G4 vs. G5
    Posts: 12075 from 2003/5/22
    > neither the X5000 or the G5 support GCN cards under Linux
    I think they are supported in everything but 3D.
  • »09.09.17 - 00:01
    marmotta
    Posts: 32 from 2012/6/11
    This is the x5000 topographic, from tlosm. He cant register here because website registration issue
    X5000 Topographic
  • »09.09.17 - 09:07
    >>> wrong hardware topographic
    >> What does that mean?
    > X5000 Topographic
    Thanks. And what's wrong with this topology?
  • »09.09.17 - 14:16
    Posts: 80 from 2017/9/10
    finally here! i dont know why this website dont like hotmail or yahoo.com
    ok letz explain the topo.
    first the two socs (?) i hope are the sosc not sure have the same id and float around someware
    the first controller is is the 16x aka 4x pcie is where is the gpu
    the second controller have all the bridge put on it ... with bridge over a bridge over a bridge over a bridge...
    the third controller pcie controller they forget to use.
    The L3 cache is a fake cache it is used only for net packet and not for data... this was explained by the mantainer of the uboot
    it is called corenet.
    by the way the cpu have good integer compared the G5 970MP but overall deskop performances are choppy, slow expecially after some times. i think becasue havy ram granulation.
    plus steam report only max 2gb/s for 5020 and 4 gb/s for 5040 where the ddr3 1600 is capable on other hardware to run at 22 Gb/s
    fastest gpu dont help too much compared slowed one i test various NI board with not good big differences in result.
    NOTE:All is about linux ... i dont consider amigaos because i cant compare amigaos with faster powerpc hw.
    for sure now the faster cpu is the e5500 for amigaos.
    only mos guys can compare morphos under X5000 and G5 if sow differences in better or worst performances.
    sorry my english is not perfect.
    Im waithing the day when mos will be available for G5 Quad and RadeonHD :P
    [ Edited by tlosmx 10.09.2017 - 12:53 ]
  • »10.09.17 - 12:08
  • ASiegel
    Posts: 1370 from 2003/2/15
    Because before blocking those, 90+ percent of all spam registrations used either. (Yahoo was especially bad and heaviliy abused by what appeared to be Chinese spam bots.)
    Considering that well below one percent of valid MorphZone users used Yahoo! or Hotmail email accounts, this seemed like a no-brainer.
  • »10.09.17 - 12:43
    now lets explain why i buy the x5000/40
    before i had a pegasos2 1266mhz ... for me the best machine made for an amigan because linux compatible with mol-kvm, morphos, amigaos.
    take the x5000/40, (the 3 october 2016 was to me) because on paper it specs will made my g5 quad goes in pension and will gave me linux, amigaos and morphos togheter again on the same machine.
    but this was not true ... from very beginning i report to aeon the bed video gpu performances ... result they change the document specs of x5000.
    g5 quad continue is the best powerpc desktop machine made .
    about
    Video card support of Linux on X5000 is better than video card support of Linux on PowerMac G5?
    on linux ppc you can have all the board available on linux x86 ... only mesa are problematic because endianess in SI sourcess.
    the same gpus work on G5 and on x5000 but better on g5.
    i tested on my quad radeonhd 4.xxx,5.xxx,6.xxx an 7.xxxx, r230 all are working . only r7 is not running but can be only a firmware issue not a pcie compatibility issue.
    [ Edited by tlosmx 10.09.2017 - 13:07 ]
  • »10.09.17 - 13:00
    tlosmx wrote:..Im waiting the day when mos will be available for G5 Quad and RadeonHD :P
    A lot of people have asked for that. I have one, the cooling system is a bit of a PITA, but it makes a good Linux platform.
    As Kronos pointed out in the TalosII thread, the quad G5 would make a good base for the next version of MorphOS.
    BUT, many of the developers think we are supporting too many systems already.
  • »10.09.17 - 13:34
    true ... but the quad will the best one ;-)
  • »10.09.17 - 14:00
    That is what everyone said when then 2.7 GHz AGP models we're supported, and the slower G5s became more popular because they were air cooled.
    I'd feel more comfortable with the quad if there was an easy way to convert it to air cooling.
    [ Edited by Jim 10.09.2017 - 12:17 ]
  • »10.09.17 - 14:23
    >>> X5000 Topographic
    > someware
    There's only one SoC on the Cyrus/X5000.
    Actually, it's one PCIe-PCIe bridge with another PCIe-PCI bridge (for the PCI slots) attached to it.
    http://morph.zone/modules/newbb_plus/viewtopic.php?forum=11&topic_id=11137&start=712
    I doubt Varisys simply forgot to use more than two PCIe controllers, but believe there is a good reason for using only two of them. It might be connected to the fact that the board has been designed for three different SoCs (P3041, P5020, P5040) which are not 100% pin-compatible, so the actual board design represents the lowest common denominator between the three SoCs.
    http://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=7001&start=893
    Considering the fact that the P3041 version was abandoned anyway, they might as well have selected the P5021 instead of the P5020, as the P5021 and the P5040 are 100% pin-compatible.
    Interesting. I didn't know that the CoreNet L3 cache can't be used also like a normal L3 cache. But even then this has nothing to do with the board design, don't you think?
    Do you think this is a board design issue?
  • »10.09.17 - 14:34
    Posts: 2026 from 2003/2/24
    One annoyance with support for dual core and quad core machines is that they came with NVIDIA graphic cards, and it can be somehow difficult to find compatible PCIe cards... in any case it's difficult for users to buy complete setups which would work "out of the box". But of course they would be nice machines to be supported otherwise... faster gfx bus etc.
  • »10.09.17 - 14:35
    Interesting. Which specs in particular did they change after your reporting?
    Together with the TerraSoft/Fixstars/YDL PowerStation, I guess :-)
    Isn't that a contradiction to what Jim said in comments #50 and #53? :-)
    > on my quad [...] only r7 is not running
    Isn't that a contradiction to what you just said yourself? :-)
  • »10.09.17 - 14:51
    >>> X5000 Topographic
    > someware
    oh mama to much question.
    ... bad because it made the topo more strange than before,
    ok that can be normal
    ... but on the topo you see more bridges in the schemas are the squares.
    one is the extra bridge of the cmi board (and is normal) many others none.
    im try to reproduce the board scheme on qemu and it refuse to do something like that.
    it continue make a "normal topo" shot
    yes it can be used as fast sdram too. but i was referring to the topo scheme.
    can be it or bad kernel integrations, low ram speed bottle neck.
    ram speed so slow... i hope is only bad uboot integration... bur my fear is the e5500 true speed is ddr 200 at true 400MTs data rate.
  • »10.09.17 - 15:34
    made more better the pcie 16x description ;-)
    I was thinking this machine are more for server use :P
    where?
  • »10.09.17 - 15:39
    Why? I don't see where the lstopo output shows more than one SoC.
    So you say that the Cyrus board topology is wrong because QEMU can't recreate it? Wouldn't it rather mean that there's something wrong with QEMU if it can't recreate the topology of an existing board?
    Just like it's supposed to be, right? Everything fine then.
    What's wrong with the L3 cache in the lstopo output?
    The memory controller is not part of the e5500 core. It's part of the SoC's 'uncore'. Also, 400 MHz and 800 MT/s is minimum spec for DDR3.
    https://en.wikipedia.org/wiki/DDR3_SDRAM#JEDEC_standard_modules
  • »10.09.17 - 21:35
    You mean when A-Eon wrote "PCIe x16 slot (Gen2 x4)" in their November 2016 press release? Or do you mean they omitted the fact in the original Cyrus Plus technical reference manual (version 1.1.1 from July 2014 makes no secret of the fact)?
    It was advertised for both server and workstation use.
    > where?
    There: "the same gpus work on G5 and on x5000" :-)
  • »10.09.17 - 21:53
    this ... i need to make a correction my x5000 come 29/9/2016 .. i was sure it come in october but i was wrong... just find my video of unboxing.
    ah ah you right. for have the gpus run on x5000 the gpu firmware have to be build on the kernel. On g5 quad need to be installed on the lib/firmwares on the hd. i did not have the firmware in the lib when i made the test on G5 this is why im not sure.
    you have better memory then me :-)
    [ Edited by tlosmx 10.09.2017 - 22:02 ]
  • »10.09.17 - 22:01
    Andreas my english is not good and for me is difficult to write .
    the soc if one on the topo have to be one only ... if you see the image you will see two with same id
    >So you say that the Cyrus board topology is wrong because QEMU can't recreate it? Wouldn't it rather mean that there's >something wrong with QEMU if it can't recreate the topology of an existing board?
    Nope
    yes the cpu scheme is all ok, are the pci bridges and soc strange
    Nothing strange there about L3 cache is ok in the topo . but it is used only for corenet and not as sdram
    for be sdram have to be set up in source config of uboot ... but no one setup it. and build.
    i hope now is better :P
    by the way 1 GB/s to 4 gb/s max for 5040 are not DD3 1600 speed .. (stream and linux kernel report)
    1 GB/s to 2 gbs max for 5020
    G5 Quad is 7/8 Gb/s near 10Gb/s in Altivec
    Os4 ragemem Performances of 5020
    vs x1000
    nope ... the topology of the cyrrus is totally strange compared all topology in the world Informaic Tecnology.
    qemu dont manage it because strange.
    check and compare topos:
    SAM 460
    https://www.dropbox.com/s/pps1q9ropeusfh0/16196243_10208175166078464_2023629800_o.jpg?dl=0
    X1000
    https://www.dropbox.com/s/synwq2x1k081jn3/16117271_10208143633210162_1285018612_n.jpg?dl=0
    PowerMac G5 Quad
    https://www.dropbox.com/s/b9ajetsf8r1kjh0/16118530_10208141403954432_751303834_n.png?dl=0
    Tabor
    https://www.dropbox.com/s/joziw57zfoq0h3u/16237927_10208180847220489_965077643_n.jpg?dl=0
    a PC
    https://www.dropbox.com/s/fu3bwiooqg4q9as/16111653_10208132217124767_495101249_n.png?dl=0
    X5000 /20...
    https://www.dropbox.com/s/wdwuib52bii2bcn/16176754_10208155966798494_1032589834_n.png?dl=0
    X5000/40
    https://www.dropbox.com/s/8rgcvr6532fmzt5/16128954_10208172248685531_756994869_n.png?dl=0
    [ Edited by tlosmx 10.09.2017 - 23:12 ]
  • »10.09.17 - 22:30
    Hmm, those memory benches are very disappointing.
  • »10.09.17 - 22:58
    exactly for the 5020 is the same speed of P4 born in 2001 ddr 266mhz
  • »10.09.17 - 23:10
    if you need stream result here are for compare
    https://www.cs.virginia.edu/stream/by_name/Bandwidth.html
  • »10.09.17 - 23:14
    Not the greatest analysis, since the P4 did have pretty good memory bandwidth (for the period).
    And, for some reason the X5000/40 has slightly better bandwidth.
    The really telling thing is how poorly the X5000 compares to the X1000.
    So, just how accurate are these figures?
    And, I wish we could get a better idea of how this compares to the quad G5, but that comparison can only occur under Linux right now.
    You had me wondering why an advocate for the X5000 would suddenly be recommending the G5.
    The X4 PCI-E slot is not that big a deal for me (it should be adequate for the cards that are suited to linux and NG OS').
    But these other issues are...unsettling.
  • »10.09.17 - 23:58
    You mean the "PCI 1957:0451" ID? If yes, are you sure this is the P5040 SoC?
    > L3 cache [...] is used only for corenet and not as sdram
    Then this should be changed in U-Boot. Who is the developer/maintainer of U-Boot for Cyrus/X5000?
    > 2 gbs max for 5020
    > G5 Quad is 7/8 Gb/s
    Yes, I already compared my PowerMac G5 to the X5000 (both with MorphOS) last year and basically came to the same conclusion:
    AmigaMARK Memory, stream:
    http://morph.zone/modules/newbb_plus/viewtopic.php?forum=11&topic_id=11137&start=593
    RAGEMEM:
    http://morph.zone/modules/newbb_plus/viewtopic.php?forum=11&topic_id=11137&start=624
    > world Informaic Tecnology. qemu dont manage it because strange.
    Okay, so the Cyrus board topology is strange, not wrong :-)
  • »11.09.17 - 00:46
    P5040 is different from 5020 in number of cores,mhz and ram P5020 use ddr3 1333 P5040 ddr3 1600 plus the cpus differs in the logic scheme . P5040 is "more modern"
    they reflect the same situation that i found on linux. was made by one of my friend with last release of os4.
    the pcie 4x is not the best under linux too.more faster is better will be the result ... this is why every time i switched from x5000 to G5 quad was like change from an amiga 500 (standard) to an amiga 3000 in performances.
  • »11.09.17 - 00:48
    yes if not the soc we will have a more big problem.
    Yes. Developer varisys, manteiner was before i quit Perez.
    > 2 gbs max for 5020
    > G5 Quad is 7/8 Gb/s
    RAGEMEM:
    Working bad... issue with some boards: example cmi sound card made machine freeze, slow performances pcie sata 3 controllers with fast ssd sata3 max 400mb/s r 100Mbs w . flashdrive max 900mb r .. 150 w.... and so and so.
    this are my bechmark not with altivec : https://www.dropbox.com/s/wshgd98gfny33ma/bench.xlsx?dl=0
    distributed G5 Quad on fedora ppc64 dnet bench
    [Aug 23 16:52:41 UTC] Automatic processor type detection found
    a PowerPC 970MP (G5) processor.
    [Aug 23 16:52:41 UTC] OGR-NG: using core #1 (KOGE 3.1 Hybrid).
    [Aug 23 16:53:00 UTC] OGR-NG: Benchmark for core #1 (KOGE 3.1 Hybrid)
    0.00:00:16.29 [42,505,737 nodes/sec]
    [Aug 23 16:53:00 UTC] RC5-72: using core #4 (KKS 7450).
    [Aug 23 16:53:21 UTC] RC5-72: Benchmark for core #4 (KKS 7450)
    0.00:00:17.47 [18,852,434 keys/sec]
    [Aug 23 16:53:21 UTC] Compare and share your rates in the speeds database at
    http://www.distributed.net/speed/
    (benchmark rates are for a single processor core)
    edit: e5500 not have some math instruction that are emulated by linux kernel. plus dont have the numa too.
    [ Edited by tlosmx 11.09.2017 - 01:25 ]
  • »11.09.17 - 01:08
