MorphOS on AmigaOne X5000?
    zukow
    Posts: 642 from 2005/2/9
    I understand that Tunenet is better than Aminetradio but what about Snes9x? Why OS4 version is better?
  • »21.08.18 - 22:06
    Posts: 12083 from 2003/5/22
    > the X5000 [...] is one of the few machines out there and available to buy that can
    > run both AmigaOS 4 MorphOS and various Linux distributions all in one box.
    It's even the only machine newly available to buy that can do so.
  • »21.08.18 - 22:08
    Posts: 888 from 2004/1/24
    Tunenet better that AmiNetRadio? Never :-P
    [ Edited by Stevo 21.08.2018 - 23:21 ]
  • »21.08.18 - 22:20
    outrun1978
    Posts: 28 from 2018/7/8
    @zukow
    The HunoPPC port of SNES 9X on OS4 allows for better quality resolution filters. The GUI on the OS4 version is also a lot nicer too.
    The MorphOS version appears a little lacking in comparison
    For those who are curious my blog post from last year covers this
    https://amigax5000.blog/2017/06/24/snes9x-super-nintendo-emulator/
    [ Edited by outrun1978 21.08.2018 - 22:45 ]
  • »21.08.18 - 22:44
    outrun1978
    And my preference for Tunenet over Aminet Radio is simply down to the preconfigured shoutcast streams. Unless I have missed something with Aminet Radio and the set up of it, the scan of streams doesn’t seem to work and I have to enter in Radio streams manually.
    [ Edited by outrun1978 21.08.2018 - 22:54 ]
  • »21.08.18 - 22:51
    zukow
    But BeWorld ported Huno's port to Morphos.
    http://www.morphos-storage.net/dl.php?dir=Emulation&file=Snes9x_1.53.lha
    and
    this tab is most ugly piece of UI i've ever seen :)
    ... but ok, Amigainput tab could be useful.
    [ Edited by zukow 22.08.2018 - 00:19 ]
  • »21.08.18 - 23:18
    Doffo
    Posts: 507 from 2010/10/14
    Anyone got any kind of benchmarks of anything with MorphOS running on the x5000?? Can be anything really. Just need to see if the x5000 is lets say twice as fast as a Mirror Drive Mac or if it is the same or even slower?
    YUUUP!
  • »21.08.18 - 23:25
    Doffo
    Only for ones who have a compatible working 3D card in their x5000 for MorphOS, a good starting point is to benchmark Quake III. Here is a thread explaining how to set it up once you have it installed:
    Quake III Benchmarking
    Just run it if you are able to. Nobody with an x5000 has sat down and actually ever did it, or at least even posted about it.
    [ Edited by Doffo 21.08.2018 - 18:06 ]
    YUUUP!
  • »22.08.18 - 00:05
    See comment #781:-)
  • »22.08.18 - 00:14
    Doffo
    Thanks. That settles that. ;)
    YUUUP!
  • »22.08.18 - 00:21
    Doffo
    Still, who is gonna step up and run some quake III benchmarks on their x5000? Don't even have to play the game, run some commands and watch those FPS go. :D
    YUUUP!
  • »22.08.18 - 00:27
    redrumloa
    Posts: 1424 from 2003/4/13
    Sounds fair enough. OS4 has 3D support finally with Warp3D Nova, right?
  • »22.08.18 - 00:53
    Spectre660
    Posts: 275 from 2015/6/30
    @redrumloa
    No Quake III ports using Warp3D Nova or wrappers available yet .
    Port using GLES4 wrapper awaiting a Warp3D Nova/OpenGLES 2.0 library bug fix release .
    Post # 1 by Kas1e
    Post # 2 by Kas1e
    Bug fixes done and stuff tested works with Radeon SI and Polaris .
    There are 2 wrappers in the works. Gl4ES and EGLWrap .
    Demos that I have access to for both work (Radeon SI and Polaris) but nothing heavy like Quake III to benchmark yet .
    Forgot a 3rd Wrapper , Minigl Reloaded which is a implementation of Minigl via Warp3D Nova.
    [ Edited by Spectre660 21.08.2018 - 21:53 ]
  • »22.08.18 - 01:29
    Spectre660
    AmigaOS 4.1FE using Warp3DSI (Not Warp3DNova)
    X5000/020 - Radeon R9-270X
    IOQuake 3
    1600x1200 = 95.10FPS
    [ Edited by Spectre660 21.08.2018 - 21:59 ]
  • »22.08.18 - 01:58
    Spectre660
    Pampers X5000 benchmark from 2016
    Benchmark Configuration
    [ Edited by Spectre660 21.08.2018 - 22:13 ]
  • »22.08.18 - 02:10
    Doffo
    Appreciate it. :) Numbers to work with.
    YUUUP!
  • »22.08.18 - 02:21
    Doffo
    To be sure what demo, demo four or demo001 or which one did you use?
    The person Kas1e, only claims 40 or so fps on demo four? I will just have to make some videos and upload them. Both my MDD G4 and G5 GHz did basically the same on a Radeon 9600. 41 FPS on the 1.5GHz MDD, and 44 on the G5 2 GHz on 1600x1200.
    YUUUP!
  • »22.08.18 - 04:48
    Doffo
    I just made a video instead to show what all I could squeeze out of an MDD G4 Mac @ 1.5 GHz and a Radeon 9600 card. Least to show we are on the same page as to what demo was benchmarked.
    If you can sometime, make a video of your setup doing the quake 3 demo.
    Quake III Benchmark Mac MDD @ 1.5 GHz w/ Radeon 9600
    YUUUP!
  • »22.08.18 - 05:35
    outrun1978
    Well i have just run this now on my X5000 set up in MorphOS3.11
    Using a Sapphire X1650Pro 512MB run under following perameters if this helps to dissect any scores further...
    setenv TGLSYNC 0
    flushlib tinygl.library
    In Quake 3
    r_primitives 2
    timedemo 1
    demo four
    GL Driver default
    GL Extensions ON
    Colour Depth Default
    Fullscreen ON
    Lighting: Lightmap
    Geometric DetaIl: Medium
    Texture Quality 32 bit
    Texture Filter: Trilinear.
    640x480 resolution 1260 frames 6.5 seconds 193.8fps
    800x600 resolution 1260 frames 8.0 seconds 158.4fps
    1024x768 resolution 1260 frames 10.5 seconds 120.3 fps
    1280x1024 resolution 1260 frames 14.21 seconds 88.9 fps
    [ Edited by outrun1978 22.08.2018 - 10:04 ]
  • »22.08.18 - 10:00
    Spectre660
    My AmigaOS 4.1FE result is for demo four.
    1280x1024 = 104.9fps
    [ Edited by Spectre660 22.08.2018 - 06:51 ]
  • »22.08.18 - 10:33
    Doffo
    setenv TGLSYNC 0
    In Quake 3
    r_primitives 2
    timedemo 1
    demo four
    GL Driver default
    GL Extensions ON
    Fullscreen ON
    Lighting: Lightmap
    That helps. Thanks. I will give it a try later today.
    YUUUP!
  • »22.08.18 - 10:52
    Doffo
    Thanks again. Later on ill get on my MDD to see.
    YUUUP!
  • »22.08.18 - 10:53
    Why "finally"?
  • »22.08.18 - 20:48
    > GLES4 wrapper
    ...or GL4ES :-)
  • »22.08.18 - 20:54
