Important Notice regarding X5000 Firmware Updates
    bigfoot
    Posts: 510 from 2003/4/11
    KennyR wrote:
    So probably best to avoid these updates if you plan running MorphOS, unless they do something useful like power down the unused cores.
    Unfortunately not even that would be a good excuse. MorphOS already does power down the unused cores, and doing so doesn't actually require booting them and taking them over. You can do it entirely - and easily - from the boot core.
  • »30.10.22 - 04:57
    Posts: 12408 from 2003/5/22
    Very nice :-) Has this been the case since MorphOS 3.10 or been added later? I don't remember I already read this, at least looking through the release notes since 3.10 I cannot find anything with respect to this.
    Btw, has this feature also been added for PowerMac11 (PPC970MP) meanwhile? (I know that generation isn't officially supported, and that MorphOS supports this on PowerMac7 (PPC970/PPC970FX) since MorphOS 3.10).
  • »30.10.22 - 08:50
    bigfoot
    It's been this way since MorphOS 3.10
    Btw, has this feature also been added for PowerMac11 (PPC970MP) meanwhile? (I know that generation isn't officially support, and that MorphOS supports this on PowerMac7 (PPC970/PPC970FX)).
    I don't know, sorry :)
  • »30.10.22 - 09:27
    Posts: 1335 from 2004/2/8
    I can only hope the answer is 'no' as my QUAD consumes approximately 280W when idle.
    If that would be on just one CPU core that would be insane.
  • »12.01.23 - 09:54
    Posts: 545 from 2003/4/11
    Are you planning to win the morph.zone thread off-topic price of the day and did you check that without gfxcard ? :)
  • »12.01.23 - 10:01
    > 280W when idle. If that would be on just one CPU core that would be insane.
    Btw, regarding PowerMac7, there've been findings reported in another thread based on temperature sensor signal suggesting that the 2nd CPU is not completely disabled. So far, I've not seen any explanation what "Disabled the second CPU on PowerMac7 machines" really means technically.
  • »12.01.23 - 13:00
