Recent Video Drivers and PCIe cards on PowerMac 11,2.
    matt3
    Posts: 764 from 2004/2/10
    I'm pretty sure the results on a X5000 and PowerMac PCIe PPC will be different since:
    1. Bigfoot is developing on a X5000.
    2. The way PCIe is handled by both systems is different.
    Perhaps we can purchase Bigfoot a local PowerMac for him to test his drivers and donate to the MorphOS team to encourage the official support of these PowerMacs.
  • »26.09.23 - 09:16
    Posts: 12479 from 2003/5/22
    Yes, it's been well established that the PCIe graphics cards that don't work on PowerMac11,2 usually do work on X5000. ernsteiswuerfel (and others?) are in the process of finding a pattern regarding what it is that makes cards fail on PowerMac11,2.
  • »26.09.23 - 17:09
    matt3
    Recently either the little DVI to DP device failed (not showing green) or the DVI port in my new monitor failed.
    So I went back to a DVI to HDMI cable and it works perfectly.
    Is there a better standard to use? DP or HDMI?
  • »07.10.23 - 18:04
