gigabit usb adapter
    catohagen
    Posts: 297 from 2003/5/20
    any chance this would work on morphos ?
    http://eu.startech.com/Networking-IO/Adapter-Cards/Compact-Black-USB-20-to-Gigabit-Ethernet-NIC-Network-Adapter~USB21000S
    anyone use similar adapters?
  • »24.01.13 - 09:57
    boot_wb
    Posts: 874 from 2007/4/9
    @Catohagen
    This appears to use the ASIX AX88178 chipset (according to Newegg).
    According to the AROS Poseidon hardware support page there are no supported devices using this chipset, so probably not.
    I can confirm that the Belkin F5D5050 works well, although it's only 100Mb/s.
    [ Edited by boot_wb 24.01.2013 - 13:20 ]
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »24.01.13 - 11:19
    catohagen
    crap...but do aros poseidon <-> morphos 3.1 use the same drivers?
    Who updates AROS Poseidon and who updates Morphos usb stack ?
    A bluetooth stack for Morphos would be sweet too :)
  • »24.01.13 - 11:58
    Posts: 12558 from 2003/5/22
    Some thoughts on that from several years ago:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6378&forum=3&start=4
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=5281&forum=11&start=24
  • »24.01.13 - 13:48
