Pegasos 2 HDD/SSD SATA options
    Jeckel
    Posts: 133 from 2007/3/11
    > How to you know the board revision?
    It's printed on the board.
    Ok, found it! It is rev 2B5. :)
  • »08.06.19 - 11:26
    Posts: 12408 from 2003/5/22
    So in your case it's no surprise that 2× 1 GiB works :-)
  • »08.06.19 - 15:44
    Jeckel
    Well, I had several dimm pairs that didn't operate stable before this one (most pairs I tested worked single but not dual).
  • »08.06.19 - 20:15
    Yes, see comment #31 :-)
  • »09.06.19 - 04:05
    Cego
    Posts: 738 from 2006/5/27
    Is it possible to boot MorphOS from a sil3114 PCI card completely or do I have to install the boot.img file on a hard disk on the IDE port?
    Does MorphOS 1.4.5 also support SATA PCI cards?
    Thank you
  • »14.05.20 - 17:24
    Posts: 1326 from 2010/1/6
    I think, PEG OpenFirmware does not support such card. Do a test! If it occours in device-tree, it could work. If no dev-alias is generated, you may have to set full hardwarepath to boot from there.....
    To MOS hardwarecompatibility to MOS1.4 .5 you have to ask MOS-Team.....
    Btw: Why useing MOS1.4.5 on PEG??
    [ Editiert durch Amigaharry2 14.05.2020 - 21:55 ]
  • »14.05.20 - 17:51
    SATA support came with MorphOS 2.5.
  • »14.05.20 - 18:15
    connor
    Posts: 650 from 2007/7/29
    Sailor: your screenshot in the first message cannot be viewed: Error 451!
    The page is blocked due to the decision of the authorities in your area.
    Can you include it in the text or upload it to another place?
    I would be happy if my Pegasos 2 would be as fast as yours. I mean the Pegasos itself is fast but harddrives are always slow when I copy files. I don’t know why but I only get transfer rates of 1MB/s in average when I copy big files like images, sound files, videos. This is on the IDE drive and the SATA drives. Even on SATA drive with the ulsata device you mention I only get this slow speed. This is much worse than USB! What can be wrong? Which settings can I check?
    I have not upgraded my Pegasos 2, it is still G4 at 1GHz.
    > https://www.probers.cz/jak-pretaktovat-procesor-u-pegasose-ii/
    Wow, that’s a monster cooler! Does it not pull out the CPU card because of the big size and heavy weight? I would fear that could damage the CPU card and slot and mainboard.
    You write:
    > Only things what I did against this is new power supply and proper cooling:
    I used oversized passive cooler with fan, passive cooler on RAM, passive coolers on Northbridge and Southbridge.
    But on the pictures I see only active coollers (fans). Do you have other pcitures? And which passive colllers do you use?
    > And if, please can you check the morphos-debug.log, if your drives recognized like UDMA5=100MB/s or UDMA6=133MB/s.
    How can I do this?
    > PCI HD 5450
    Is that the best card for the Pegasos 2?
    > > I cannot find pair of RAMs which have no errors
    > 2× 1 GiB can only work error-free on revision 2B5 boards.
    I have that board. Which RAM do I have to buy?
  • »15.05.20 - 09:08
    >> PCI HD 5450
    It's the newest one at least. MorphOS doesn't support 3D acceleration or overlay with this card, though. Also, SmartFirmware won't show on this card (or any other card with a bridge chip).
  • »15.05.20 - 09:45
    Posts: 422 from 2019/5/9
    I see. They changed the rules, obviously.
    I will do it.
    I am sure that default morphos settings are OK. Simply I don't know. Maybe try to increase number of buffers - what is your actual number?
    1GHz is not bad, MorphOS is very lightweight, but 1.3 is very good for internet etc..
    Yes this one and also my actual cooler (ARCTIC Alpine M1-Passive Socket AM1) are oversized. I calculated that overclocked CPU MPC7447 have less then 30W TDP. You can use some smaller if you want, but it is quite difficult find some which fits on CPU card. And motherboard+cpucard are OK. I will post photo somewhere.
    >You write:
    I will post photos.
    >How can I do this?
    the easiest way is to use builtin Screenbar module: Debug
    You can see here all boot messages
    > PCI HD 5450
    HD 5450 PCI - newest, 2D, no overlay, 19W only
    HD 4350 PCI - 2D, hardware overlay, 20W only
    9800 PRO AGP - 2D, 3D, 47W.
    It depends, what you want to do with your Peg. But I do not tried the PCI cards.
    you can try this-modules or this - they works each at least on one Pegasos2. But you have no guarantee, you have to try them.
  • »15.05.20 - 10:56
    See here:
    Peg2(1.33GHz) Controllers Comparison
    [ Edited by sailor 18.05.2020 - 09:37 ]
  • »18.05.20 - 05:36
    Here some photos of ARCTIC Alpine M1-Passive Socket AM1 ( with fan ;-))
    Previously used Thermalright HR-05 SLI blocked IDE connectors.
    00-arctic1.jpg 01-arctic2.jpg 02-arctic2a.jpg 03-arctic3.jpg 04-arctic4.jpg 05-arctic5.jpg
  • »18.05.20 - 06:07
    connor
    See here:
    Thank you. So for this byte aligned (what ever it is) transfers you also get only low data rate like 1 or 2 MB/s. Maybe all my copy processes (ambient or CLI) from one partition to another are byte aligned and it is so slow on my Peg because of this?
  • »18.05.20 - 14:53
    connor
    Wow, thats a huge block! I don't have the tools to cut this in the right size. And in the end you also need a fan on top of the cooler. So it still makes noise. But impressive cube :-)
  • »18.05.20 - 14:55
    connor
    It is 64 on all partitions. This is the default that HDConfig sets.
    I would want to have it silent :-)
    sailor wrote:
    >You write:
    I will post photos.
    So the new pictrures all all active cooled, I think. A passive cooler with a fan isn't that active? Because the fan is active.
    >How can I do this?
    It says:
    PCI ATA/ATAPI Driver@0: PIO Mode 4
    PCI ATA/ATAPI Driver@0: UDMA Mode 5
    PCI ATA/ATAPI Driver@2: PIO Mode 4
    PCI ATA/ATAPI Driver@2: UDMA Mode 5
    One is the CD-ROM and the other is the hard disk. So they both use 100MB/s.
    sailor wrote:
    > PCI HD 5450
    3D I don't need (I think) because I don't run 3D games. Overlay is only for MPlayer important?
    PCI is slower than AGP. Can you feel it?
    I try to find them.
  • »20.05.20 - 08:55
    OffseT
    Posts: 23 from 2019/8/23
    Yes. Graphics card on PCI are noticeably slower than on AGP. You can feel it.
    I even tested PCI-express card through a PCI to PCIe adapter, And I switched back to my Radeon 9700 Pro which is much faster and have full 3D support. It also can handle 2K resolutions with no issue.
    [ Edité par OffseT 20.05.2020 - 13:16 ]
    [ Edité par OffseT 20.05.2020 - 13:17 ]
  • »20.05.20 - 10:15
    I use more, 200 or 300. But if you have low speed with read/write big files, I think it is not the case. Look for max tansfer value - it it limited somehow?
    It is up to you. If you have big case with good airflow, you can use this cooler without fan.
    CPU MPC7447(A):
    6.5W @ 900 MHz
    7.5W @ 1066 MHz
    19W @ 1420 MHz
    ARCTIC Alpine M1 Passive RECOMMENDED FOR TDP UP TO: 35 W
    I have nearby bigger cooler of graphics card and I want also have some airflow around northbridge - thus I used the fan. And yes, is is active now. But the name of cooler itself stays "M1 passive" ;-)
    OK - same values like me. But these numbers are OK for internal IDE. For SiI SATA cards you can (in theory) have 133MB/s, but MOS sata.device is show stopper here.
    sailor wrote:
    > PCI HD 5450
    Yes, overlay is for playing videos.
    As a said - I do not used any PCI card, I simply don't know.
    In theory - if you succeed to find (or make) some AGPx1->PCI riser ( something like reversed riser for efika) you can try PCI card in AGP slot - in such case it will have double speed - 66MHz ( compares to 33MHz of other PCI slots).
  • »20.05.20 - 10:44
    connor
    So the PCI cards are only better for more video RAM to show more windows and screens? This would be good but if it is slower then it is not a good change. I think I only have AGP Radeon 9200P or so. Is it also faster then PCI cards?
  • »20.05.20 - 10:54
    connor
    I don't know . I don't underdtand all these settings. I always let them on default. Only for IceFS I changed them like written in the manual but IceFS still has so many bugs that it is impossible to use - but other construction site.
    Here I use SFS. And for SFS the Max Transfer is 0xffffffff and Mask (on the right to it) is 0x7ffffffe.
    How big is one buffer? One byte? Kilobyte? Megabyte? How can I know the right number of buffers? Because it is the same for all partitions. For 1GB and for 120GB.
    CPU MPC7447(A):
    6.5W @ 900 MHz
    7.5W @ 1066 MHz
    19W @ 1420 MHz
    No. I have a normal Micro ATX case. Maybe this is too small. I do not know which one is enough.
    I found the cooler on amazon but not avilable. Maybe it is too old. I will look further. Funny thing: warranty 6 years, haha. It is just a piece of metal. Only a block. Nothing more. What should happen after 6 years? Break it? Melt it? :-)
    I already use passive graphics card. But the CPU is noisy.
    I have one of the cards that work with ulsata2.device. It says UDMA6. So this seems to be good. But MOS cannot from that. Pity. Because hten I could remove the IDE disk. Or maybe the mos team should upgrade the sata.device to allow boot from it and higher speed.
    I see if I can find it. Then I can look for a 2D card with overlay.
  • »20.05.20 - 11:17
    It's also for playing video inside Odyssey as well as for many emulators (for free resizing of the window).
  • »20.05.20 - 12:25
    MorphOS can't use more than 256 MiB VRAM, btw.
    Yes, likely.
  • »20.05.20 - 13:06
    connor
    I thought OWB uses MPlayer. How is it with scene demos or SDL programs that use full screen or window resize?
    OK emulators I don't need.
  • »20.05.20 - 13:06
    I think that one buffer equals the size of the block size set for the filesystem.
    >> [...] you can try PCI card in AGP slot
    Good luck. I've never seen such thing.
  • »20.05.20 - 13:22
    It doesn't use any external program for anything unless explicitly configured to do so. Both OWB's internal video player and MPlayer use integrated FFmpeg for video decoding.
    No idea, sorry.
  • »20.05.20 - 13:29
