Posts: 2793 from 2006/3/21
Quote:Quote:
Jim wrote:
Hmm, those memory benches are very disappointing.
.........The really telling thing is how poorly the X5000 compares to the X1000.
And, I wish we could get a better idea of how this compares to the quad G5, but that comparison can only occur under Linux right now.
You had me wondering why an advocate for the X5000 would suddenly be recommending the G5.
The X4 PCI-E slot is not that big a deal for me (it should be adequate for the cards that are suited to linux and NG OS').
But these other issues are...unsettling.
My X1000 is looking better and better each day, for running OS4 anyway. I like that it has Altivec and is using the e6500 core (I think), instead of the "weaker?" e5500, e600, or any other PPC core design.
If I remember correctly (which is highly unlikely), the memory read/write speeds and bandwidth for the X1000 was one of it's very few strong points, when the X1000 was compared to G4 and even G5 systems. That superior memory speed and maybe bandwidth, partially may have made up for the many other areas where the PA6T, or X1000 was/is slower than used PPC Mac hardware.
It is a shame, and I feel bad for Trevor and Matthew, that the X5000 is experiencing these apparent problems, or short falls in performance, since so much has been invested in creating what "is" the current (and possibly last) ultimate PPC AmigaOS4 compatible system. I kind of doubt that Hyperion will ever port AmigaOS4 to any Power9 (or even Power8 or lower) work station class systems, and no talk has been leaked that anyone is even thinking of porting AmigaOS4 to the x64 architecture.
Still, everything I have heard from the X5000 beta testers I have talked to, indicates that the X5000 is very noticeably faster at running AmigaOS4.1FE, when compared to the X1000 (or was that comparisons while running Linux?). This thread is the first I have seen where anyone has complained so extensively about the performance of the X5000. I'll have to get more info for Jim when I attend AmiWest 2017 next month, and take notes while playing with one of the many X5000's that will be displayed at the show. Maybe I will be able to set up my X1000 right next to someone's X5000, so a "side-by-side" comparison can be done, running the exact same game, or other software application.
That reminds me, I need to upgrade my X1000's video card and drivers, before the show dates. I haven't decided which video card I am going to put into it yet. I have a 6xxx, or 7xxx Radeon card in my i5 PC, which is a double width card with double fans attached to it, but I'm not sure I want to put such a noisy video card into my X1000, and don't think AmigaOS4.1FE has any software that needs such a powerful video card. I'll probably try to get recommendations from other X1000 and X5000 owners, regarding which video card to look for, then try to have it delivered within the next couple weeks, so I can install it and play around with AmigaOS4.1FE a bit before I pack it up to take to the show.
Let me know if there is anything specific you want tested, or asked of the X5000 owners Jim, so it can help you with your decision to buy an X5000-20, or X5000-40.
