lb-link bl-mp01
    amiga4001
    Posts: 451 from 2006/11/16
    I am using a netgear ethernetadapter on my powerbook and this works nice.
    Now I invested in a second ethernetswitch for my peg2 and I went the cheap way ebay and a non a brand.
    Nevertheless there are more people usin g these so maybe someone can help me out.
    I can acces the device and use the quick setup wizzard.
    Now when I fill in the security method .wpa2 and the key to acces the router it gives me a statuslog which seems to be the end off the wizzard..only refresh button there.
    There is no field in which I can set the desired network/router.
    When I set it manually the desired router is detected and I select it but it returns to non connect and selecting the desired network/router.
    Please help
  • »22.11.12 - 19:24
    boot_wb
    Posts: 874 from 2007/4/9
    Try a different cable. I found I had trouble with the supplied cable-on-a-reel: often I couldn't save the settings, or the connection would be dropped intermittently.
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »23.11.12 - 00:10
    amiga4001
    Used another cable to no avail.
    If only there was some manual in english.
    I set the switch to client that's right yes?Used as a wifi receiver on my peg2.
    Maybe setting up the client is not possible in quick setup?
  • »23.11.12 - 04:36
    Jambalah
    Posts: 820 from 2008/3/30
    Hi, I'm using a netgear ethernet router with powermac and since it has a wifi option, I connected a netgear access point to my Peg2 so to have a wireless connection working on it.
    Now If I have understood correctly the problem is in your switch ethernet (wich receive signal from ethernet adapter): you wrote you can access to switch setup page and you set it as client and that is correct. Did you checked if it has the dhcp disabled?
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »24.11.12 - 06:28
    Miky060
    Posts: 694 from 2003/2/24
    I took one of this too and Got some problems. After I' changed its IP from 192.168.16.254 to 192.168.1.2 it worked. I don't know if this can help in you case.
    Moreover it seems to not work with WEP encryption, I switched my router to WPA2.
  • »24.11.12 - 09:53
    Fraggle
    Posts: 203 from 2012/9/2
    You do know that WEP is blown wide open now don`t you? It`s literally a ten minute crack if the network is busy so WPA is probably best anyway.
    Fraggle
  • »24.11.12 - 10:22
    Miky060
    Why a router with WPA2 encryption and custom password would be easy to crack?
  • »24.11.12 - 12:59
    Fraggle
    It wouldn`t, you misunderstand me - I meant WEP is broken, so it`s good that you switched :o)
    Fraggle
  • »24.11.12 - 13:20
    Miky060
    Aaah, ok! :-) Yes, I took the occasion to switch to a better ecnyption mode too..
  • »24.11.12 - 13:40
    boot_wb
    The manual that came with the router was totally inadequate iirc (a picturebook operation guide).
    'Client' is the correct choice (out of AP/Router/Client).
    I avoided the wizard and went straight for manual setup.
    The menu systems are dreadful, but once set up is does work ok. Have you tried Wireless Settings>Site Survey? Select your desired network, then click 'add profile'.
    Another alternative is to export your settings, edit them manually, and re-import them (Administration>Settings Management)
    Mine is set up as in client mode, connecting to a wireless network called <Foobar> with password <password>:
    I'd just copy and paste the relevant bits, since there's also DHCP, routing and MAC address information in the file.
    (NB - the SSID and password appear twice in the settings)
    #The following line must not be removed.
    Default
    WebInit=1
    HostName=admin
    Login=admin
    Password=admin
    OperationMode=2
    Platform=RT5350
    wanConnectionMode=STATIC
    wan_ipaddr=192.168.0.150
    wan_netmask=255.255.255.0
    wan_gateway=192.168.0.1
    wan_primary_dns=8.8.8.8
    wan_secondary_dns=4.4.4.4
    wan_pppoe_user=pppoe_user
    wan_pppoe_pass=pppoe_passwd
    wan_l2tp_server=l2tp_server
    wan_l2tp_user=l2tp_user
    wan_l2tp_pass=l2tp_passwd
    wan_l2tp_mode=0
    wan_l2tp_ip=192.168.1.1
    wan_l2tp_netmask=255.255.255.0
    wan_l2tp_gateway=192.168.1.254
    wan_pptp_server=pptp_server
    wan_pptp_user=pptp_user
    wan_pptp_pass=pptp_passwd
    wan_pptp_mode=0
    wan_pptp_ip=192.168.1.1
    wan_pptp_netmask=255.255.255.0
    wan_pptp_gateway=192.168.1.254
    lan_ipaddr=192.168.1.1
    lan_netmask=255.255.255.0
    dhcpEnabled=1
    dhcpStart=192.168.1.100
    dhcpEnd=192.168.1.200
    dhcpMask=255.255.255.0
    dhcpPriDns=8.8.8.8
    dhcpSecDns=8.8.4.4
    dhcpGateway=192.168.1.1
    dhcpLease=3600
    stpEnabled=0
    lltdEnabled=0
    igmpEnabled=0
    natEnabled=1
    IPPortFilterEnable=0
    IPPortFilterRules=
    PortForwardEnable=0
    PortForwardRules=
    MacFilterEnable=0
    MacFilterRules=
    DefaultFirewallPolicy=1
    DMZEnable=0
    DMZIPAddress=
    TZ=
    NTPServerIP=
    NTPSync=
    DDNSProvider=
    DDNS=
    DDNSAccount=
    DDNSPassword=
    CountryRegion=5
    CountryRegionABand=0
    CountryCode=
    BssidNum=1
    SSID1=<Foobar>
    SSID=BL-MP01
    WirelessMode=0
    TxRate=0
    Channel=6
    BasicRate=15
    BeaconPeriod=100
    DtimPeriod=1
    TxPower=100
    DisableOLBC=0
    BGProtection=2
    TxAntenna=
    RxAntenna=
    TxPreamble=0
    RTSThreshold=2347
    FragThreshold=2346
    TxBurst=1
    PktAggregate=1
    TurboRate=0
    WmmCapable=1
    APAifsn=3;7;1;1
    APCwmin=4;4;3;2
    APCwmax=6;10;4;3
    APTxop=0;0;94;47
    APACM=0;0;0;0
    BSSAifsn=3;7;2;2
    BSSCwmin=4;4;3;2
    BSSCwmax=10;10;4;3
    BSSTxop=0;0;94;47
    BSSACM=0;0;0;0
    AckPolicy=0;0;0;0
    APSDCapable=0
    DLSCapable=0
    NoForwarding=0
    NoForwardingBTNBSSID=0
    HideSSID=0
    ShortSlot=1
    AutoChannelSelect=0
    SecurityMode=0
    VLANEnable=0
    VLANName=
    VLANID=0
    VLANPriority=0
    WscConfMode=0
    WscConfStatus=2
    WscAKMP=1
    WscConfigured=1
    WscModeOption=0
    WscActionIndex=9
    WscPinCode=
    WscRegResult=1
    WscUseUPnP=1
    WscUseUFD=0
    WscSSID=RalinkInitialAP
    WscKeyMGMT=WPA-EAP
    WscConfigMethod=138
    WscAuthType=1
    WscEncrypType=1
    WscNewKey=scaptest
    IEEE8021X=0
    IEEE80211H=0
    CSPeriod=6
    PreAuth=0
    AuthMode=WPAPSKWPA2PSK
    EncrypType=TKIP
    RekeyInterval=3600
    RekeyMethod=TIME
    PMKCachePeriod=10
    WPAPSK1=<password>
    DefaultKeyID=1
    Key1Type=0
    Key1Str1=
    Key2Type=0
    Key2Str1=
    Key3Type=0
    Key3Str1=
    Key4Type=0
    Key4Str1=
    WapiPskType=0
    HSCounter=0
    HT_HTC=1
    HT_RDG=1
    HT_LinkAdapt=0
    HT_OpMode=0
    HT_MpduDensity=5
    HT_EXTCHA=0
    HT_BW=1
    HT_AutoBA=1
    HT_BADecline=0
    HT_AMSDU=0
    HT_BAWinSize=64
    HT_GI=1
    HT_STBC=1
    HT_MCS=33
    HT_PROTECT=1
    HT_MIMOPS=3
    HT_40MHZ_INTOLERANT=0
    HT_TxStream=1
    HT_RxStream=1
    HT_DisallowTKIP=1
    NintendoCapable=0
    AccessPolicy0=0
    AccessControlList0=
    AccessPolicy1=0
    AccessControlList1=
    AccessPolicy2=0
    AccessControlList2=
    AccessPolicy3=0
    AccessControlList3=
    WdsEnable=0
    WdsEncrypType=NONE
    WdsList=
    WdsKey=
    WirelessEvent=0
    RADIUS_Server=
    RADIUS_Port=1812
    RADIUS_Key=
    RADIUS_Acct_Server=
    RADIUS_Acct_Port=1813
    RADIUS_Acct_Key=
    session_timeout_interval=0
    idle_timeout_interval=0
    staWirelessMode=9
    Language=en
    marker=0
    FixedTxMode=HT
    HT_BSSCoexistence=0
    apClient=0
    QoSEnable=0
    QoSUploadBandwidth=2048
    QoSDownloadBandwidth=2048
    qoslist=111
    MTUvalue=1500
    WAN_MAC_ADDR=48:2:2A:79:3B:E
    RFICType=8
    TXPath=1
    RXPath=1
    wan_dhcp_hn=SUBNET1
    macCloneEnabled=0
    macCloneMac=48:02:2A:79:3B:0C
    Lan2Enabled=0
    lan2_ipaddr=
    lan2_netmask=
    upnpEnabled=0
    radvdEnabled=0
    pppoeREnabled=0
    dnsPEnabled=0
    staProfile=PROF001
    staSSID=<Foobar>
    staNetworkType=1
    staAdhocMode=0
    staPSMode=0
    staChannel=0
    staPreamType=2
    staRTSCheck=0
    staRTS=2347
    staFragmentCheck=0
    staFragment=2346
    staAuth=7
    staKey1=0
    staKey2=0
    staKey3=0
    staKey4=0
    staKey1Type=0
    staKey2Type=0
    staKey3Type=0
    staKey4Type=0
    staKey1Length=0
    staKey2Length=0
    staKey3Length=0
    staKey4Length=0
    staKeyDefaultId=1
    staEncrypt=4
    staWpaPsk=<password>
    sta8021xEAP=7
    sta8021xTunnel=3
    sta8021xKeyMgmt=3
    sta8021xIdentity=0
    sta8021xPassword=0
    sta8021xClientCert=0
    sta8021xPrivateKey=0
    sta8021xPrivateKeyPassword=0
    sta8021xCACert=0
    staActive=0
    staWPSMode=0
  • »24.11.12 - 16:13
    amiga4001
    Ok a few options to try out.
    I have no button add profile in the site survey..there should be one?All I have is connect,rescan and disconnect there.
    2 networks are detected including mine.When I try connecting my network it pauzes a while and then returns to main screen site survey with no selection off a network.
    I'll try changing the ip adres and exporting,changing ,importing the configfile.
  • »24.11.12 - 17:04
