MOS 3.10 Sam460 Radeon HD 6570 ?
    Posts: 14 from 2013/9/27
    Hi
    Has anyone tried MOS 3.10 with Sam460 + RadeonHD 6570 ?
    Sam460 is able to boot MOS3.10 installation CD, however screen doesn't change to MOS output and stays at UBoot screen.
    I can hear the CD-Rom working, that means system has not crashed.
    I tried DVI and HDMI ports..
    Any ideas ?
  • »26.03.18 - 09:04
    Posts: 12408 from 2003/5/22
    > I tried DVI and HDMI ports.. Any ideas ?
    If this is on a Sam460ex and not on a Sam460cr, maybe MorphOS defaults to the VGA output of the on-board SM502 and must be switched to the PCIe graphics card after boot? Just a guess.
  • »26.03.18 - 09:32
    Spectre660
    Posts: 276 from 2015/6/30
    I had a problem with a Sam460ex + RadeonHD 6570 when I tried MorphOS 3.9.
    Possibly DDC not working properly. Had to use a DVI to VGA adapter to get a display.
    I did attempt to report the issue.
  • »26.03.18 - 09:53
    bigfoot
    Posts: 510 from 2003/4/11
    That graphics card should definitely work. If the display indeed stays with the U-Boot screen active, rather than going blank, then it's most likely a question of the card not being detected right for whatever reason. Is there any chance you can obtain a serial log from your boot attempt?
  • »26.03.18 - 10:02
    Mozzerfan
    Posts: 100 from 2016/10/5
    I have the same problem with my sam460ex and a radeon x1550.
    After loading the boot img, it says "booting..." and it stays there forever.
    I used the same CD to update my other systems (ibook, macmini) and with that systems all went well.
  • »26.03.18 - 10:10
    bigfoot
    Well, then same question for you :) Any chance you could capture a serial log?
  • »26.03.18 - 10:29
    Mozzerfan
    How can I capture a serial log? (I know: dumb question)
  • »26.03.18 - 10:40
    bigfoot
    You'll need a serial cable and a second machine, and then some serial terminal software for whatever OS the second machine runs, and the serial terminal software needs to be configured for 115200 bps 8N1 mode.
  • »26.03.18 - 10:49
    I will send a serial log tonight or latest tomorrow morning.
  • »26.03.18 - 10:55
    Mozzerfan
    Hmmmmm... bummer. I don't have a serial cable.
  • »26.03.18 - 10:55
    Yes this is a Sam460ex...I will check if VGA has any output..
    But anyway it would be better if it switches to 6570.
  • »26.03.18 - 10:57
    Spectre660
    Serial Log link below. HD6570 No display for me too.
    http://dl.dropboxusercontent.com/s/9fjnl1ei7zo9muy/HD6570-Sam460ex_Morphos.log?dl=0
    [ Edited by Spectre660 26.03.2018 - 10:16 ]
  • »26.03.18 - 11:04
    Spectre660
    No problems with HD6450
  • »26.03.18 - 11:15
    bigfoot
    Thanks for the log. And just to confirm, do you get a blank screen or does the firmware screen stick like earlier described by eightwonder?
  • »26.03.18 - 17:04
    Spectre660
    It was a blank screen .
  • »26.03.18 - 17:27
    Mozzerfan
    @bigfoot
    I just checked again.
    The bootloader gives some errors:
    - Failed to load cache block 0 from device 2
    - Failed to load partitions on device 2
    device 2 is my DVD/CDROM device.
    It DOES load the boot img though
    EDIT: I've tried with 2 different CDs and I also tried 3 different programs to burn the ISO to CD.
    (Jalapeno, UltraISO and Burnaware).
    But bootloader always gives the same errors.
    [ Edited by Mozzerfan 01.04.2018 - 12:50 ]
  • »27.03.18 - 04:10
    Hello bigfoot
    Here is my serial output (now it is a blank screen like Spectre)
    U-Boot 2015.a (May 16 2015 - 14:17:51)
    CPU: AMCC PowerPC 460EX Rev. B at 1150 MHz (PLB=230 OPB=115 EBC=115)
    No Security/Kasumi support
    Bootstrap Option H - Boot ROM Location I2C (Addr 0x52)
    Internal PCI arbiter enabled
    32 kB I-Cache 32 kB D-Cache
    Board: Sam460ex/cr, PCIe 4x + PCIe 1x
    I2C: ready
    DRAM: 2 GiB (ECC not enabled, 460 MHz, CL4)
    PCI: Bus Dev VenId DevId Class Int
    00 04 1095 3114 0104 00
    00 06 126f 0501 0380 00
    PCIE0: successfully set as root-complex
    02 00 1095 3132 0104 00
    PCIE1: successfully set as root-complex
    04 00 1002 6759 0300 ff
    Net: ppc_4xx_eth0
    FPGA: Revision 03 (2010-10-07)
    SM502: found
    PERMD2:not found
    VGA: 1
    VESA: OK
    ABox 1.29 (26.6.2016) © 1999-2016 by Ralph Schmidt, Emmanuel Lesueur, Teemu Suikki, Harry Sintonen
    Driver_InitBoard: Channels = 4 UnitsPerChannel = 1
    PCI (S)ATA/ATAPI Driver@0: PIO Mode 4
    PCI (S)ATA/ATAPI Driver@0: UDMA Mode 5
    PCI (S)ATA/ATAPI Driver@1: PIO Mode 4
    PCI (S)ATA/ATAPI Driver@1: UDMA Mode 5
    sata.device@0: PIONEER DVD-RW DVR-221L <CDROM>
    sata.device@0: CDRom <CD001>,<MORPHOS > found, bootable
    sata.device@0: Mount <CD0>
    sata.device@0: Partition <CD0> DosType 0x43444653 BootPri 127
    sata.device@1: ATA-HD ST9160821AS <DIRECT_ACCESS>
    Driver_InitBoard: Channels = 2 UnitsPerChannel = 1
    SiI3132_Init:
    SiI3132_Init: Taking port 0 out of reset
    SiI3132_Init: Taking port 1 out of reset
    SiI3132_Init: Port resets done
    SiI3132_Init: Port 0 SStatus 00000000
    SiI3132_Init: Port 0: Drive not present
    SiI3132_Init: Port 1 SStatus 00000000
    SiI3132_Init: Port 1: Drive not present
    usbscsi.device@0: Mount <DH0>
    usbscsi.device@0: Partition <DH0> DosType 0x444f5307
    Radeon: Read BIOS ROM @0x16415054
  • »27.03.18 - 05:04
    I enabled SM502 VGA output as default at Sam460 UBoot.
    There is no MOS screen after UBoot screen in this configuration too..
    Serial log is the same..
  • »27.03.18 - 05:19
    Mozzerfan
    @bigfoot
    tried to install from sd-card.
    same problem, bootloader gives the same error msg (this time for the sdcard device of course)
  • »27.03.18 - 07:15
    Spectre660
    @bigfoot
    Using a a DVI to VGA adapter allows the Sam460ex to boot with the Radeon HD6570.
    Screen resolution limited to 800x600x24 .
    DDC issue ?
  • »27.03.18 - 08:28
    Spectre660 wrote:
    @bigfoot
    DDC issue ?
    Direct VGA or DVI to VGA adapter doesn't work here...
    Maybe I should go out and buy Radeon R5 230
  • »27.03.18 - 08:51
    eightwonder wrote:
    Spectre660 wrote:
    @bigfoot
    DDC issue ?
    That was the card Bigfoot recommended to Acill before last Fall's Amiwest demo.
  • »27.03.18 - 12:15
    ...and it is the card he's just recommended in the MorphOS 3.10 news article thread, as well as the HD6450.
  • »27.03.18 - 14:31
    Spectre660
    Comments on the Sam460ex + Radeon HD6570 from 2015 .
    Link
  • »27.03.18 - 15:30
    Link
    So why didn't you install the HD 6670?
    And no one has mentioned the 6750 or the 6870, both of which should work.
    [ Edited by Jim 27.03.2018 - 20:03 ]
  • »27.03.18 - 19:21
