G5 PowerMac videocard with MorphOS?
    Krisz
    Posts: 154 from 2023/3/22
    eastone wrote:
    @Krisz
    Write what model/brand of keyboard and mouse you are using and to which port you are connecting these devices. Have you tried using a different keyboard and mouse? I also have one Logitech mouse that behaves just like yours. Despite the black screen, do you hear a jingle when starting the system from CD?
    Btw, my G5 11.2 has problems with the USB port on the front and it doesn't work more often than it does.
    There is no brand name on the keyboard, just Spirit Of Gamer
    The mouse is some cheap wireless Chinese product
    Both have been working flawlessly on MacPro 5.1 for years
    I tried both the front and back connectors!
    [img]MTg5NzMzMg.jpg[/img]
    [img]MTg5NzMzMQ.jpg[/img]
    [img]MTg5NzMzMA.jpg[/img]
    [img]MTg5NzMyOQ.jpg[/img]
  • »14.04.25 - 09:05
    Posts: 2539 from 2003/2/24
    1.7GB is the max. MorphOS can use/sees.
    As for the kbd, is this by any chance a wireless combo with some extra features? Like connecting to more than 1 dongle or so.
    When in question (and no Apple kbd at hand) stick to wired KBD and mouse (or at least ones with dumb dongles).
  • »14.04.25 - 09:05
    Posts: 12498 from 2003/5/22
    > Could there be a problem if I leave the nvidia card in the computer?
    Only with your electricity bill ;-)
    > Does not interfere with MorphOS operation?
    No.
    > MorphOS [...] says that there is 1.7GB of ram in the machine
    > and in fact there is 3GB
    MorphOS can use only 31 bit (= 2 GiB) minus some IO address space, which results in about 1.7 GiB.
  • »14.04.25 - 09:06
    Krisz
    > How can you design a machine that won't accept any card
    When Apple designed the PowerMac G5, they could have equipped OpenFirmware with an x86 emulator. I guess they didn't for marketing reasons and also because they released their own graphics cards and because they were big enough for 3rd parties to release specific graphics cards for their machines.
    Fortunately, the video card problem is solved!
    It crossed my mind that maybe the problem was with the DVI-VGA adapter and it was confirmed
    the only interesting thing is that the Nvidia card uses the same DVI connector as the Radeon and Nvidia had no problems with the adapter I used so far
  • »14.04.25 - 09:14
    >> OpenFirmware with an x86 emulator. [...]
    That's good to hear. And it was clear from the start that it wasn't a problem with the PowerMac G5's design ;-)
  • »14.04.25 - 09:21
    Krisz
    Fortunately, it was resolved
    however, in my opinion, Apple was very cheeky when they designed the Power Mac and Mac Pro machines to only work with Apple-compatible cards, which were also much more expensive than PC cards.
    But it's still much cheaper than buying an Amiga computer
    Unfortunately, my Pegasos2 has been sitting there for over 10 years since it broke
    But everything would be much easier with it
    I've just tried a few games and for example the Robinhood demo runs at about the same speed as it did on my pegasos2 at the time
    I know the demo version doesn't have the 3D driver
    I still need to get a wifi or lan card because I can't install the MorphOS system normally until then
  • »14.04.25 - 09:54
    Krisz
    Thanks
    Maybe someday there will be a MOS release that will see more ram :)
    I use a mouse that has a usb adapter but I think I should get an Apple keyboard and some kind of wired mouse
  • »14.04.25 - 09:59
    Krisz
    The user named Lord76 said that the network works with this card :
    TP-Link TG-3468
    Is this automatically detected by MorphOS and ready to use or does it need some configuration?
  • »14.04.25 - 14:57
    Small update from my side:
    Got an HD3650 that kinda works on 3.19, no signal on HDMI or DP just DVI but at least it's a start.
    The 1€ AirPort also showed up and with an antenna ripped out of a QuickSilver G4 it does work quite well.
    Need to find a solution to secure the card and antenna though.
  • »14.04.25 - 15:15
    Krisz
    Good luck with making your wifi antenna
    It's a shame the HDMI output doesn't work, that would be the advantage of the HD card.
    I decided to give up the wifi card and buy a regular lan card instead.
    I will buy this.: TP-Link TG-3468
  • »14.04.25 - 16:45
    When testing the card on a PC that HDMI wouldn't go past FullHD, so not much of an advantage.
    But the card is "better" than the AGP HD3450 which will do 2560x1440@75Hz so it might be just some stupid firmware lock to avoid higher license fees. DP does go much higher, might even do 4k@60Hz.
  • »14.04.25 - 17:14
    Krisz
    FullHD resolution is more than enough for me
    I never set a higher resolution on my MacPro either
    Now I'm having another headache trying to figure out what network card to get that MOS supports
    Finally the video card good and now there's another obstacle
  • »15.04.25 - 04:01
    Krisz
    Here on the forum a user recommended this card : AW-GE870 B/G PCI-E
    if I buy such a card, the MOS system will immediately recognize it without any tricks, right?if I buy such a card, the MOS system will immediately recognize it without any tricks, right?
  • »15.04.25 - 04:18
    Under current/recent versions of macOS "resolution" ain't a thing. It just scales text and UI to give you a FullHD like space rendered at the native res of the screen.
    In MorphOS setting a 2k or 4k monitor to FullHD means the monitor will do the scaling a far inferior result than rendering native and increasing font sizes.
    Since everything bigger than 24" is at least 2k these days (ignoring some weird gaming stuff) support for those resolution is a must.
  • »15.04.25 - 05:31
    Krisz
    I see
    I'm going to ignore MOS for a while until I find a working network card
    Until then I'll have to deal with my MacPro because after installing OCLP it doesn't want to see Windows in the boot menu for some reason
    It seems I'm having no luck with Macs
  • »15.04.25 - 06:07
    matt3
    Posts: 775 from 2004/2/10
    @Krisz
    I use a 4k monitor and a 1080p one with my G5.
    You can get decent results with you 4k monitor, but it will take some setting changes under monitors in settings to do so.
    I went with 1900x1200 on the 4k, which for a 27" screen and old eyes, gave me the best results.
    Chris Edwards had a YT for multiple monitor setup as well.
  • »15.04.25 - 11:02
    @matt3
    If it is a 4k you should go with FullHD to avoid fractional scaling.
  • »15.04.25 - 11:07
    Krisz
    matt3 wrote:
    @Krisz
    My monitor supports fullHD resolution and I use this resolution under MOS
    with 16-bit color depth
    I didn't want to set it to 24-bit because I'm afraid it would result in a performance degradation
  • »15.04.25 - 11:22
    Posts: 1351 from 2004/2/8
    I... really don't think you should hold yourself back like this on a G5 :)
  • »15.04.25 - 11:59
    Krisz
    I don't know
    I booted MorphOS from a CD and connected a hard drive with MOS using a dock that I also used on a G4 Mac.
    Due to the lack of SDL, I can only test the machine with a few games, and one of them was a car racing game called Torch, which seemed a bit slow to me.
    It's also possible that the game isn't optimized properly
    I'll only be able to test with more games once I have a working network card
  • »15.04.25 - 12:27
    It's not super fast on my G5 setup too, but I would call it quite playable (video here).
  • »15.04.25 - 18:38
    Lord76
    Posts: 81 from 2014/8/31
    This card is my working card: https://www.ebay.de/itm/297189096831?_skw=TP-LINK+TG-3468&epid=2255327262&itmmeta=01JRXKBJR0A8DTRSFZX8697ZYF&hash=item4531d9bd7f:g:r3AAAOSwDo1n83n8&itmprp=enc%3AAQAKAAAA8FkggFvd1GGDu0w3yXCmi1dE50ZICNIbFdA2Qhp8ygL%2B3%2BZUQuv%2Fjf4OKSeHgaL%2FDiNTteHgdC6iQaORAyrzzlntPRMErqxjTzsutLXGfIMJ63HiA3amwRto1T7EkTaeTrtRLGRQzS0rInTTMK7b0Jn411JzmN4QBhKOM95sS2VDRAtuhHPg%2FLGXc29Y1EqtyQA1m5GaqrLVSfgAH1jg%2FdF5YzhhXhS93%2F0ZCbd7C2ZlyPO%2B5XRvh5RetUhmBMup9y4NgOXXWrc1DaBmOsYj7K00s6O6Ed4TH0QukpoCO76QLdZpC0lDi4NhM3fMOmdu%2Bw%3D%3D%7Ctkp%3ABk9SR6CsrrPHZQ
    Powerbook G4 A1138/39
    Powermac G5 2.7ghz / G5 11.2 2.3ghz
    Amiga1200 V1200/Pistorm
  • »15.04.25 - 18:50
    matt3
    Kronos wrote:
    @matt3
    Looks good to me, and the extra space makes a nice difference with Iris and Pagestream.
    PolyOrga is on the other display at 1080P, frankly I would like to have 1200 on that screen as well.
    Anything higher resolution it gets harder to read without glasses...
  • »15.04.25 - 21:51
