My Quicksilver is now sporting a SATA adapter and SATA drive
    Doffo
    Posts: 508 from 2010/10/14
    The only issue im having now is that when I install MorphOS straight to the SSD, the mac will not boot from it at startup.. Am I missing some options or settings while installing? Yes the card is detected as a Wiebe.
    ******************Update
    It is infact Bootable! :) So when I power up it shows the folder with the blinking ? and Folder icon.... But wait about 10 more seconds then the computer finally boots up into MorphOS. :P
    Wonder how I can get it to recognize it faster or if it is the card itself being waited on?
    Any ideas?
    [ Edited by Doffo 02.11.2012 - 14:16 ]
    YUUUP!
  • »02.11.12 - 17:50
    Motosampy
    Posts: 199 from 2004/8/14
    OF tries to boot most likely from another device. This is easy to verify: Boot to OF (hold Command - Option - O - F when you hear the chime), type printenv <enter> and find boot-device row, if it's correctly set to boot from the SATA drive it should say something like (depending on your configuration): boot-device pci /WiebeSATA3512@15/@0:5,\\:tbxi hd:,\\tbxi
    I'm not expert with OF commands so can't help if the boot device is not correct, one way is to detach all other hard drives and do a fresh install to the SATA disk, then the boot device should be set correctly.
  • »02.11.12 - 20:30
    Doffo
    @Motosampy
    Thanks for the help. I will have to double check it.
    YUUUP!
  • »03.11.12 - 00:39
    caver99
    Posts: 131 from 2012/6/14
    sorry but could someone point me in the direction of the mac bios files please.
    Powermac quicksilver Dual 1ghz Dual Boot Morph OS 3.7 and OS X 10.5.8
    PS3 x5
    Xbox 360 x 6
    Wii x 3
    PSP x 3
    DS x 3
    Custom Gaming Rig
     :-o
  • »05.11.12 - 08:34
    Posts: 12558 from 2003/5/22
    Click the 2nd link in posting #39.
  • »05.11.12 - 09:15
    caver99
    Thanks, i had checked the links but did not realise that the mac firmware was also on there.
    [ Edited by caver99 05.11.2012 - 12:27 ]
    PS3 x5
    Xbox 360 x 6
    Wii x 3
    PSP x 3
    DS x 3
    Custom Gaming Rig
     :-o
  • »05.11.12 - 10:11
    redrumloa
    Posts: 1424 from 2003/4/13
    Doffo,
    Here is what I did to get it to flash:
    1.extract the wiebeflash file to your desktop.
    2.Open up a terminal shell
    3.Give yourself super user by typing 'sudo su' along with your account name
    4.Now, use cd for change directory until you are in your wiebeflash folder
    ex: /Users/asdfasdf/Desktop/wiebeflash/
    5.Now, DRAG the FlashTool to your Terminal window, then press ENTER (Trying to run it by typing in the name doesnt do anything, unless I missed a command)
    5.Follow the steps and be sure to flash it with the FIRMWARE for mac compatibilty
    6.reboot, then check system profiler if it is listed in the PCI cards. :)
    Done and working! The SATA card is now autobooting in my MDD!  :-)
  • »24.11.12 - 23:29
    Way to go Red.
    Never bothered to do this because I hadn't been running OSX.
    What revision is the minimum for running the Flashtool utility?
  • »25.11.12 - 01:23
    redrumloa
    Jim,
    OSX 10.2.8 or higher is required. I speficially bought a cheapo 2nd hand G4 powerMac because i din't have a working PPC OSX install anywhere. Now I did the deed, I have a cheapo G4 PowerMac for sale :-)
    [ Edited by redrumloa 24.11.2012 - 22:48 ]
  • »25.11.12 - 01:47
    Thanks, I have a copy of Jaguar sitting around I could install temporarily for the flash.
    I don't have much use for OSX.
  • »25.11.12 - 03:34
    pan1k
    Posts: 147 from 2009/1/20
    Well, the SATA is acting up again, I thought it was weird. My audio programs seem to halt when playing music from the SATA drives. I tried to copy a file from PATA to SATA and Ambient crashed/locked up. I dont know anymore!!!  :-o
    MacMini 1.5Ghz / Amiga 4000T Cyberstorm 060, 132MB RAM, Cybervision 64/3D, XSurf-III, MP3@64, Buddha Flash / Amiga 1200 GVP 030, Subway USB, 32MB RAM
  • »24.12.12 - 13:04
    Doffo
    pan1k,
    My problem went away after that wiebe firmware. Havent had any issues transferring. Though I only am using SFS and kept my partitions under 120GB.
    YUUUP!
  • »25.12.12 - 15:23
