change video board?
    Kronos wrote:
    @Jim
    There is only one 350MHz PowerMac G4 that can run MorphOS
    http://www.everymac.com/systems/apple/powermac_g4/specs/powermac_g4_350_agp.html
    So yes most aftermarket CPU cards should work.
    Edit:
    Problem is, that 1GHz Sonnet is already more expensive as just buying another PowerMac >= 1GHz ;)
    Might be, I can get G4s at positively stupid prices (then again, G5s are now also very cheap), but with shipping...
    Anyway, the 1 GHz upgrade is not at a bad price.
    The total upgrade cost, even with overseas shipping should not be more than $100.
    Of course, I can get a 2.5 GHz G5 for $100, but shipping it would be prohibitively expensive.
  • »25.05.14 - 18:32
    sabbate
    Posts: 110 from 2013/7/7
    in December I take a g5 does not cost much
  • »26.05.14 - 18:15
    sabbate
    hello guys,
    I solved the problem graphics card ati rage also good for video and also my computer even if the old is fine, the problem I loaded the video from the usb 1.1 port to a external HD.
    I tried to install the files on the internal hd and everything works morphos is great also for old machine
    hi thanks
  • »11.06.14 - 13:31
