MorphOS Developer
Posts: 508 from 2003/4/11
Hi guys,
I'm sorry I'm a bit late to the party, but I've been super busy lately.
Assuming that Ebay is showing me the correct photo for the (now expired) listing in the first post, the card in question is the exact same one as I'm running in my G5 right now.
It's a bit unclear what the status is for the two users of this card in this thread, but let me see if I understand this right:
Using the OF boot menu accessed via the alt key fixes this issue for you, Koszer? For both of you? Does it fix it for that boot only, or also for subsequent boots?
Booting Mac OS X first, and then rebooting into MorphOS fixes the issue until next power off for you Koszer? Does this also work for you, Intuition?
Do these two workarounds fix all issues? Do they work equally well?
Would any of you be available at some point to do some testing? Said testing will likely involve a lot of reboots and booting MorphOS from CD to copy in a working driver after a test, so it'll require some time and some patience.
Also, what's your full system specs? Which G5 exactly do you have? CPU speed? How much memory? Any other cards installed?
