable the OEM-banner it should be enough
    to type at prompt:
    setenv oem-banner false
    and reboot...
  • »03.04.06 - 11:03
    Toto
    CPU v1.1 front
    CPU v1.1 back
  • »03.04.06 - 12:12
    Bladerunner
    Posts: 418 from 2004/2/19
    SmartFirmware Version "1.2" (20051216161829)
    model "Pegasos2,1.2"
    built-on "0x131F510 (20051216)
    upgraded due some gfx Probs with my Radeon 9000 which where solved with the newer Firmware.
    [ Edited by Bladerunner on 2006/4/3 13:27 ]
  • »03.04.06 - 13:26
    Thanks toto and Bladerunner. Any other firmware around (Anyone with a pre-april or an april 1 firmware) ?
    If someone please can post similar pictures for CPU Board 1.0 and 1.2 then we can spot the differences :)
    I have a 1.2 CPU board but I am currently away from it. I may post a picture later if nobody does it.
    [ Edited by cdfr on 2006/4/3 8:31 ]
  • »03.04.06 - 14:30
    Bladerunner
    cdfr:
    IIRC, Cecilia`s Board is actually a pre April Board.
  • »03.04.06 - 15:17
    magnetic
    Posts: 2129 from 2003/3/1
    Neko
    I was going to ask the same question :-?
    Here is my info for kicks (and also because there is always a method to cdfr's madness :-) )
    Peg 2
    Rev 1.2
    build 20040810
    Would be great to get a comment from bplan on these numbers...
    magnetic
  • »03.04.06 - 17:46
    analogkid
    Posts: 664 from 2004/11/3
    Pegasos2 G3
    V1.2
    SF 1.2 (20040810)
  • »03.04.06 - 19:29
    volm
    Posts: 13 from 2003/11/24
    PegasosII/G3 here...
    Board says:
    pegasos dual ppc
    rev: 2b1
    Cpucard says:
    pegasos cpu
    single 750 cx
    rev: 1.0
    OF (.properties) says:
    model: pegasos2, 1.1
    sf: 1.2 (20040402193939)
  • »03.04.06 - 19:46
    Markus_Bieler
    Posts: 19 from 2004/3/20
    My PegasosII G4:
    SF 1.2
    Peg2 1.1
    20040224
    [ Edited by Markus_Bieler on 2006/4/3 21:33 ]
    :angel:
  • »03.04.06 - 21:29
    maurensen
    Posts: 358 from 2003/10/3
    Pegasos II/G4
    Version 1.2
    SmartFirmware 1.2 - 20040810
    Ola
  • »04.04.06 - 08:45
    Neko
    Here is the hard sell on the firmware:
    You are never going to know what the difference is between board revisions, and in any case it is not guaranteed to give you any hint by knowing what firmware revision is on it. Please do not "ask gently" or ask at all, as you will be met with what amounts to a disappointing response.
    The public differences: 2B4 and below used a Winbond clock chip. 2B5 and above use an ICS clock chip (see Power.org public specifications).
    Users should run the latest publically available firmware, if the one already installed on your system is not in fact much newer. For most Pegasos II owners this is the firmware that came with the machine. For the rest it's on the bplan site - but if you didn't upgrade already you probably broke your system doing setenv in firmware anyway :D
    There is no real intrinsic value to knowing how many hardware/software revision/combinations there are - in a very short time there will be a "1.3" firmware, for Pegasos II if not also for Pegasos I too, and EFIKA, and the HDB, and everything else, and it will all be useless information. Dare I say you are wasting your time with a boring numbers game?
    Developer Relations
  • »04.04.06 - 11:31
    thefab
    Posts: 92 from 2003/8/19
    Neko,
    i guess some people here are not bored with number games but instead, are bored of bugged firmwares.
  • »04.04.06 - 11:54
