MorphOS on AmigaOne X5000?
    Spectre660
    Posts: 275 from 2015/6/30
    @redrumloa
    No Quake III ports using Warp3D Nova or wrappers available yet .
    Port using GLES4 wrapper awaiting a Warp3D Nova/OpenGLES 2.0 library bug fix release .
    Post # 1 by Kas1e
    Post # 2 by Kas1e
    Bug fixes done and stuff tested works with Radeon SI and Polaris .
    There are 2 wrappers in the works. Gl4ES and EGLWrap .
    Demos that I have access to for both work (Radeon SI and Polaris) but nothing heavy like Quake III to benchmark yet .
    Forgot a 3rd Wrapper , Minigl Reloaded which is a implementation of Minigl via Warp3D Nova.
    redrumloa wrote:
    Doffo wrote:
    Still, who is gonna step up and run some quake III benchmarks on their x5000? Don't even have to play the game, run some commands and watch those FPS go. :D
    Sounds fair enough. OS4 has 3D support finally with Warp3D Nova, right?
    [ Edited by Spectre660 21.08.2018 - 21:53 ]
  • »22.08.18 - 01:29
    Spectre660
    AmigaOS 4.1FE using Warp3DSI (Not Warp3DNova)
    X5000/020 - Radeon R9-270X
    IOQuake 3
    1600x1200 = 95.10FPS
    [ Edited by Spectre660 21.08.2018 - 21:59 ]
  • »22.08.18 - 01:58
    Spectre660
    Pampers X5000 benchmark from 2016
    Benchmark Configuration
    Doffo wrote:
    Only for ones who have a compatible working 3D card in their x5000 for MorphOS, a good starting point is to benchmark Quake III. Here is a thread explaining how to set it up once you have it installed:
    Quake III Benchmarking
    Just run it if you are able to. Nobody with an x5000 has sat down and actually ever did it, or at least even posted about it.
    [ Edited by Spectre660 21.08.2018 - 22:13 ]
  • »22.08.18 - 02:10
    Doffo
    Posts: 507 from 2010/10/14
    Appreciate it. :) Numbers to work with.
    YUUUP!
  • »22.08.18 - 02:21
    Doffo
    To be sure what demo, demo four or demo001 or which one did you use?
    The person Kas1e, only claims 40 or so fps on demo four? I will just have to make some videos and upload them. Both my MDD G4 and G5 GHz did basically the same on a Radeon 9600. 41 FPS on the 1.5GHz MDD, and 44 on the G5 2 GHz on 1600x1200.
    YUUUP!
  • »22.08.18 - 04:48
    Doffo
    I just made a video instead to show what all I could squeeze out of an MDD G4 Mac @ 1.5 GHz and a Radeon 9600 card. Least to show we are on the same page as to what demo was benchmarked.
    If you can sometime, make a video of your setup doing the quake 3 demo.
    Quake III Benchmark Mac MDD @ 1.5 GHz w/ Radeon 9600
    YUUUP!
  • »22.08.18 - 05:35
    outrun1978
    Posts: 28 from 2018/7/8
    Well i have just run this now on my X5000 set up in MorphOS3.11
    Using a Sapphire X1650Pro 512MB run under following perameters if this helps to dissect any scores further...
    setenv TGLSYNC 0
    flushlib tinygl.library
    In Quake 3
    r_primitives 2
    timedemo 1
    demo four
    GL Driver default
    GL Extensions ON
    Colour Depth Default
    Fullscreen ON
    Lighting: Lightmap
    Geometric DetaIl: Medium
    Texture Quality 32 bit
    Texture Filter: Trilinear.
    640x480 resolution 1260 frames 6.5 seconds 193.8fps
    800x600 resolution 1260 frames 8.0 seconds 158.4fps
    1024x768 resolution 1260 frames 10.5 seconds 120.3 fps
    1280x1024 resolution 1260 frames 14.21 seconds 88.9 fps
    [ Edited by outrun1978 22.08.2018 - 10:04 ]
  • »22.08.18 - 10:00
    Spectre660
    My AmigaOS 4.1FE result is for demo four.
    1280x1024 = 104.9fps
    [ Edited by Spectre660 22.08.2018 - 06:51 ]
  • »22.08.18 - 10:33
    Doffo
    setenv TGLSYNC 0
    In Quake 3
    r_primitives 2
    timedemo 1
    demo four
    GL Driver default
    GL Extensions ON
    Fullscreen ON
    Lighting: Lightmap
    That helps. Thanks. I will give it a try later today.
    YUUUP!
  • »22.08.18 - 10:52
    Doffo
    Thanks again. Later on ill get on my MDD to see.
    YUUUP!
  • »22.08.18 - 10:53
    Posts: 12079 from 2003/5/22
    Why "finally"?
  • »22.08.18 - 20:48
    > GLES4 wrapper
    ...or GL4ES :-)
  • »22.08.18 - 20:54
    Spectre660
    @Andreas_Wolf
    Names get twisted when I reply late pm or early am :-) .
  • »22.08.18 - 21:10
    Doffo
    Spectre660 wrote:
    My Settings
    I am slacking a bit. I unearthed all of my AGP PC hardware to setup so that if I need to reflash AGP cards back to their PC bios counterparts, then I can. I found a 9800 Pro 128MB AGP card I had flashed 4+ years ago. Can't remember if or why I stopped using it. Something about the smaller bios's being problematic. All is well. Sooner or later I will report back with another video.
    YUUUP!
  • »23.08.18 - 05:42
    Spectre660
    Don't know what happened but getting much lower scores today.
    So my new scores X5000/20 .
    1280x1024 = 71.20fps
    1600x1200 = 66.90fps
  • »23.08.18 - 13:59
    Doffo
    Squeezed out 60.1 FPS on 1280x1024. I am still on the Radeon 9600.
    Hoping I have a GPU heatsink for the 9800. I removed it from the card years ago and only found the card itself. Least I know it is working, but again, it either struggled with the shrunk bios or just locked up playing. But its fun trying out the stuff again.
    YUUUP!
  • »23.08.18 - 21:59
    Spectre660
    I had accidentally set the Geometric Detail setting to High.
    Reset to Medium
    1600x1200=102.7fps
    May be a bug with the .config file as I am getting the 102.7 fps again with the Geometric Detail back at High.
    [ Edited by Spectre660 23.08.2018 - 19:17 ]
  • »23.08.18 - 23:12
    redrumloa
    Posts: 1424 from 2003/4/13
    Reset to Medium
    1600x1200=102.7fps
    This post makes no sense and is contradicting itself a couple times. Probably best to make a video of you running the test demo from soup to nuts.
    Anyhow, I have a Radeon FireGL x3 on the way. I'll bench my G5 next week when it gets here.
    [ Edited by redrumloa 23.08.2018 - 22:07 ]
  • »24.08.18 - 03:07
    Spectre660
    I have very slow upload bandwidth so I no video upload.
    Today's benchmark produces 95.9 in 1600x1200 .
    Settings
  • »24.08.18 - 11:20
    redrumloa wrote:
    Reset to Medium
    1600x1200=102.7fps
    FireGL X3 requires a re-flashed bios, and can be tricky to implement.
    It might be the o my card to require this (unless you consider PC cards like the X800XT or 9800).
  • »24.08.18 - 23:05
    Doffo
    I can only get 55FPS on a x1650 at 1600x1200. Max geometric detail, slider all the way to the right for texture detail, Tri etc...
    Also, makes you are demo-ing with a MAX playable screen size. Once in a game, you can adjust it + and - keys on your keyboard. Max it out. You can easily get 20+ more FPS shrinking the playable screen area lol. (Or just make sure screen size is on the max through the Display option.)
    This is why videos are important from the time you click it on it on your desktop and showing the configuration after the demo. :) ;)
    Anywho, redrumloa laid the lumber with his setup.
    [ Edited by Doffo 24.08.2018 - 19:47 ]
    YUUUP!
  • »25.08.18 - 00:29
    redrumloa
    Settings
    I got a chance to go out to my workshop today and do a benchmark because of curiosity. Here's my setup on the desk.
    PowerMac G5 @ 2.3Ghz
    Ati Radeon X800
    One thing I found out on this setup is in quake lower screen resolutions gave me lower FPS than higher resolutions. Go figure. Anyhow at 1600x1200 and EVERYTHING maxed out I got 114.9 fps.
    Some time next week my Radeon FireGL x3 will come in. I'll load that into the G5 2.7 Ghz and redo the benchmark. My current monitor for my PowerMac doesn't like to go over 1600x1200. I'll either have to buy a new one or borrow one from one of my PCs. I'm thinking the 2.7 with FireGL x3 will fly even at 1080p.
    Will update next week.
    [ Edited by redrumloa 24.08.2018 - 19:40 ]
  • »25.08.18 - 00:33
    redrumloa
    The seller I am buying it from already flashed it. He's sold quite a number of these and has a very good seller rating. I should be fine :-)
    -Edit-
    If it benches worse than the X800, I'll return it. He advertises it as the fastest gfx card for a G5 AGP model.
    [ Edited by redrumloa 24.08.2018 - 19:43 ]
  • »25.08.18 - 00:34
  • ASiegel
    Posts: 1370 from 2003/2/15
    Simply put, the FireGL-x3 is a relabelled X800 (same chip, same memory, etc). There should not be much of a difference between both cards while running MorphOS.
  • »25.08.18 - 09:14
