G5 PowerMac videocard with MorphOS?
    Krisz
    Posts: 154 from 2023/3/22
    Kronos wrote:
    Slow is relative as G4s go from 0.45 to 1.8GHz and even some ultrarare 2.0.
    For GFX anything that isn’t a 9000 will be slow for sure.
    The new TinyGL does/should provide 3D support for all these cards, just no legacy W3D. Latest beta also omitted t3D for R600 but that should be fixed in 2 more weeks…..
    I found RADEON HD7570 1 GB for sale
    So can I use MorphOS with this card?
    The problem with it is that it is a low profile card but I will solve that
    Anyway, my Mac is a 1.75 GHZ G4
    And yes, the video card is also a 7xxx series
    So would I be better off with this HD 7570 card than with the Radeon X 1300Pro?
    Maybe there's also a RADEON HD4350 512MB and it has an HDMI port too! And normal profile
    Which of the 3 cards should I choose?
    [ Edited by Krisz 01.04.2025 - 14:19 ]
  • »01.04.25 - 11:15
    Posts: 12573 from 2003/5/22
    > HD cards are only supported in 2D applications by MorphOS, right?
    Yes. There was a TinyGL beta version with 3D support for TeraScale2 GPUs (R8xx/R9xx minus RV970), but an update removed this support. It's supposed to return, together with TeraScale1 (R6xx/R7xx) support, though.
    > Or is Wazp3D also possible with HD cards?
    In software rendering mode, yes.
  • »01.04.25 - 11:47
    > G4s go from 0.45 [...] GHz
    From 0.35 GHz even.
    ...except if it's an 8500 (LE).
    ...except Radeon HD cards with TeraScale3 (HD69xx) or GCN1/GCN2 (HD77xx-HD79xx, HD85xx-HD89xx) GPU, which are not even supported in 2D (at least officially (#32)).
  • »01.04.25 - 11:59
    Yes, but 2D-only and no overlay for now.
    > Maybe there's also a RADEON HD4350 512MB and it has an HDMI port too! [...]
    The X1300 is 3D-supported right now, the Radeon HD cards somewhen in the future. The HD4350 is 2D-supported with hardware overlay, the HD7570 without.
  • »01.04.25 - 12:11
    Krisz
    Thanks!
    Then I'll buy the radeon x1300pro for now and later if there is support I'll replace it with an HD card
  • »01.04.25 - 15:25
    Lord76
    Posts: 81 from 2014/8/31
    This Card here works with PowerMac 11.2 PCI-E Modells:
    Sapphire x1950pro PC-Version with 256mb VRAM PCI-E
    https://tpucdn.com/gpu-specs/images/c/969-front.small.jpg
    [ Editiert durch Lord76 03.04.2025 - 15:24 ]
    Powerbook G4 A1138/39
    Powermac G5 2.7ghz / G5 11.2 2.3ghz
    Amiga1200 V1200/Pistorm
  • »03.04.25 - 11:16
    Krisz
    Thanks!
    A Radeon x1300Pro card is on its way
    It will be good for now and I will buy a more powerful card later
  • »03.04.25 - 11:33
    Lord76
    But only under MorphOS, have this in X16 Slot and in the upper Slot Nvidia 6600 , Network works with TP-Link TG-3468 PCI-E Card
    [ Editiert durch Lord76 03.04.2025 - 15:39 ]
  • »03.04.25 - 11:37
    Krisz
    Thanks for the advice!
    I use the internet with the Power Mac's factory built-in adapter!
    works flawlessly.
    I would rather have a Wifi/Bluetooth card that is compatible with the G5 P.M and is also supported by MorphOS
  • »03.04.25 - 11:45
    Lord76
    I only set up the G5 today and just quickly checked if the network and GPU were working. I've had it for a while, but I haven't had time to test anything because I was missing the GPU and network card until today :-)
    Oh, and you also need the power adapter for the graphics card, which fits onto the logic board:
    https://www.ebay.de/itm/234679325502
  • »03.04.25 - 11:54
    Krisz
    Then have fun with the G5 :)
    My Mac Pro has been sitting in the attic for years
    I just cleaned it up and I want to use it with MorphOS so I can play old Amiga games when I have time
    I tried it with a G4 Power Mac before, but it was really slow! There were some 2DS games that ran sluggishly on it. :D
    I hope I won't have such problems with the g5. Later, if there is 3D support for HD cards on MorphOS, I will buy a video card that also has an HDMI connection.
    HD video cards require an additional power supply, which I don't know yet, how where will I get it from on the G-5 motherboard?
    If I remember correctly, the G5 Power Mac motherboard does not have a connector for the additional power supply for the video card.
    Maybe I'll run the wires from the power supply to the 6-pin connector.
    [ Edited by Krisz 03.04.2025 - 15:23 ]
  • »03.04.25 - 12:20
    Lord76
    Not correct, it has a 6-pin connector on the logic board if you have a PowerMac 11.2 PCI-E.
  • »03.04.25 - 12:24
    Krisz
    Yes, it's an 11.2 machine
    but where do I find the connector?
    I'll check the motherboard!
  • »03.04.25 - 12:36
    Lord76
    Between the fan with the built-in speaker and the PCI card holder, below the DVD-ROM.
    [ Editiert durch Lord76 03.04.2025 - 16:45 ]
  • »03.04.25 - 12:42
    Krisz
    Thanks!
    There is indeed a connector there but unfortunately I don't have a cable with such a connector
    You can probably get it on Ebay
  • »03.04.25 - 12:50
    Krisz
    Thanks!
    I found it!
    https://www.ebay.com/itm/295839385515?_skw=Power+Mac+g5+videocard+power+supply&itmmeta=01JQY27088H0P33NZNPQWAJ2NJ&hash=item44e166c7ab:g:BM0AAOSwKn5kwJkG&itmprp=enc%3AAQAKAAABAFkggFvd1GGDu0w3yXCmi1e7ZQtwRGfELhGlsYGC6SrTaFeU46VHUZVmGYJwiMnTOHeoQH6kXAHmejAWG7rMOZb0fP0SzwC9IbhCkdJu%2B6KfzYviD3nVqgq%2FX10CjAcS46eStzzvI4GR2Crdv%2FBw%2FCarUGNyTJ2fGaJwbVgIYsOmBnkmad5UuCDFTbdjMmZpBvkLeoTrB1Rh884SqMp6tl9MUAqdLeIg5cuK5xcs9GTuuUaq3oPz6O0mL6gm4MC4EqqDJyUEVmiol4QEknsrBg3GWb57i%2BFQ8uUH9VSmU85He3z%2B1Nc4hEHF9bhv0XEpS4TPm2V8pKs0LzkYEhclfbA%3D%7Ctkp%3ABk9SR6KEnMK_ZQ
  • »03.04.25 - 12:55
    Lord76
    I buy this: https://www.ebay.de/itm/234679325502
  • »03.04.25 - 13:03
    Krisz
    Thanks!
    That's good too but it's only 6 pins!
    Will that be enough for all cards?
  • »03.04.25 - 13:12
    Krisz
    Radeon x1300 arrived today and it doesn't work
    I've already spent a fortune on video cards hoping to finally get the machine working, I'm getting bored
    MorphOS started loading from the CD, which the CD drive also indicated with a flashing LED, but after a few flashes it stopped, as if MorphOS was not compatible with the computer itself.
  • »07.04.25 - 08:36
    roschmyr
    Posts: 211 from 2003/2/20
    @Krisz
    did you have tried with the Nvidia to boot, some pciE G5. like mine, does not without a Mac compatible card installed
    i have installed from the top
    network
    nvidia
    radeon
  • »07.04.25 - 09:10
    beworld
    Posts: 683 from 2010/2/10
    Have you keep GeForce into your G5 and put your Radeon just above ?
    Wi thm y X1950 PCi, i need to have geforce to boot on CD
    My MOS ports
  • »07.04.25 - 09:11
    Krisz
    Unfortunately the x1300 has a heatsink that I couldn't put in the bottom pci-e slot because it didn't fit!
    the nvidia was placed in the bottom rail and the x1300 above it but there's no image and when I looked at the osx hardware info it didn't even see the x1300
    If I remove the HDD and only the MorphOS installation CD remains, it should automatically boot from the CD, right?
    So MOS should boot without nvidia
    I think the nvidia is only needed until I install the MOS system and then only the Radeon card should remain.However, I tried the card with MacPro 5.1 and it doesn't give a picture there either! Open core is installed so if the card worked then there would be a picture
    unfortunately they cheated me with this card :(
  • »07.04.25 - 09:23
    Posts: 1362 from 2004/2/8
    Take out the plastic deflector (I know the fans will rage, but it's just for testing) and put the X1300 in the bottom PCI-e slot. Then try to boot MorphOS and report what happens.
  • »07.04.25 - 11:15
    Krisz
    The card cannot fit into the lower rail because it is obstructed by the processor separator plate.
    [img]387IMG20250407132509.jpg[/img]
    [img]433IMG20250407132539.jpg[/img]
    [ Edited by Krisz 07.04.2025 - 14:34 ]
  • »07.04.25 - 11:33
    Krisz
    I removed the cooling on the bottom of the card so it fit in the lower pcie rail and put the nvidia in the one above it and connected the monitor to it
    so there was only a black screen and after a while the fans started spinning up!
    After I took out the Radeon card it worked again so unfortunately there is a problem with the video card
  • »07.04.25 - 12:06
