    Tom01
    Posts: 187 from 2009/9/20
    koszer wrote:
    ThePlayer wrote:
    The question still remains what exact config eliot has and what combination of dual CPUs,bad airflow and aging fans is responsible for the noise.
    I had a MDD Mac and i can't remember that it was noisy.
    AFAIK early MDD's are notorious for their noisy fans in PSU (AcBel). The late ones, with Samsung PSU are quieter.
    It is not the PSU. I have replaced it with an ATX PSU. It is the CPU fan, which is extremely loud. Sounds like a moped.
  • »17.09.25 - 07:32
    Posts: 1090 from 2004/9/23
    You need a small cup, 99.9% alcohol (IPA) and a battery to repair your fan.
    Here is how it looks like:
    https://www.geit.de/tmp/PowerMac_FanCleanOrnamentalFountain.mov
    Before the fan was loud like hell. After removing it from the case, you could hit the blade by hand and it did not even rotate 1/4 of a full rotation.
    After running around 20 minutes in its bath, which looked very filthy after a short while if was like new. I put it back without any additional lubrication and it works since than for over three years. Recently it starts to making noice again, but it is runnning at least 18 hours a day for over three years.
  • »17.09.25 - 11:48
    Posts: 2565 from 2003/2/24
    Seems a lot of work for 3€ worth of fan.
  • »17.09.25 - 13:10
    Well, I did it in the evening. No need to order and wait for a fan. No need to have the none working dismantled PowerMac around until the package arrives and you find the time to swap it.
    So, yes. I prefer having it done in 30 minutes. :D
  • »17.09.25 - 13:43
    Posts: 477 from 2019/5/9
    [quote]geit
    thanks for tip, I try renew fans from powernac this way...
  • »17.09.25 - 15:28
    Collection number ;-)
  • »26.09.25 - 08:41
    Posts: 649 from 2004/4/15
    I am back in the game.
    I just updated my Power Mac Mdd 3,6, 1,25 GHz G4 with
    Radeon 9600 GPU.
    It‘s ok, but really loud.
    So I am still looking foward to the Mirari Release.
    We see us at Amiga40!
  • »04.10.25 - 12:21
    ppc-grinch
    Posts: 43 from 2025/7/17
    I may have forgotten already, but is there any proof that the Mirari team will at some point be testing their board with the T2081 (e6500 core)? All I have see being mentioned in press releases and seen in video demonstrations on their official YouTube channel are the T1042 (e5500 core).
    The Mirari board also got some attention at Amiga40 in Germany, alongside the announcement of AmigaOS 3.3, AmigaOS 4.1 Final Edition Update 3, an update to the ExecSG Multicore plan for adding SMP to AmigaOS 4, and more.
    Mac Mini G4 1.5 Ghz, ATI Radeon 9200 64MB, 1GB RAM
  • »13.11.25 - 20:55
    Posts: 1087 from 2003/3/24
    I thing that the Mirari is a great board and i am thrilled how just two guys make it happen in such a short time. I talked to Skateman at the Amiga40. And i told him that many of us MorphOS Users would like to have the board to be equipped with T2081. Because most of us use an G4 or G5. And the T1042 would be a downgrade with the missing Altivec Units.
    I wonder how far we could overclock the T2081?
  • »14.11.25 - 13:04
    I'm pretty sure going back to my 1.8GHz Quiksilver (which is close to the max what a G4 desktop can be) would be a downgrade for everything except a few edge cases.
    AGP PMac G5 and the iMac? A much more mixed result, but the limitations in I/O and plausible GPUs makes it again a no brainer.
    Even a PCIe G5 will struggle in I/O.
    Noise, heat and the need for obscure 20+ year old parts....
    Would I buy a T2081 Mirari? Sure, even at a premium.
    Would I have skipped on the T1042 board if I knew for sure a T2081 would be coming? Only if it had been a question of months (which I doubt it will be).
    I do plan to maintain 2 desktop MorphOS systems anyways, whether 1 is a G5 or both Mirari, doesn't really matter that much.
  • »14.11.25 - 18:25
    Posts: 12543 from 2003/5/22
    Interestingly, it were four guys until August (not counting Trevor). But indeed, progress seems blazingly fast compared to that other project.
  • »14.11.25 - 19:29
    Flash
    Posts: 112 from 2019/11/1
    Maybe a next hw revision could have a CPU slot just like Pegasos?
  • »15.11.25 - 04:43
    Posts: 608 from 2003/4/11
    You can't simply glue a T2081 SoC to the board as a T1042 replacement and have it working and there is no easy solution like a BGA socketed board, either. It also would raise the costs for a customer board even if it would be possible which kind of contradicts the goal to provide an affordable board, let alone all the implications this would have for a customer to get hold of such SoC or even put it onto the board.
    Making the T2081 SoC based board work also needs various adjustments to the UBoot firmware which have not been done until the current day AFAICT, it won't run OOTB.
  • »15.11.25 - 11:46
    Posts: 53 from 2018/6/9
    Kronos wrote:
    [SNIP]
    [SNIP]
    I am lucky enough to be in the beta test phase and I would just like to second this. Don't underestimate the emphasis on noise and power. The Mirari is sitting on my desk about 2ft from my ears, in a tiny case, with the CPU fan set to 50% and a silent GPU. While the machine isn't silent like my Mac Mini (M4, not a G4) it's really pretty damn close. I would be happy to sit next to this all day long. All while the CPU (the hottest part of the system) is sitting around 43C (it obviously does get hotter but 51C was the most I've seen compared to 71C on my 5040).
    Priceless in my opinion. Will I upgrade to the board with Altivec should it happen? Of course, but I'm very glad (and grateful) I was offered the opportunity to get involved with this board.
  • »17.11.25 - 09:50
    > Complete MorphOS-related entries from the "blog": […]
    20th November: "The need for more Speed (NVMe)
    While Harald focused on the hardware and the raw NVMe driver, Frank’s work ensures that once the driver is complete, MorphOS can fully utilize it, including the crucial ability to boot directly from an NVMe drive. This requires modifying or integrating the NVMe support into the MorphOS boot process and the file system layer, allowing the operating system to load its initial files from the high-speed NVMe storage. In essence, Harald provided the device driver (the software bridge) for the modern NVMe hardware, while Frank Mariak is handling the operating system integration (adapting MorphOS) to make the NVMe drive a fully functional and bootable part of the new PowerPC system. [...] Check the video below on installing and booting MorphOS 3.20 using a NVME drive.
    https://www.youtube.com/watch?v=jWegsIzQ8Z4
  • »21.11.25 - 06:48
    wow, very cool!
  • »21.11.25 - 11:35
    Travis_H
    Posts: 165 from 2009/12/17
    I don't mean to be "that" guy, but when can I buy this? I've been without MorphOS for a few months since the iMac Mini stopped booting. I've still got the iBook, but I never had any of my software on it.
  • »22.11.25 - 02:08
    Current !!PLAN!! is to order another batch late this year which should be shipping to customers in early spring (rough estimate of course).
    Wether any of those will be available for the general public (instead of being allocated to betatesters) is unknown, just like it is unknown wether a public MorphOS with Mirari support will be available at that time.
    So I guess if there is ever a point when you will be able to just buy one on a whim will be 2nd half of 2026....
  • »22.11.25 - 08:49
    Posts: 49 from 2020/10/11
    Yeah, it was just a bit to much for the other two guys..
    The dedication of getting this going (from Harald and Me) was more then the average nice side project.. :-)
  • »22.11.25 - 12:48
    Posts: 168 from 2004/11/18
    For me it's impressive how fast are the progress.
    Nvme it's just blazing fast....
    It's a pitty that Morphos doesn't use the second core of the processor.
    It should be usefull to use this second core to send some tasks like JavaScript or media demuxing or 68k just in time...... A bit like it was on powerup....
    This approach avoid to loose compatibility with actual software and also permit to gain some horsepower and responsivness on heavy tasks.
    I know smp is better but it need a complete rewrite of operating system and use a sort of virtualisation to allow abox to run and since years it was never done.
    Asmp could be a first step.
    [ Edited by acepeg 22.11.2025 - 15:10 ]
  • »22.11.25 - 14:07
    > […] Morphos doesn't use the second core of the processor.
    …neither third and fourth one ;-)
  • »22.11.25 - 17:01
    ;-) absolutly !
  • »23.11.25 - 17:43
    Posts: 3 from 2025/11/23
    Nice to see that they're using SOC's that we've already discussed.
    Since I disposed my G5 Quad with the bad coolers this January, it would be nice to have a new MorphOS system.
    Although I to would prefer the T2081, if only for it's higher clock speed and AltiVec instructions.
    The extra cores would be useful under Linux.
    Final thought, an MATX form factor board with expansion slots would have been more useful.
    [ Edited by Iggy 23.11.2025 - 13:03 ]
  • »23.11.25 - 17:52
    A mATX board with slots would be indeed more useful than a mATX board with slots ;)
    Something is of with your statement.
  • »23.11.25 - 19:09
