    Posts: 478 from 2019/5/9
    >> NVME, USB 3.0
    > MorphOS drivers?
    Geennaam comment on amiga-news.de:
    Tested Linux distributions are all booting and running from NVMe. I also have experience with NVMe drivers, so consider this covered for OS4 and MorphOS as well.
  • »04.06.25 - 16:34
    Posts: 12550 from 2003/5/22
    >>> NVME, USB 3.0
    >> MorphOS drivers?
    > Geennaam comment on amiga-news.de: […] I also have experience
    > with NVMe drivers, so consider this covered for […] MorphOS
    Alright, so USB3 (USB 3.2 specifically) yet to assign then, I guess.
  • »04.06.25 - 18:32
    > Complete MorphOS-related entries from the "blog": […]
    4th June: "A Medal of Honor…
    MorphOS developer and Porter Cowcat brought us OpenMOHAA. Lets see if it runs on the Mirari Proto board.
    https://www.youtube.com/watch?v=DJF-Xy60lBE
  • »04.06.25 - 21:02
    Cool_amigaN
    Posts: 777 from 2011/11/30
    ^ Many thanks for completing my request on my bday :) It sure loads much faster and the gameplay is 100% smooth compared to my system (especially when entering large sceneries and battling many enemies). How did you get the fps values on the down left side, so I can do a direct comparison? Overal seems a nice improvement compared to what I have available right now as my main computer at home. I think final test on 3D capabilities should be Doom 3, which along with OpenMohaa are the heaviest software pieces we have to compare.
    [ Edited by Cool_amigaN 05.06.2025 - 09:14 ]
  • »05.06.25 - 04:13
    In this I believe @geennaam, that he succeeds also with USB3 drivers. And if not, we can use USB3 with linux - the same way like I do it with my X1000. And USB3.0 is enough for Mirari:
    Used chip ( if I read it correctly from photos ) has four USB3.0 ports and is connected to PCIe v2.0 line.
    Mirari with CPU T1024 has all SEDRES lines with speed of PCIe v2.0, it means speeds only upto USB 3.0.
    Only way howto use USB 3.1 is to have Mirari with T2081 CPU and put USB 3.1(or 3.2) PCIe card to x4 connector.
    T2081 CPU in Mirari configuration ( see possible SERDES mapping of CPU ) has one PCIe 3.0 line, connected to this slot. And if there is only one PCIe link, you cannot use USB3.2 speed, which needs two lines. Thus every USB3.2 device will work max in 3.1 mode.
    [ Edited by sailor 05.06.2025 - 09:36 ]
  • »05.06.25 - 04:52
    > Used chip [...] has four USB3.0 ports
    You're correct. I once knew but unfortunately forgot that "USB 3.2 Gen 1" is just a new fancy name for the old 5 Gbit/s USB 3.0 (and "USB 3.2 Gen 2×1" a new name for 10 Gbit/s USB 3.1, and only "USB 3.2 Gen 2×2" the real 20 Gbit/s USB 3.2). Thanks for reminding me.
    > PCIe v2.0 [...] means speeds only upto USB 3.0.
    ...or USB 3.2 Gen 1 ;-)
  • »05.06.25 - 07:07
    8th June: "Good old Quake3 ..
    On of my old time favorite`s .. the Daddy of all FPS games Quake 3 ! Running on the Mirari board.
    https://www.youtube.com/watch?v=TSTczmkqq5w
    12th June: "Classics using ScummVM
    Classic games running on ScummVM and MorphOS 3.20. Lets see how that turns out.
    https://www.youtube.com/watch?v=XekRwvtiVKQ
    Edit: added another entry
    [ Edited by Andreas_Wolf 13.06.2025 - 18:45 ]
  • »08.06.25 - 16:34
    13th June: "HD Audio driver for MorphOS
    Harald has just finished his first MorphOS driver. It’s for PCIe discrete soundcard complying with the Intel Hdaudio standard. That includes:
    Sound Blaster Audigy FX
    Sound Blaster Audigy FX V2
    CM8828+CM9882A cards
    https://mirari.vitasys.nl/wp-content/uploads/2025/06/HDaudio_Alpha_MOS.jpg
  • »13.06.25 - 20:00
    Brumiga
    Posts: 277 from 2004/4/3
    @Andreas_Wolf,
    Do you know when the audio part will be supported/managed by the Trion FPGA chip ? I saw/read somewhere that this chip would/should do the job.
    Brumiga
  • »14.06.25 - 07:05
    That would be this part of the overall description:
    "The T1042 features an I2S interface for direct connection to external audio codecs, while the T208x does not. Therefore, we've implemented the I2S and S/PDIF controllers in the FPGA. This means there's no audio driver readily available for Linux. For OS4 and MorphOS, I have experience writing AHI drivers, so consider this covered."
    Sorry, I've no knowledge whether those controllers have already been implemented in the FPGA (and just the drivers missing) or are yet to be implemented (and if so, when).
  • »14.06.25 - 11:50
    Posts: 2575 from 2003/2/24
    Well the last "news" is that he got the drivers for a fancy surround sound PCIe card working, so I'd say
    no
  • »14.06.25 - 14:17
    Yes, see comment #83 :-) This is likely just a MorphOS port of the author's existing OS4 driver.
    > so I'd say no
    Strictly speaking, the statement regarding the I²S and S/PDIF controller implementation in the FPGA is written in present perfect tense, rather implying a 'yes'.
  • »14.06.25 - 15:17
    Posts: 50 from 2020/10/11
    The drivers build by @geennaam are the HDaudio drivers.
    It’s for PCIe discrete soundcards complying with the Intel Hdaudio standard.
    That includes:
    Its not the driver for the onboard FPGA yet.
  • »15.06.25 - 11:07
    > The drivers build by @geennaam are the HDaudio drivers. It’s
    > standard. [...] Its not the driver for the onboard FPGA yet.
    Yes, that's what's already been worked out in comments #82 to #87. Instead, the question (see comment #84) was whether the FPGA-based I²S and S/PDIF controller implementations have already been completed or not. The used language (see quote in comment #85) implies a 'yes', while others (see comment #86) assume a 'no'.
  • »15.06.25 - 11:27
    I can say the logic is in the FPGA and a Tone can be send to the Jack and Optical out.
    No driver yet.
  • »15.06.25 - 11:55
    Thanks for confirmation that both controllers have been implemented already.
  • »15.06.25 - 12:46
    No driver yet.
  • »15.06.25 - 15:08
    Posts: 2730 from 2003/2/24
    No driver yet.
    Thanks for visiting here and browsing through the feedback from MorphOS users! :-) This is indeed a good sign! :-)
    I sincerely hope you read and take to your heart the requests from the MorphOS world about the more powerful CPU option. This is what *we* want! ;-)
    I am actually looking to buy a board with this CPU for MorphOS use, should you have a working one to provide. (Maybe an optional "Butterfly" Mirari bootloader image in blue? Not very important though... ;-))
    Maybe the next run is earmarked only for developers? But I would even buy an early individual board with this CPU, if made available to me. Long holiday coming up. Let me know if you end up with a spare board left over. ;-)
  • »15.06.25 - 23:22
    2nd July: "MorphOS version of RetroArch port done by Steffen Haeuser tested with FBneo core and NeoGeo games."
    https://www.youtube.com/watch?v=5uDNOJ3tuSY
    6th July: "Doom64 EX test on Mirari board running MorphOS 3.20
    As stated on the MorphOS Storage website: Doom 64 EX+ is a continuation project of Samuel “Kaiser” Villarreal’s Doom 64 EX aimed to recreate DOOM 64 as closely as possible with additional modding..
    https://www.youtube.com/watch?v=8uy7ZNzNiAc
    [ Edited by Andreas_Wolf 07.07.2025 - 00:03 ]
  • »02.07.25 - 19:40
    Everblue
    Posts: 170 from 2004/1/6
    Is there a (very rough) indication of the price for this board? Will this also run Amiga OS 4 (for all its worth)?
    Thanks.
  • »15.07.25 - 13:50
    Posts: 53 from 2018/6/9
    Not yet. And watch this space...
  • »15.07.25 - 20:42
    Brumiga
    It is summer, and temperatures are rising significantly both indoors and outdoors. Apple computers use their sensors to modulate the rotation speed of their various fans and thus prevent the processor(s) from overheating.
    I read that the AmigaOne x1000 and X5000 don't have circuits to regulate the temperature of their processors despite they have sensors. What about this Mirari ? Does it have a circuit to regulate the speed of their various fans connected, processor front chassis rear chassis, and thus prevent the processor from overheating ?
    Brumiga
  • »16.07.25 - 10:33
    Hi all,
    Few updates regarding the above posts. First the pricing. It's still hard to come with a final price. We have send out an order for 25 new boards with several changes. We have to see how these leave the factory and more important if they are all functional. It could be that for example 10 percent of the boards are not functioning. We are not sure yet after having just done a single small batch. The moment we can tell a price that makes sense we will let you know. Regarding the temp. The board has temp sensors so yeah we can measure this. It's already functional within linux. Also the fan speed can be set from within Uboot... But if i recall Harald correct this is still work in progress. The cpu temp under full load overclocked at 1.6 GHz instead of 1.4Ghz has not passed 50 degrees celcius from what I have seen. So when running stock at 1.4Ghz temp will not be an issue. We hope to see the boards arrive in August and then some work needs ro be done as Harald will add some components like a header himself. Also he will bring up the boards by hand one by one. That's the info for now. Keep you posted!
  • »19.07.25 - 14:04
    @Skateman
    thanks for new informations and cross fingers!
  • »19.07.25 - 18:42
