Via_rhine on Pegasos 2 connects at speed of 10 mbps?!
    Dragster
    Posts: 99 from 2005/11/6
    Hi all, just to see if anyone has this issue... isn't the via_rhine ethernet driver supossed to support and run at 100 mbps?
    My DSL modem has 100 mbps ports... my laptop PC and my Powerbook connect at speeds of 100 mbps to the same modem.. not so the via_rhine on my Pegasos so I'm wondering why the via_rhine doesn't! And to make it more weird... OS4 does connect at 100 mbps with the same ethernet port...on the same hardware to the same modem...
    Comments welcome,
    Cheers..
    Dragster
    [ Edited by Dragster 05.02.2013 - 21:08 ]
  • »06.02.13 - 01:08
    catohagen
    Posts: 297 from 2003/5/20
    you could try to create envarc:sana2/via_rhinepci_0.config and put
    100BASETX
    FULLDUPLEX
    inside and see if that helps
  • »06.02.13 - 04:32
    Dragster
    Hey there mate.. thanks for your reply.
    Tried it but it didn't work... you have a Pegasos II right? Does the via_rhine NIC connect at 100 mbps with roadshow/miamidlx or netstack?
    Cheers,
    Dragster
  • »06.02.13 - 15:14
    Posts: 1390 from 2010/1/6
    There was a thread about that issue on Pegasosforum.de (from Thore). On MorphOS, network-statistics shows also 10mbps, but it seems that this value is'nt the truth...... Thore reported that his PEG2 is as slow as shown, but mine (and others) connets with 100mpbs - nevertheless 10mbps is shown in statistics.....
    You report now the same behaviour under OS4.....strange! I've tested speed under OpenFirmware - seems hardware is OK. MorphOS uses a stack based on AmiTCP - maybe Roadshow and AmiTCP have the same issues (seems it depends to device....). But the strange thing: why are'nt all PEG2 affected....? (Depending on board-revision.........?)
  • »06.02.13 - 16:56
    Posts: 12558 from 2003/5/22
    > On MorphOS, network-statistics shows also 10mbps [...]. Thore reported that
    Actually, he measured a LAN upload speed of 48 Mbit/s (6 MByte/s), which wouldn't be possible with a real 10 Mbit connection.
    http://www.pegasosforum.de/viewtopic.php?p=51154#p51154
    Does he? As I've understood him, OS4 correctly shows a 100 Mbit connection for him.
  • »06.02.13 - 20:40
