Installing an SSD in Mac Mini
    clr666
    Posts: 85 from 2008/7/8
    geit wrote:
    This will not fit in any of your devices without reworking them.
    I'm sure, 2.5" SATA drive can be fitted inside Mac Mini with SATA2IDE44 adapter ;)
    This is my MacMini:
    Okay, reworking is in only one new hole in plastic for fixing drive in new position.
    In my PowerBookG4 i use mSATA2IDE44 adapter, 2.5" SATA drive cannot be fitted with SATA2IDE44 adapter.
    [ Edited by clr666 01.02.2016 - 13:35 ]
    _______________
    wintel free
  • »01.02.16 - 04:46
    beworld
    Posts: 592 from 2010/2/10
    i just purchapse that : http://www.ebay.fr/itm/2-5-Hard-Drive-HDD-SATA-female-to-IDE-44Pin-Converter-Adapter-for-Laptop-/201509300297? to test it with MacMini.
    I hope this will work. I keep you informed
    IMac G5 2.1,PowerBook G4 1.5,MacMini 1.5, PowerMac G5 2.7 died !!!
    My MOS ports
  • »01.02.16 - 11:44
    Posts: 1246 from 2004/2/8
    I have one. It doesn't work with standard 2,5" SATA drive, but maybe a SSD would fit inside (clr666 managed to squeeze one).
  • »01.02.16 - 15:52
    clr666
    I afraid, this type of adapter will lift drive too high and optical drive cannot be fitted on usual place.
    _______________
    wintel free
  • »01.02.16 - 16:11
    beworld
    ok I'll try anyway, if not work, it'll be lost 7€ :(
    thanks for yours replies
    My MOS ports
  • »01.02.16 - 16:23
    Yasu
    Posts: 1724 from 2012/3/22
    This is a little expensive compared to the chinese knockoffs, but it might be worth it for the varranty. This is the right one right?
    http://www.teknikproffset.se/Datorer-Kringutrustning/Kablar--Adaptrar/Interna/Strömkablar-och-adaptrar/DeLOCK-adapter-foer-mSATA-till-IDE-57x40mm.htm
    [ Edited by Yasu 01.02.2016 - 17:44 ]
    My MorphOS blog
  • »01.02.16 - 16:35
    clr666
    In my PB works about year sheapest chinese adapter, looks similar as in your link, with 128Gb ADATA mSATA card. Works very well with triple boot - Debian/MorphOS/OSX.
    _______________
    wintel free
  • »01.02.16 - 16:50
    Yasu
    Can anyone confirm that the converter in the link above is the right one? I'm 99% sure it is but I want to be 100% sure.
    My MorphOS blog
  • »02.02.16 - 12:12
    I have the same one (can you spot a difference?), albeit I bought in Singapore (for 5$ or so) and it does work.
  • »02.02.16 - 19:16
    beworld
    I received the adapter SATA2IDE.... lol
    http://i67.tinypic.com/a5d9vr.jpg
    http://i64.tinypic.com/2yo51k7.jpg
    So I tried it with my Samsung 128GB (SSD 830 Series)
    I installed the disc, the disc holds just below the CDROM
    By forcing it a little ets OK.
    I boot the MacMini .... error OpenFirmware screen .....
    I then test by removing the visible jumper on the adapter.
    I try again and nothing :-(
    I got back on my IDE drive.
    My MOS ports
  • »08.02.16 - 17:45
    clr666
    Maybe you need to reset PRAM by button or keyboard shortcut after installing new drive.
    _______________
    wintel free
  • »08.02.16 - 19:23
    Been there, done that. I almost managed to squeeze the disk and CD-ROM using the same adapter, but with no luck booting, or formatting the drive. The mSATA solution worked though.
  • »08.02.16 - 20:26
    Yasu
    I installed the recommended IDE --> mSATA adapter and a Samsung 250 GB mSATA SSD in my Mac Mini and so far it works great. The speed difference is noticable, even though it would probably be much faster on modern hardware.
    The only downside is that there are no screws to keep it fixed in the slot, so it relies on the pins. But they are sturdy so I don't expect much problems.
    Thanks everybody for the help!
    My MorphOS blog
  • »15.02.16 - 14:45
    There's always a hot glue gun option...
  • »15.02.16 - 18:08
    Intuition
    Posts: 1110 from 2013/5/24
    I wedged mine in with a folded up piece of A4 paper lol
  • »15.02.16 - 19:23
