G5 PowerMac videocard with MorphOS?
    Krisz
    Posts: 154 from 2023/3/22
    Krisz wrote:
    Lord76 wrote:
    Between the fan with the built-in speaker and the PCI card holder, below the DVD-ROM.
    [ Editiert durch Lord76 03.04.2025 - 16:45 ]
    Thanks!
    There is indeed a connector there but unfortunately I don't have a cable with such a connector
    You can probably get it on Ebay
    I found it!
    https://www.ebay.com/itm/295839385515?_skw=Power+Mac+g5+videocard+power+supply&itmmeta=01JQY27088H0P33NZNPQWAJ2NJ&hash=item44e166c7ab:g:BM0AAOSwKn5kwJkG&itmprp=enc%3AAQAKAAABAFkggFvd1GGDu0w3yXCmi1e7ZQtwRGfELhGlsYGC6SrTaFeU46VHUZVmGYJwiMnTOHeoQH6kXAHmejAWG7rMOZb0fP0SzwC9IbhCkdJu%2B6KfzYviD3nVqgq%2FX10CjAcS46eStzzvI4GR2Crdv%2FBw%2FCarUGNyTJ2fGaJwbVgIYsOmBnkmad5UuCDFTbdjMmZpBvkLeoTrB1Rh884SqMp6tl9MUAqdLeIg5cuK5xcs9GTuuUaq3oPz6O0mL6gm4MC4EqqDJyUEVmiol4QEknsrBg3GWb57i%2BFQ8uUH9VSmU85He3z%2B1Nc4hEHF9bhv0XEpS4TPm2V8pKs0LzkYEhclfbA%3D%7Ctkp%3ABk9SR6KEnMK_ZQ
  • »03.04.25 - 12:55
    Lord76
    Posts: 81 from 2014/8/31
    I buy this: https://www.ebay.de/itm/234679325502
    Powerbook G4 A1138/39
    Powermac G5 2.7ghz / G5 11.2 2.3ghz
    Amiga1200 V1200/Pistorm
  • »03.04.25 - 13:03
    Krisz
    Thanks!
    That's good too but it's only 6 pins!
    Will that be enough for all cards?
  • »03.04.25 - 13:12
    Krisz
    Radeon x1300 arrived today and it doesn't work
    I've already spent a fortune on video cards hoping to finally get the machine working, I'm getting bored
    MorphOS started loading from the CD, which the CD drive also indicated with a flashing LED, but after a few flashes it stopped, as if MorphOS was not compatible with the computer itself.
  • »07.04.25 - 08:36
    roschmyr
    Posts: 211 from 2003/2/20
    @Krisz
    did you have tried with the Nvidia to boot, some pciE G5. like mine, does not without a Mac compatible card installed
    i have installed from the top
    network
    nvidia
    radeon
  • »07.04.25 - 09:10
    beworld
    Posts: 683 from 2010/2/10
    Have you keep GeForce into your G5 and put your Radeon just above ?
    Wi thm y X1950 PCi, i need to have geforce to boot on CD
    My MOS ports
  • »07.04.25 - 09:11
    Krisz
    Unfortunately the x1300 has a heatsink that I couldn't put in the bottom pci-e slot because it didn't fit!
    the nvidia was placed in the bottom rail and the x1300 above it but there's no image and when I looked at the osx hardware info it didn't even see the x1300
    If I remove the HDD and only the MorphOS installation CD remains, it should automatically boot from the CD, right?
    So MOS should boot without nvidia
    I think the nvidia is only needed until I install the MOS system and then only the Radeon card should remain.However, I tried the card with MacPro 5.1 and it doesn't give a picture there either! Open core is installed so if the card worked then there would be a picture
    unfortunately they cheated me with this card :(
  • »07.04.25 - 09:23
    Posts: 1362 from 2004/2/8
    Take out the plastic deflector (I know the fans will rage, but it's just for testing) and put the X1300 in the bottom PCI-e slot. Then try to boot MorphOS and report what happens.
  • »07.04.25 - 11:15
    Krisz
    The card cannot fit into the lower rail because it is obstructed by the processor separator plate.
    [img]387IMG20250407132509.jpg[/img]
    [img]433IMG20250407132539.jpg[/img]
    [ Edited by Krisz 07.04.2025 - 14:34 ]
  • »07.04.25 - 11:33
    Krisz
    I removed the cooling on the bottom of the card so it fit in the lower pcie rail and put the nvidia in the one above it and connected the monitor to it
    so there was only a black screen and after a while the fans started spinning up!
    After I took out the Radeon card it worked again so unfortunately there is a problem with the video card
  • »07.04.25 - 12:06
    Posts: 2583 from 2003/2/24
    Spinning up the fans suggests that MorphOS has somehow crashed or not booted at all.
    From my experience (see Quad thread) one can either have no display but the CD booted to the language/ kbd selector as with the R5 230 or it completely fails as with the MacPro card.
  • »07.04.25 - 15:15
    roschmyr
    @Krisz
    does the MorphOS BootCD show up if you press and hold the Alt key after the chime?
    you will see this only on the nvida
  • »07.04.25 - 15:29
    Krisz
    I received a faulty card :(
    it doesn't work on MacPro 5.1 either
  • »07.04.25 - 15:48
    Krisz
    roschmyr wrote:
    @Krisz
    I tried but when the Radeon card was also in the machine, the Nvidia card didn't give a picture either.
    I'm looking for a card on eBay but everyone there wants to sell it for a very high price.
  • »07.04.25 - 15:51
    Careful X600XT refers to the build in GFX in the 20“ iMac.
    Such cards do not exist as Apple PCIe cards and PC cards don’t fall under the AtomBIOS compatibility.
    They might work in an X5000 or SAM which can handle PC BIOS.
    [ Edited by Kronos 07.04.2025 - 20:38 ]
  • »07.04.25 - 16:38
    Posts: 12572 from 2003/5/22
    > And the one on Ebay? should work with PowerMacG5 and Morphos right?
    Yes, all Radeon X1300 to X1950 cards with AtomBIOS *should* work.
  • »07.04.25 - 20:27
    Krisz
    But how do I know which x1300 and x1950 has atom bios?
    or do these 2 types all have this bios?
    And what about the Sapphire ATI Radeon X1600XT?
    is this also Atom BIOS?
    Unfortunately I couldn't find a cheap x1950 card and I don't want to pay again for a card I can't use
    the x1600xt is not expensive
    if it also works with atom bios I would buy it
    [ Edited by Krisz 08.04.2025 - 07:00 ]
  • »08.04.25 - 03:53
    If it's a card for x86/x64 Windows/Linux PCs (so not one for PPC/x86/x64 Macs), it has AtomBIOS.
    "X1300 to X1950" is a range and includes any X1600.
  • »08.04.25 - 05:32
    > I just looked at the compatibility list and only the
    > x1600 and x1600pro are listed, the xt is not there
    The compatibility list is incomplete, so the XT variant is supported, see:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=13334&forum=11 (#2)
    There are many more variants of several graphics cards missing in the list which are most likely compatible.
  • »08.04.25 - 08:12
    Krisz
    Thank you very much for your help and to the other members of the forum as well!
    Then I'll order the Radeon x1600xt
    But first I'll take another look to see if I can find a cheap x1950, it's definitely much better than the x1600
  • »08.04.25 - 09:56
    Lord76
    This works under MorphOS, very Silent and Fast Card
    HIS Radeon X1950 Pro ICE Q3 Turbo 256 MB GDDR3 (256-bit) 2x Dual Link DVI
    http://www.hisdigital.com/de/product2-77.shtml
    Sapphire Radeon X1950 Pro 265mb
    https://www.techpowerup.com/gpu-specs/sapphire-x1950-pro.b7825
    Have testet both Cards in G5 11.2 2.3ghz with MorphOS 3.19
    The question is whether it's possible to flash both cards with a Mac BIOS here. If so, which ROM should be used and where can it be found? Ideally, I'd like to remove the second graphics card (Nvidia 6600) as well.
    [ Editiert durch Lord76 11.04.2025 - 11:20 ]
  • »11.04.25 - 07:17
