Moderator
Posts: 441 from 2003/2/26
takemehomegrandma:
You are free to come up with any suggestion on names
I did not think of short down of names. So we might find something better, hmm.... thinking....
Maybe we should have a contest ?
And thank you DJBase for suggestions !
Palpatine & magnetic:
Well, that display looks fine
The reason I posted those pictures on Pegasos.org was for showing some people what Freevo is and how it can be used and what we have done so far, and what for instance a Media Station created around Pegasos, and for instance using this case, can be. Not only for showing the case or the display device in itself
It is still work in progress.
It is also that the display device in itself might be the most expensive part in the whole concept, depending on choice of course. I for myself really like Neovo displays, they are the best in all aspects and nr 1, in my opinion. However they do not have any widescreen format yet, but the X-AV series are very nice. In a test that was in a computer magazin here, just some weeks ago, they won over all other marks easy. They claimed really no discussion who is nr 1...
When ready, we will hopefully show it around at some places also.
Gunne
Best wishes, Gunne
