How to run MorphOS on unsupported G5 PCIe
    Doffo
    Posts: 507 from 2010/10/14
    amigadave wrote:
    Doffo wrote:
    ThePlayer wrote:
    Andreas_Wolf schrieb:
    > So you are using two GFX Cards in your G5? One Nvidia Mac and a Radeon PC?
    He's apparently not the only one who does, see comments #3 and #6 for instance.
    > does somebody know what is the latest Radeon supported by OSX 10.5.8 PPC?
    X1900 GT Mac edition. Other X19x0 cards may be supported when flashed with the PPC ROM from the X1900 GT Mac edition.
    That is great, so one can use easily a PC Radeon and don`t care about flashing.
    So no Driver Support on 10.5.8 of 2xxx and 3xxx Radeon?
    Did someone Bench the G5 2,7 AGP against Quad G5 2,5 Ghz in Games and MKV 1080p playback?
    I`ve heard that the Quad should be faster because of the RAM and BUS.
    I personally wanted to try different things like this. See how good certain videos played on the PCI-E Mac G5 vs the older G5.
    My Quad 2.5 turned out to be a lemon. The LCS is toast, and "rebuilding it" proved to be wasteful as I had a hard time getting it to properly fill etc.. The Pump itself might be ruined since it was basically empty.
    No worries, gonna source me a single cpu/dual core G5 in time.
    If you're just going to recycle, or trash your Quad core G5, let me know. I wouldn't mind trying to fix it for myself, if all I need to do is drive to Nevada from California to get it. I could swap another G5 system with you. I have a spare Dual 2.7GHz G5 PowerMac that has the demo version of MorphOS already installed on it and appears to run great, but I would want to remove the video card I currently have in it, so you would need to provide your own video card. I also have a Dual 2.5GHz G5 system that has damage to the motherboard, which only allows one of the two G5 CPU's to run/show up as running, which does not matter for MorphOS, which only currently uses a single G5 CPU. If either of those system is easier for you to convert to air cooled heat sinks, you are welcome to either of them in exchange for your Quad core G5 PowerMac 11.2 model.
    Unfortunately, I moved to Kansas a month and a half ago. Thanks for the offer though. For now, after a Single CPU/Dual Core model that I can swap out a CPU out of into it. The lousy liquid cooling system was hard to even do much with as the actual pump itself may of failed and not strong enough to push the liquid through. All is well. :)
    YUUUP!
  • »24.11.19 - 05:51
    Posts: 2793 from 2006/3/21
    I would think that it would be better for you to just replace the liquid cooling system from another Quad Core G5 PowerMac 11.2, as they all had the best liquid cooling pumps of all the liquid cooled G5's that Apple made. Unfortunately, most failures in all of the liquid cooled G5's were probably due to a leak in the cooling system, or failed cooling pump, and all of the Quad Core G5's still working, it would not make sense to remove the cooling system from one just to put it into another Quad Core G5.
    Good luck with your plans to get a G5 system that you can run MorphOS3.12 (and beyond) on. I'm betting that you will enjoy it, once you have used it more often.
  • »24.11.19 - 19:23
    Flash
    Posts: 105 from 2019/11/1
    The pcie ATI x1900gt is latest card supported by macosx 10.5.8 for powermacs.
    Under morphos 3.12 it can be used in combination with native nvidia 6600 pcie card, using an pcie 8x free slot.
    It can be also flashed with a powermac rom on a pc under msdos and atiflash tool.
    Be careful because there are two version of x1900gt one with extra power connector on the top/left
    radeon-x1900-gt.c173#gallery-1
    and another with power connector on the middle/left
    in my experience only the first can be modded in an original powermac ati x1900gt and so use only one video card instead of two.
    I don't know if you can flash an ATI 1900xt card into a genuine powermac x1900gt, if someone has tested it please let us know.
    About powermacs g5 quad I have to say it's a big beast and LCS issues are a big mistake.
    On my G5 quad I had to rebuild the whole cooling system using special liquid cooled nordbrige heatsink and a special liquid metal thermal compound.
    Now I have the fastest amiga ever seen..
  • »24.11.19 - 21:18
    zukow
    Posts: 642 from 2005/2/9
    I have X1950XT flashed with Apple Bios, it runs without problem
  • »24.11.19 - 21:25
    Flash
    Is it shappire brand? how much memory has on board 256 or 512mb? Do you have used it also un mac osx? Is it the only video card present in your mac? is it suited on pcie 16x slot?
    Anyway thanks for your feedback, i'd like to know if also an x1950gt or x1950pro could be ok.
  • »24.11.19 - 22:10
    ernsteiswuerfel
    Posts: 545 from 2015/6/18
    I got this card cheaply, 256 MiB version. I plan to flash it. Only waiting for my MoBo->PCIe power cable to arrive. ;-) I'll let you know about the results. Don't run MacOS on the G5 but Linux.
    And congrats for your worlds fastest Amiga! :-) This surely was hard work...
  • »25.11.19 - 18:20
    zukow
    @Flash
    I explained in the first post in this thread and added photos of my cards. Yes, it's sapphire 512MB X1950XT. Works under OF/MorphOS/MacosX 10.5 (under 10.4 i got b-w screen). Doom3 works pretty well under MacosX. Far better when using NVidia.
  • »25.11.19 - 19:43
    Doffo
    Opened up the LCS again, and discovered a much worse problem underneath. The part that actually goes to the CPU was beyond clogged that nothing would ever pass it. (Along with the lousy filter put on the intake side.) I made room by removing some of the little goofy plastic fins, so now if the fins clog up, water can still move around and not just stop again.
    She is up and running. :)
    YUUUP!
  • »26.11.19 - 10:47
    Posts: 357 from 2019/5/9
    zukow wrote:
    Hi, some remarks from your unsupport team.
    1. Prepare a CD with MorphOS 3.12
    - for quick test you can put HD from existing PowerMac G5 AGP machine to PCIe one
    - sound is supported
    - ide is supported
    - sata is supported
    - usb is supported
    - fans handling is supported
    - temperature sensors are supported
    - onboard lan is not supported
    - pcie Rs232 cards for getting debuglog may work (but i have one and it doesn't)
    2. Add some supported Radeon card
    Many thanks to MorphOS developers. I had my quad G5 three years at home for this moment.
    Everything works fine as written, I succeed to buy cheap original powermac X1900. Now I waiting only for ordered NIC adapter and then I can register another MorphOS.
    some quick notes:
    - performance is great, Quake 3 = 60.1fps, Tower57 = 62fps, 1941 = 140fps
    - internal speaker allways on. Is this my HW problem or is it connected with OS+mixer? I will check later with linux and MacOS
    - graphics board detected correctly, Utilities/GraphicBoard don't show frequencies
    - System monitor recognizes two CPUs.
    - SDLBench crashes, but SDL games works
    - GraphicSpeed crashes at the end - it can be connected with unregistered MOS and slowing down ?
    - USB mouse don't work after boot. (wrong port status 0103). Restart of Poseidon doesn't help, plug and unplug yes.
    Good work!!!
    [ Edited by sailor 26.11.2019 - 20:27 ]
    AmigaOS4: Micro A1-C, AmigaOne XE, Pegasos II, Sam440ep, Sam440ep-flex, AmigaOneX1000
    MorphOS: Efika 5200b, Pegasos I, Pegasos II, Powerbook G4, Mac Mini, iMac G5, Powermac G5 Quad
  • »26.11.19 - 11:04
    Doffo
    sailor wrote:
    some quick notes:
    - performance is great, Quake 3 = 60.1fps, Tower97 = 62fps, 1941 = 140fps
    You should be getting a ton more FPS on Quake 3. ;)
    From Redrumloa's post in 2012:
    Using parameters by Piru for benchmarking the driver:
    setenv TGLSYNC 0
    flushlib tinygl.library
    And under Quake 3 (All details maxed out):
    r_primitives 2
    timedemo 1
    demo four
    YUUUP!
  • »26.11.19 - 11:09
    setenv TGLSYNC 0
    r_primitives 2
    timedemo 1
    demo four
    Thanks, it was only quick test to compare it with my Peg2 (41fps) iMac (53fps) and A1X1000 (86 fps).
    With registered MOS I will try this Quake optimalizations.
  • »26.11.19 - 11:31
    Doffo
    setenv TGLSYNC 0
    r_primitives 2
    timedemo 1
    demo four
    You will be in for a surprise. :) Enjoy!
    YUUUP!
  • »26.11.19 - 11:37
    Posts: 1246 from 2004/2/8
    That 60 FPS is because vertical sync with your monitor refresh rate. Try running Tower57 in windowed mode or Quake 3 without vsync.
  • »26.11.19 - 13:20
    You are right! Powermac G5 Quad with X1900 G5 version - Quake 3: 170 fps!!!
  • »26.11.19 - 18:09
    Still, X1950 GT (AGP version) on my G5 Dual Processor 2,7 GHz does 153 FPS (in 1600x1200). I thought Quad (with its PCIe and DDR2) would do much better.
    [ Edited by koszer 26.11.2019 - 20:14 ]
  • »26.11.19 - 19:14
    Doffo
    I just tested it on my end.
    Video Mode : 1600x1200
    Color Depth : Default
    Fullscreen : On
    Lighting : Lightmap
    Geometric Detail : High
    Texture Detail : Max
    Texture Quality : Default
    Texture Filter : Trilinear
    184 FPS Using those settings.
    Using vertex instead of lightmap for Lighting yielded 200 FPS.
    :) A PC Sapphire x1900 XT 512 MB. Doesn't have a flashed Mac bios.
    YUUUP!
  • »27.11.19 - 06:11
    Excellent! For me is enough all above 30. ;-) I don't play fps games, only for testing.
    But I am glad that Quad is now "supported".
  • »27.11.19 - 06:46
    Doffo
    Definitely worth it. I had to tear down the LCS and redo it all. This one was basically empty and didn't know of its condition when I brought it home. Glad the CPUs didn't fry.
    YUUUP!
  • »27.11.19 - 13:04
    ernsteiswuerfel
    Meanwhile I tried a Sapphire Radeon X1550 (512MB, PC-BIOS, see picture). A nice passively cooled card with low power draw (~28W), but this one does not work. Installed it in the 2nd slot, a Nvidia GF6600 is in the 1st one.
    MorphOS 3.12 boots into the desktop, but I got garbled colours (funny rgb dots, horizontally segmented by 5mm wihte lines) though the mouse pointer looks ok and works as intended. The machine is usable, but the colours are that garbled you can't do anything meaningful.
    Linux gives me this data about the card:
    # lspci -vv -s 0001:06:00.1
    0001:06:00.1 Display controller: Advanced Micro Devices, Inc. [AMD/ATI] RV516 [Radeon X1300/X1550 Series] (Secondary)
    Subsystem: PC Partner Limited / Sapphire Technology RV516 [Radeon X1300/X1550 Series] (Secondary)
    Control: I/O- Mem- BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
    Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
    Latency: 0, Cache Line Size: 64 bytes
    Region 0: Memory at 80100000 (64-bit, non-prefetchable) [disabled] [size=64K]
    Capabilities: [50] Power Management version 2
    Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
    Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
    Capabilities: [58] Express (v1) Endpoint, MSI 00
    DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <4us, L1 unlimited
    ExtTag- AttnBtn- AttnInd- PwrInd- RBE- FLReset- SlotPowerLimit 0.000W
    DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
    RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
    MaxPayload 128 bytes, MaxReadReq 128 bytes
    DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
    LnkCap: Port #0, Speed 2.5GT/s, Width x16, ASPM L0s L1, Exit Latency L0s <64ns, L1 <1us
    ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
    LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
    ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
    LnkSta: Speed 2.5GT/s, Width x8, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
  • »27.11.19 - 15:38
    Doffo
    Have you tried using the x1550 under Linux? I have an AGP x1300 that was ruined. Showed up, but colour artifacting like crazy and really unusable. Maybe your GPU suffered the same fate?
    At least if you boot up with linux, you can see how it appears to see if it is the GPU or something to do with MorphOS.
    YUUUP!
  • »27.11.19 - 19:16
    I have some minor non-working thing:
    after rebooting mouse not works on PmacG5 Quad.
    ERR: wrong port status 0103 for port 2
    strange port response, power-cycling port 2
    Restart of Poseidon stack not helps, unplug and plug the mice yes.
    I don't know if it is connected with MOS (on G5 linux & MacOS mice works) or I have bad mouses ( my Powerbook G4 have the same error).
    Do you have similar issues with Mac&Mouse ?
  • »28.11.19 - 08:21
    What mouse model? Connected directly or through some sort of hub?
  • »28.11.19 - 08:25
    cheap mouses, model I will check at home, if there are any label. Connected directly. The same issue on all USB ports.
    The same mouses I tried on Peg2, IMacG5 and bananapro and it works.
    If other people have no this problem, it points to mouses. I will test some other mouses with my Pmac and Pbook and let you know. And try connect with powered hub.
  • »28.11.19 - 08:48
    Doffo
    I believe there are some USB issues this time around that will be addressed on the next release regarding USB devices on startup. No worries, maybe find another cheap mouse to try. I use a Logitech G105 keyboard and a Logitech G302 mouse. Works every time I boot into MOS and after every restart.
    [ Edited by Doffo 28.11.2019 - 10:01 ]
    YUUUP!
  • »28.11.19 - 16:00
    Doffo
    To add to your issues, once booted into MorphOS, my Razor Kraken USB headset worked! :) Though you can't control the volume on it or even set it on the settings on the bar up top to have it control the Kraken, it was damn cool to hear audio out of my USB headset.
    Though, once rebooting with the headset in, it kept the entire system from even starting up at all into MorphOS. I had to disconnect the headset from USB, then things returned to normal.
    Still though! Audio through the USB headset was neat.
    YUUUP!
  • »28.11.19 - 19:38
