How to boot MorphOS on Mac Mini?
    Etze
    Posts: 6 from 2013/3/3
    Hi there,
    I just got a Mac Mini G4 (1,5GHz, 512MB RAM, 64MB VRAM) and wanted to test MorphOS. So I downloaded the ISO from the official Website and burned a CD. First try with Toast 11 (on my C2D-Mac Mini using OSX 10.7.x). Second try with Windows 7 (built-in image-burning tool).
    Both CDs don't seem to work on the G4 Mini. It refuses to boot and ejects them after some seconds, though I hold the C key. If I insert the CDs when OSX (10.4.x) is started, it tells me that it's empty...??? WTF?
    Anything that could have went wrong? The DVD-Drive in the Mini seems to work as it reads other CDs and DVDs without problems.
    I can't wait to test MorphOS.... :-x
    Any help?
  • »21.03.13 - 08:40
    hooligan
    Posts: 1948 from 2003/2/23
    http://www.imgburn.com/
  • »21.03.13 - 08:50
    Etze
    Ok, I will try this tonight. Thanks!
  • »21.03.13 - 08:51
    catohagen
    Posts: 297 from 2003/5/20
    i was gonna say 'burn the iso in morphos' but instead i say
    Welcome to Morphos and Morphzone  :-D
  • »21.03.13 - 08:59
    Etze
    "Welcome to MorphZone" -> thanks!
    "Welcome to MorphOS" -> not yet. Maybe tonight  ;-)
  • »21.03.13 - 09:18
    ausPPC
    Posts: 543 from 2007/8/6
    Maybe try another brand of writable cd.
  • »21.03.13 - 19:28
    Etze
    didn't work :-(
    - I downloaded the image again just to be sure.
    - I used another brand of writable CD
    - I used another writer
    - I used ImgBurn
    After I tried some older burnt CDs (to check if they are even recognized) without success (they all seem to be empty) and after I successfully tried the MorphOS-CD on my C2D-Mac-Mini I am quiet sure that the G4-Mini has some problems with the DVD-drive...  :-x
    Do you think this can be repaired? Otherwise I would have to return the computer.
  • »21.03.13 - 20:24
    Posts: 3311 from 2003/3/5
    The drive is relatively easy to replace on your own. You can also boot MorphOS from a USB drive.
  • »21.03.13 - 20:40
    Etze
    Thanks, but I don't want to pay for a "new" drive, because he sold the Mac Mini stating it was fully working. I'll have to contact the seller. Dammit! :-x
  • »22.03.13 - 05:56
