X5000 GPU Recommendation?
  • ASiegel
    Posts: 1399 from 2003/2/15
    I will say my perception from this experience is some of the MOS team comes across as hyper sensitive cry babies. Instead of getting angry at users asking questions and blaming others but not looking in the mirror until now is really sad.
    No good deed goes unpunished.
  • »29.05.22 - 05:50
    Posts: 2732 from 2003/2/24
    What an unnecessary insulting comment. Totally uncalled for. Where on earth did that come from?
  • »29.05.22 - 05:55
    MoerBoer
    Posts: 240 from 2019/10/15
    OP gets the fix they wanted and then goes on a rampage attacking the developers.
    Boggles the mind...
  • »29.05.22 - 06:54
    Posts: 12575 from 2003/5/22
    > Was the bug more complicated than hardcoded expectation
    > of the display adapter being in the x16 slot?
    At least my impression, which may very well be plain wrong, from the relevant thread (which fell victim to the recent data loss unfortunately) was that bigfoot was easily able to identify the nature of the bug (as his initial hunch in that thread proved true). To me it seemed that it wasn't that hard for him to incorporate the actual fix also.
    Assuming that this impression isn't too far from the truth, I must admit I've been somewhat puzzled that it took 4 years of reporting this issue here on MorphZone before it was eventually taken on.
  • »29.05.22 - 09:51
    bigfoot
    Posts: 510 from 2003/4/11
    I seem to remember that I did write a somewhat detailed explanation of what the problems were, but it got lost in said data loss. What I don't understand is why some people seem to jump to conclusions, that it was just a matter of flipping a switch, a tiny change to somehow make MorphOS "search" for a graphics card in the right slot, and the MorphOS developers were just too lazy to do this tiny change.
    I honestly don't want to go into too many technical details once again, but let me just say that that is not how MorphOS (or any other operating system really) works. Nobody looks for a specific card in a specific slot. The PCI (express) bus(es) get scanned, and then the operating system makes an API available that allows drivers to find cards, usually based on the card's device and vendor IDs. At no point does any specific slot come into this equation.
    When it comes to fixing this issue, first you gotta realise that it involves are quite uncommon hardware setup, and not one that is readily available. Initially there was no MorphOS developer who had such a setup, or could create such a setup, without investing in additional hardware.
    Fixing this issue spanned a duration of 2.5 weeks. Of course not 2.5 weeks of non-stop work on this issue, but it definitely wasn't a simple matter of just flipping a switch. I did have an initial idea of what the problem was, one I believed I could fix without having access to this setup myself. So I went ahead and did just that, and I enlisted the help of a person here on MorphZone with the prerequisite setup for testing.
    It turned out that while my "blind" fix was indeed correct, it wasn't the only problem preventing MorphOS from booting with multiple Radeons installed, and figuring out the remaining problems would take too long without having such a setup myself, so I went out and bought a PCI Express riser card so I could run my own X5000 with two graphics cards. From there on, I identified multiple different problems that all contributed to this problem, and I fixed them all.
    All in all, the diff for the cumulative fixes that made MorphOS boot with multiple Radeons in the X5000 is almost 1000 lines long. It was not a simple fix.
  • »29.05.22 - 10:59
    Seems the data loss occurred too soon after you wrote that detailed explanation for me to read it. If I had, my previous comment would surely have come out differently.
    > […] It turned out that while my "blind" fix was indeed correct, it wasn't the
    > installed […]. From there on, I identified multiple different problems that all
    > contributed to this problem, and I fixed them all. All in all, the diff for
    Thank you for the insight.
  • »29.05.22 - 11:56
    Posts: 1933 from 2003/10/19
    So can we now boot an X5000 with the two cards and OS4 doesnt choke on having two? I havent tried this and just saw the update supports two cards now. Pretty impressive solution.
    What about a 2nd HDD installed with MorphOS on it, will this work out of the box if I put in a 2nd card and replaced the DVD with my MorphOS SATA drive?
    [ Edited by Acill 29.05.2022 - 08:58 ]
  • »29.05.22 - 12:54
    > on having two?
    Yes, but OS4 still requires its card in the primary slot, else there wouldn't have been any problem as the MorphOS card has always worked in the primary slot and OS4 would have simply used its card in the secondary slot (which it cannot, at least with the primary slot in use).
    As is known from running dual-boot OS4/Linux on X5000, OS4 running on the primary card isn't disturbed by a secondary card.
  • »29.05.22 - 13:44
    bigfoot
    The logic is slightly faulty here, and it might be caused by the previous (wrong) speculation. I have no idea if AmigaOS 4 can or cannot boot with its graphics card in a non-primary slot, but in the case of MorphOS, it couldn't boot at all with a Radeon in anything but the primary (x16) slot. At all. It wouldn't even get to the point where it would try to load the Radeon driver.
  • »30.05.22 - 08:36
    IIRC from the discussions over the years, if there're two OS4-compatible graphics cards installed in the X5000, OS4 will always use the one in the primary slot. There's no way to make OS4 ignore the card in the X5000's primary slot and use the (better supported) one in the secondary slot instead (or in addition). This was stated as an unfortunate regression from the X1000 where OS4 can even use two graphics cards concurrently in a dual-GPU setup. I have no idea though about OS4-incompatible graphics cards in the X5000's primary slot as all MorphOS-compatible graphics cards are also OS4-compatible to the extent that OS4 can boot with them.
    > MorphOS [...] couldn't boot at all with a Radeon in anything
    Thanks for the clarification. Do I understand the situation right that pre-3.17, MorphOS couldn't even boot with a MorphOS-compatible card in the X5000's primary slot as long as another Radeon (MorphOS-compatible or not) was inserted into the secondary slot?
  • »30.05.22 - 12:15
    bigfoot
    Yes, you're understanding it right. And technically it didn't specifically have to be a Radeon, but any set of PCI devices with the right set of PCI memory bases could trigger this bug. Radeons in general just do that reliably.
  • »30.05.22 - 12:29
    Posts: 7 from 2020/5/23
    Thank you bigfoot for fixing the bug that was preventing myself (and perhaps other x5000 owners) from using MorphOS.
    I ordered a 1950 XTX and will order a riser adapter soon.
    It is a nice benefit that the 1950 XTX PCB is red, as is the semi-transparent wind tunnel matching the x5000 PCB. My Define has a tinted glass side panel.
    Luckily I checked and have a Corsair 750 PSU, as I thought I had put a SF450 in the machine.
    Reading up on the cards they both seem to be power hungry.
    This is the best of both worlds for me. A ~2006 GPU for MOS, and a ~2018 GPU for AOS-maximizing capabilities on each OS.
    Some may not like statement of my impression(s) of the MOS teams response to potential new users and that is OK.
    I think it is important the team be told how they interact with their own user base.
    Do what you will with this feedback.
    Now that this bug has been fixed all x5000 users stand to benefit.
  • »31.05.22 - 00:49
