G4 vs. G5
    tlosmx wrote:
    Jim wrote:
    Hmm, those memory benches are very disappointing.
    exactly for the 5020 is the same speed of P4 born in 2001 ddr 266mhz
    Not the greatest analysis, since the P4 did have pretty good memory bandwidth (for the period).
    And, for some reason the X5000/40 has slightly better bandwidth.
    The really telling thing is how poorly the X5000 compares to the X1000.
    So, just how accurate are these figures?
    And, I wish we could get a better idea of how this compares to the quad G5, but that comparison can only occur under Linux right now.
    You had me wondering why an advocate for the X5000 would suddenly be recommending the G5.
    The X4 PCI-E slot is not that big a deal for me (it should be adequate for the cards that are suited to linux and NG OS').
    But these other issues are...unsettling.
  • »10.09.17 - 20:58
    Posts: 12548 from 2003/5/22
    > the soc if one on the topo have to be one only ...
    > if you see the image you will see two with same id
    You mean the "PCI 1957:0451" ID? If yes, are you sure this is the P5040 SoC?
    > L3 cache [...] is used only for corenet and not as sdram
    > for be sdram have to be set up in source config of uboot ... but no one setup it. and build.
    Then this should be changed in U-Boot. Who is the developer/maintainer of U-Boot for Cyrus/X5000?
    > 2 gbs max for 5020
    > G5 Quad is 7/8 Gb/s
    Yes, I already compared my PowerMac G5 to the X5000 (both with MorphOS) last year and basically came to the same conclusion:
    AmigaMARK Memory, stream:
    http://morph.zone/modules/newbb_plus/viewtopic.php?forum=11&topic_id=11137&start=593
    RAGEMEM:
    http://morph.zone/modules/newbb_plus/viewtopic.php?forum=11&topic_id=11137&start=624
    > the topology of the cyrrus is totally strange compared all topology in the
    > world Informaic Tecnology. qemu dont manage it because strange.
    Okay, so the Cyrus board topology is strange, not wrong :-)
  • »10.09.17 - 21:46
    Posts: 80 from 2017/9/10
    P5040 is different from 5020 in number of cores,mhz and ram P5020 use ddr3 1333 P5040 ddr3 1600 plus the cpus differs in the logic scheme . P5040 is "more modern"
    they reflect the same situation that i found on linux. was made by one of my friend with last release of os4.
    the pcie 4x is not the best under linux too.more faster is better will be the result ... this is why every time i switched from x5000 to G5 quad was like change from an amiga 500 (standard) to an amiga 3000 in performances.
  • »10.09.17 - 21:48
    yes if not the soc we will have a more big problem.
    Yes. Developer varisys, manteiner was before i quit Perez.
    > 2 gbs max for 5020
    > G5 Quad is 7/8 Gb/s
    RAGEMEM:
    Working bad... issue with some boards: example cmi sound card made machine freeze, slow performances pcie sata 3 controllers with fast ssd sata3 max 400mb/s r 100Mbs w . flashdrive max 900mb r .. 150 w.... and so and so.
    this are my bechmark not with altivec : https://www.dropbox.com/s/wshgd98gfny33ma/bench.xlsx?dl=0
    distributed G5 Quad on fedora ppc64 dnet bench
    [Aug 23 16:52:41 UTC] Automatic processor type detection found
    a PowerPC 970MP (G5) processor.
    [Aug 23 16:52:41 UTC] OGR-NG: using core #1 (KOGE 3.1 Hybrid).
    [Aug 23 16:53:00 UTC] OGR-NG: Benchmark for core #1 (KOGE 3.1 Hybrid)
    0.00:00:16.29 [42,505,737 nodes/sec]
    [Aug 23 16:53:00 UTC] RC5-72: using core #4 (KKS 7450).
    [Aug 23 16:53:21 UTC] RC5-72: Benchmark for core #4 (KKS 7450)
    0.00:00:17.47 [18,852,434 keys/sec]
    [Aug 23 16:53:21 UTC] Compare and share your rates in the speeds database at
    http://www.distributed.net/speed/
    (benchmark rates are for a single processor core)
    edit: e5500 not have some math instruction that are emulated by linux kernel. plus dont have the numa too.
    [ Edited by tlosmx 11.09.2017 - 01:25 ]
  • »10.09.17 - 22:08
    I hope they've been made aware of the problem. It doesn't sound too difficult to fix.
  • »11.09.17 - 08:04
    they need only enable an option in the uboot .config and disable another one... but i asked about in march 2016 when i had the 5020 ... now we are in september 2017 and:
    uboot is the 2014 version.
    nothing change about L3 options.
    Uboot integrate the varisys Cyrus config in mainstream github :
    shot
    [ Edited by tlosmx 11.09.2017 - 14:11 ]
  • »11.09.17 - 11:10
    Spectre660
    Posts: 276 from 2015/6/30
    PCIex1 CMI8738 sound card freeze issue also occurs on Sam460ex .
    http://forum.hyperion-entertainment.biz/viewtopic.php?f=17&t=3528
    PCiex1 ENVYHT24 with ASM1083 revision 1 bridge csip works so it is possible that the issue with the
    CMI PCIex1 cards may be able to be fixed in software.
    http://forum.hyperion-entertainment.biz/viewtopic.php?f=57&t=3625&start=40#p41538
    [ Edited by Spectre660 11.09.2017 - 22:12 ]
  • »11.09.17 - 23:07
    Thanks, initially I may just use an Envy 24HT PCI card.
    That will still goes through a bridge (PCI to PCI-E onboard), but maybe that will work OK.
  • »12.09.17 - 07:34
    why you dont write about a core a-eon linux manteiner who wrote "why my cmi card work on my x1000 and freeze on x5000?"
  • »12.09.17 - 08:32
    > an Envy 24HT PCI card [...] will still goes through a bridge (PCI to PCI-E onboard)
    It's even two bridges, as the PCIe-PCI bridge resides behind a PCIe-PCIe bridge.
  • »12.09.17 - 12:28
    OMG, our poor developers...
  • »12.09.17 - 14:48
    topo explained
    [ Edited by tlosmx 12.09.2017 - 22:12 ]
  • »12.09.17 - 19:12
    > topo explained
    Link doesn't work for me.
    Me either.
  • »12.09.17 - 20:01
    pls chek it now
    topo
  • »12.09.17 - 22:02
    .........The really telling thing is how poorly the X5000 compares to the X1000.
    My X1000 is looking better and better each day, for running OS4 anyway. I like that it has Altivec and is using the e6500 core (I think), instead of the "weaker?" e5500, e600, or any other PPC core design.
    If I remember correctly (which is highly unlikely), the memory read/write speeds and bandwidth for the X1000 was one of it's very few strong points, when the X1000 was compared to G4 and even G5 systems. That superior memory speed and maybe bandwidth, partially may have made up for the many other areas where the PA6T, or X1000 was/is slower than used PPC Mac hardware.
    It is a shame, and I feel bad for Trevor and Matthew, that the X5000 is experiencing these apparent problems, or short falls in performance, since so much has been invested in creating what "is" the current (and possibly last) ultimate PPC AmigaOS4 compatible system. I kind of doubt that Hyperion will ever port AmigaOS4 to any Power9 (or even Power8 or lower) work station class systems, and no talk has been leaked that anyone is even thinking of porting AmigaOS4 to the x64 architecture.
    Still, everything I have heard from the X5000 beta testers I have talked to, indicates that the X5000 is very noticeably faster at running AmigaOS4.1FE, when compared to the X1000 (or was that comparisons while running Linux?). This thread is the first I have seen where anyone has complained so extensively about the performance of the X5000. I'll have to get more info for Jim when I attend AmiWest 2017 next month, and take notes while playing with one of the many X5000's that will be displayed at the show. Maybe I will be able to set up my X1000 right next to someone's X5000, so a "side-by-side" comparison can be done, running the exact same game, or other software application.
    That reminds me, I need to upgrade my X1000's video card and drivers, before the show dates. I haven't decided which video card I am going to put into it yet. I have a 6xxx, or 7xxx Radeon card in my i5 PC, which is a double width card with double fans attached to it, but I'm not sure I want to put such a noisy video card into my X1000, and don't think AmigaOS4.1FE has any software that needs such a powerful video card. I'll probably try to get recommendations from other X1000 and X5000 owners, regarding which video card to look for, then try to have it delivered within the next couple weeks, so I can install it and play around with AmigaOS4.1FE a bit before I pack it up to take to the show.
    Let me know if there is anything specific you want tested, or asked of the X5000 owners Jim, so it can help you with your decision to buy an X5000-20, or X5000-40.
  • »13.09.17 - 02:08
    Posts: 2730 from 2003/2/24
    The X5000 is more of a sideways move, not a forward move, from the X1000's performance level, that fact was established years ago.
  • »13.09.17 - 03:31
    I actually preferred the X1000's expansion slot setup as the P50xx doesn't offer as many PCI-E lanes, and the fact that the PA6T has AltiVec instructions is a plus.
    I don't think the PA6T core is quite as nice as the e6500 core, but it had some advantages over the e5500.
    And the Gen2 PCI-E lanes, SATA2 capability, and DDR3 off the e5500 SOCs are already becoming dated, when compared to current CPUs.
    I'd still favor the X5000 over the X1000, but the memory benches are disheartening. I wonder if these can be improved with better firmware.
    If the choices are hoping for an X64 shift that appears to be stagnant, waiting for support for X5000 and MorphOS 3.10, sticking with what we have, or hoping for PCI-E G5 support (or some other RISC solution)...
    I'm not surprised we're losing users.
    David - Have a good time @ AmiWest. My guess is the focus may be the A1222.
    The teething issues with the X5000 are actually to be expected, and some of these things will improve.
    From what I have been able to tell, the X5000/40 should be ready for release soon.
    Since that will offer twice the core count of the X1000, that's the model I really think makes more sense.
    And, of course, I still like the goals of the T2080 laptop project.
    Hopefully some solutions to utilizing the additional cores available on newer systems will eventually become available.
    [ Edited by Jim 13.09.2017 - 03:00 ]
  • »13.09.17 - 04:49
    > topo
    One of the first two squares of the 2nd PCIe controller is surely the PCIe-PCIe bridge, which creates 8 output lanes from 4 input lanes (see block diagram in the Cyrus Plus technical reference manual as well as the first link I gave you in comment #64).
  • »13.09.17 - 08:44
    Andreas
    this image was made by me some time ago because what i did not understand why they dint use the 3th pcie controller of the P50xx and you explain me so,me post ago.
    for them was best made two different board one for 5020 and one for 5040 put less slots and dont use pcie-pcie bridges and use the 3 pcie controller im sure like this the machine will be have all better.
    first and second square on the second controller are pcie-pcie bdridge on lshw on linux i sow exactly this but i was hoping was not like this.
    If i will have time i will go in my mancave where is my x5000 (i dont turn on it from 1 month)
    and will copy and past the log of it just for have better vision of everything.
  • »13.09.17 - 10:07
    Seems like the expansion busses and PCI-E routing on these boards is less than ideal.
    This is one area the X1000 seems to have a leg up on.
    The design of the X5000 could almost be modified for a T10XX.
    [ Edited by Jim 13.09.2017 - 09:09 ]
  • »13.09.17 - 11:09
    Addendum:
    > I doubt Varisys simply forgot to use more than two PCIe controllers, but believe
    > there is a good reason for using only two of them. It might be connected to the
    > fact that the board has been designed for three different SoCs (P3041, P5020,
    > P5040) which are not 100% pin-compatible, so the actual board design
    > represents the lowest common denominator between the three SoCs.
    I just remembered that 6½ years ago, Jim and I discussed the SerDes assignment options for the P5020's PCIe controllers:
    http://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=7183&start=154
    http://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=7183&start=177
    As can be seen, the most sane PCIe config for the P5020 used in a desktop computer would have been x4 x4 x1 x1. Now as the P5040 lacks the fourth PCIe controller, this option can't be used on the board, so Varisys had to use the next best option instead, which is x4 x4 (with bridging the 2nd x4 to x8). And even if there was an x4 x4 x1 config for the P5020 (which there isn't), this would have resulted in only 1 lane more (or 3 lanes less without the bridge for the 2nd x4).
    I think this should explain why the Cyrus board only uses two PCIe controllers.
  • »13.09.17 - 11:11
    but the most intelligent think will be for me if they use the P5021 and not the P5020 for have less problem?
    or dont made the 5040 version and only 5020 and P3041 because are Pin compatible. P3041 plus is pin compatible with 4040 and 4080
    Addendum:
    I just remembered that 6½ years ago, Jim and I discussed the SerDes configuration options of the P5020's PCIe controllers:
    As you can see, the most sane PCIe config for the P5020 used in a desktop computer would have been x4 x4 x1 x1. Now as the P5040 lacks the fourth PCIe controller, this option can't be used on the board, so Varisys had to use the next best option instead, which is x4 x4 (with bridging the 2nd x4 to x8). And even if there was an x4 x4 x1 config for the P5020 (which there isn't), this would have resulted in only 1 lane more (or 3 lanes less without the bridge for the 2nd x4).
  • »13.09.17 - 11:40
    If they had made two different boards for X5000/20 and X5000/40, they could have used all four PCIe controllers of the P5020 in x4 x4 x1 x1 config. For the P5040, the only SerDes config that includes SATA and all three PCIe controllers is x4 x1 x1, which is even less lanes than the x4 x4 config used now.
    This means having two different boards would have benefited the X5000/20, but not the X5000/40.
    29 SerDes assignment configs for P5020
    14 SerDes assignment configs for P5040
    As you can see, the only matching configs between the SoCs are 0x11, 0x15, 0x2a, 0x34, 0x35 and 0x36. Cyrus uses 0x11.
  • »13.09.17 - 12:12
