Mac Mini G4 thermal sensor
    MoerBoer
    Posts: 239 from 2019/10/15
    sailor wrote:
    MoerBoer wrote:
    Very cool article! Nicely done sailor.
    Now do an Imac G5 iSight :)
    Thanks!
    And I buyed at ebay very very cheap two iMac iSights. For parts, but good for experimets. We will see.
    Ooh! That sounds exciting!
  • »26.05.22 - 07:20
    Posts: 477 from 2019/5/9
    But don't look forward to it, because now it's the AmigaOne XE's turn - I receive one from colleague from US and I want to upgrade and optimize her.
    Imac - it is run on a long track - and I hate to dissassemly this all-in-ones.
    [ Edited by sailor 26.05.2022 - 18:05 ]
  • »26.05.22 - 14:03
    MoerBoer
    It's actually not that hard if you follow the iFixit steps. I recently re-applied thermal paste to mine and you basically have to take the whole thing apart.
    Biggest hurdle is getting the clips at the top lose with a credit card.
  • »27.05.22 - 07:54
    NewSense
    Posts: 1615 from 2012/11/9
    MoerBoer wrote: Biggest hurdle is getting the clips at the top loose with a credit card.
    I find it much easier using an old HDD magnet held against the front corners of the top of the screen surround/fascia from a failed HDD or some other magnet you might have about the house, but it does need to have quite a strong pull/magnetic attraction. :-D
    That fiddling about with a credit card or similar tool never appealed to me. 8-D
  • »27.05.22 - 21:31
