MorphOS Developer
Posts: 508 from 2003/4/11
Quote:Cego wrote:
bigfoot wrote:
For those of you benchmarking Quake 3, make sure you do the following:
1) Reboot
2) Don't run anything that uses OpenGL
3) Open a shell and type the following command: setenv TGLSYNC 0
4) Start Quake 3
5) In the Quake 3 console, type: r_primitives 2
6) In the same console, type: timedemo 1
7) Finally type: demo four
If you get anything below 50 FPS, you're either running a very high resolution on a very weak graphics card or you're using an Efika ;)
it seems the Powerbook 5,8 is one of those weak machines... I have only 30,2 FPS in 640x480
Unlikely. My PowerBook5,6 gets 60.6 FPS at 1280x854 (the native resolution). At 640x480 it gets 126.2 FPS.
