MorphOS on AmigaOne X5000?
    Posts: 12080 from 2003/5/22
    > A new lower-end board from A-Eon would most likely be e5500-based (QorIQ T1) I guess.
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=11382&forum=3&start=13
  • »11.10.15 - 00:03
    Posts: 2053 from 2003/6/4
    http://amigaworld.net/modules/newbb/viewtopic.php?mode=viewtopic&topic_id=40603&forum=16&start=20&viewmode=flat&order=0
    From what Chain-Q and Pavlor wrote in that thread I guess it's P102x based. e500v2 - pity!
    [ Editiert durch Zylesea 11.10.2015 - 00:27 ]
  • »11.10.15 - 00:24
    Pity indeed. According to this, A1222 "Tabor" would be Zigotzky's "P1022 Custom board" he said he bought in 2014. I'm surprised this is actually an A-Eon/ACube board.
  • »11.10.15 - 00:35
    Spectre660
    Posts: 275 from 2015/6/30
    Why is everyone taking this so hard ?
    I have one too and it is a very nice board.
    [ Edited by Spectre660 10.10.2015 - 20:38 ]
  • »11.10.15 - 01:26
    redrumloa
    Posts: 1424 from 2003/4/13
    I'm not 100% sure I am following this. If this Acube rebranding someone else's hardware and marking it up for the OS4 market? Is this a rpi level board for 1,000 Euro as someone mentioned? Who is the original manufacturer? Wiki?
  • »11.10.15 - 04:33
    Spectre660
    We wait for the official announcement.
    But I link back to my post a few days ago with a quote from Trevor's Amiga Blog
    were he introduced me as a member of the A-Eon core Linux Support Team.
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=11&topic_id=11137&post_id=121579&viewmode=flat&sortorder=0&showonepost=1
  • »11.10.15 - 04:53
    Everblue
    Posts: 167 from 2004/1/6
    @Spectre666 you have a Tabor board?
    Why is Tabor being compared to a Raspberry Pi? Pricewise it surely isn't one!
  • »11.10.15 - 08:52
    Cego
    Posts: 712 from 2006/5/28
    the new sam followup Board will have a dual core processor and 1,2GHz Speed. the price will be the same as the current sam.
    [ Edited by Cego 11.10.2015 - 09:36 ]
  • »11.10.15 - 10:31
    Everblue
    That's good - hopefully "soon" considering that Acube have been out of Sam460 boards for a while now.
  • »11.10.15 - 11:02
    Have you clicked the 2nd link in comment #138?
    ...but not for OS4 nor MorphOS.
  • »11.10.15 - 12:15
    Spectre660
    Time will tell.
    WIth the joint resources of A-Eon,Ultra Varisys,Acube and Hyperion and others I would bet that it will be a nice board for OS4 .
  • »11.10.15 - 12:56
    So has this board been developed by Varisys?
    I have severe doubts about that. After all, the incompatibility of the e500v2 core is the reason the UltimatePPC has been put on hold (or cancelled?). And it was also discussed years before in feanor's market research for new PowerPC system.
  • »11.10.15 - 14:43
    Spectre660
    I can't preempt the official announcement.
    But the Hardware is what drives changes in software.
  • »11.10.15 - 15:15
    If this is based an e500v2 cored cpu, you can bet one thing, it will "drive" away support from MorphOS.
  • »11.10.15 - 15:21
    Posts: 2720 from 2003/2/24
    That sounds perhaps more interesting than the "Tabor", do you have any more info about that one? Like what is its CPU for example and planned availability etc?
  • »11.10.15 - 17:39
    ONLY hardware that is an IMPROVEMENT.
  • »11.10.15 - 18:03
    Tha Sam follow up _is_ the Tabor: Dual core 1.2 GHz priced between 700 EUR and 1000 EUR - unfortunately with an incompatible and slow fpu. Rumours have it a compatible FPU can be emulated though. We'll see. luckily this board is not too important fom a MorphOS centric POV since we have plenty hardware already.
    If support is a cheap shot, then welcome. If support will be hard, don't waste development time on it and put the effort better into MorphOS NG.
  • »11.10.15 - 20:54
    Everblue
    I quote, especially the last sentence.
  • »11.10.15 - 21:12
    Well, you mentioned Varisys in the context of Tabor, so this limits the possibilities :-)
    Changes can be for the better or for the worse ;-) Except for automotive chips (e200 core), GPR-based FPU and SPE SIMD have been deprecated by Freescale with the advent of the e500mc core.
  • »11.10.15 - 23:19
    Yes, as much as I am loath to admit it, I can't see supporting a board that requires different floating point routines.
    And, I would have qualified this with a statement about the continued potential introduction of further e5500 or e6500 core based systems, but I'm not sure that the topic carries as much interest with me as it once did.
    NG NG, might as well continue to lead, instead of following.
  • »11.10.15 - 23:35
    Spectre660
    A-Eon's e500mc core option, the P3041 Cyrus +, was cancelled .
    [ Edited by Spectre660 11.10.2015 - 19:11 ]
  • »12.10.15 - 00:10
    Ah, for some reason I got the impression that the follow-up to the Sam would be a second piece of HW. ;-)
    The Sam460cr is €539 (was it ever really available BTW?). So it's not at all "at the same price", far from it.
    Yes, the e500v2 has been confirmed by Christian. He say the FPU is fast, at least on a Linux where the OS and applications has been specially compiled for it. This is of course completely impossible in the case of OS4. And he say that regular PPC Linux works but that the OS must emulate a normal FPU then. Then it won't be fast at all. This is how it must be done by OS4 as well. Anything he say in that post about performance in DebianPPCSPE is irrelevant for OS4.
    He say he is surprised by the performance. Probably his specially compiled Linux setup also makes extensive use of the RadeonHD GPU for offloading things like video and whatnot. But isn't the "e500" kind of a slightly evolved/souped-up "G3" and running at higher clock? No Altivec, and in this case no usable HW FPU as well (for OS4). Nothing you do heavy rendering on, in other words?
    Speaking of GFX cards, what about the PCIe slot? Pavlor say it's v1.0 (250MB/s per lane). I get as much as the x16 slot only has a few lanes connected, but how many? Pavlor claims 4 lanes. But the data sheet (linked to by Pavlor ;-)) speaks about many controllers but *not available simultaneously* (depends on HW configuration perhaps?), so with the known other features of the Tabor, does x4 lanes for graphics sound reasonable? If so, it should offer about the same GFX bandwidth as the AGP 4x available in most of the decade old Mac HW that most of us use with MorphOS, right?
    Well, all in all I think this could have been a nice machine. Had it had a proper FPU. At half its price. And had it been 10 years ago. As it stands, "our" Macs still seem like a far better option in all aspects; power, price, bang/buck, the versatility of models, etc. And MorphOS of course! ;-)
    "We" have made the most and the best out of what the PPC platform has to offer and are enjoying it fully, "they" are still "chasing the dragon". ;-)
    Ah, well...
  • »12.10.15 - 00:14
    eliyahu
    Posts: 67 from 2011/4/21
    gotta agree with you there. personally i want a machine that can dual-boot AOS4 and MOS, but i'd rather MOS NG come out sooner if i had to give up one or the other. i really think MOS NG is the future and am terribly excited about it. so, from my point of view, anything that takes development time away from it -- especially for custom boards given their costs -- is something i'd hope the dev team would punt on.
    -- eliyahu
  • »12.10.15 - 00:21
    I know that A-Eon cancelled it, but what has this got to do with the price of fish? It was their own decision to cancel it. And even if cancellation was justified, why should that imply they had to go backwards to the e500v2?
  • »12.10.15 - 00:39
    Spectre660
    if several boards were in the design stage at the same time and one was cancelled how does that imply going backwards ?
    I known that A-Eon cancelled it, but what has this to do with the price of fish? It was their own decision to cancel it. And even if it was justified, why should that imply they had to go backwards to the e500v2?
  • »12.10.15 - 00:49
